I just got my new Toshiba lap top. I am running a vista home premium 32-bit SP 1. What i was wondering is how could i create a bootable disk in case my lap top crashes. Is there a feature already with the lap top or do i need a program for that. Also any good suggestions on how to optimize vista?
We don't stop playing because we grow old; we grow old because we stop playing.” (George Bernard Shaw, 1856-1950)
call toshiba support and ask for the vista install disk? you'd think a decent company would have supplied it with the comp. if they don't supply one maybe download a bootable linux distro like knoppix.
It probably has a hidden restore partition already on the hard drive. You probably have the option to create a set of restore discs - look in the start menu to see if there is a program to do this, you usually have the option to create only 1 set of discs.
"I will not be pushed, filed, stamped, indexed, briefed, debriefed, or numbered! My life is my own" - the Prisoner
(NO MAN IS JUST A NUMBER)
be seeing you ( RIP Patrick McGoohan ) -
All new toshiba laptops come with the utility to create a master back set of discs for the purpose of restoring the system to factory setup install default.
Under the programs list from the start button ... either inside a folder called toshiba or out in the open list ... used it twice today.
Sony DVD bootable one one drive but not another
By perfection in forum DVD & Blu-ray WritersReplies: 7Last Post: 20th Jun 2011, 12:59 -
dvd burning error when make a bootable dvd image
By junian116 in forum Authoring (DVD)Replies: 1Last Post: 5th Apr 2011, 03:58 -
how to make windows 7 dvd bootable
By mysts in forum ComputerReplies: 8Last Post: 16th Jul 2009, 21:43 -
Bootable ghost CD
By romanstopme in forum ComputerReplies: 4Last Post: 14th Nov 2008, 18:17 -
Converting 2 avi clips to bootable DVD?
By apfable2 in forum Authoring (DVD)Replies: 6Last Post: 15th Feb 2008, 12:46
