I'm having the same problem most (all?) DVCII users have. The audio and video of the SVCD mpeg files don't synchronize correctly when I capture video with my DVCII board. I've seen several users claim that the problem is fixed by capturing to separate files and multiplexing with TMPG. However, TMPG doesn't recognize the video file (.m2v).
Can anyone help? I'm trying to create SVCD of family videos off of a regular VCR tape.
Thanks.
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Option 1) Use bbMPEG to multiplex (personally recommended)
Option 2) Im not sure why TMPGEnc isnt recognizing the file extension m2v, but you can try renaming it with a .mpv extenstion.
I've had good luck with my DVCII (even with Athlon / Abit mobo). Although i dont use it much as i prefer capturing to AVI using VirtualDub and encoding with avisynth / CCE )
Good luck! -
Sound sync with my DVC II is ALWAYS rock solid!
Remember to disable the video preview screen b4 capturing. Thats very important.
Also, make sure nothing else is running in the background. -
Sorry. Should have mentioned that bbMPEG also can't read the file. I get the following error message.
File clip82.m2v is not a 11172-2 or 13818-2 Video stream.
Best format to copy VHS and DVC's (mini) to make sure they'll last?
By shaytala in forum Newbie / General discussionsReplies: 3Last Post: 12th Sep 2010, 13:53 -
Dazzle DVC 90 Capturing
By LangleyM in forum CapturingReplies: 2Last Post: 19th Apr 2009, 09:42 -
digital cable = the new svcd format?
By mazinz in forum DVB / IPTVReplies: 38Last Post: 8th Jul 2008, 01:22 -
Unable to read or format DVD+RW disc
By alegator in forum ComputerReplies: 4Last Post: 8th Oct 2007, 11:11 -
MTR can't read DVD... READ ERROR: Can't Open IFO.
By strathq in forum MacReplies: 16Last Post: 16th Jun 2007, 23:04
