I see SKY are charging CURRENT customers £30 for setup costs (FREE only to NEW customers)
what EXACTLY has to be changed? - dont they just change recievers over? or do they have to fit a special LnB onto current dish and run a 2nd line into premises?
cos if not I could EASILY setup myself - swap boxes and setup via menu
Results 1 to 13 of 13
Its just a case of swaping boxes IF you had Sky+ before. Otherwise you need the dual LnB.
no just standard SKY - I thought it may need dual LnB and 2nd line for the recording while watching another channel capabilities
it does. as does sky+ which would allow you a stright swap....
So you need an install really. sky or independant.
I would get on the phone to sky and say you want it but don't want to pay for install - see where you get.... Otherwise cancel sky (they will beg you to stay see http://forums.moneysavingexpert.com/showthread.html?t=115125&highlight=sky+upgrade) and then sign up as a new customer!SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
yeah i was thinking of that...
is it easy to transfer recorded movies etc from the SKY+HD Hard-Drive to a PC?
Iam quite good with this sort of stuff , know how to encode etc... just need to know if its possible and how is it done? -
Not that i am aware of (without specialised kit). The only way i have done it is via the "copy" feature which allows you to copy to DVDR. From there to your PC etc... But this route is only SD not HD.Originally Posted by snadgeSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
"DualLNB" is not the correct term.
Dual mean s H and V outputted independently.
What you guys mean is Monoblock LNB.
*** Now that you have read me, do some other things. *** -
Tell them you won'y upgrade to HD unless they waive the fee.Originally Posted by snadge
They usually fold if you threaten to cancel - two friends of mine did that and the fee was dropped.Regards,
Rob -
Basically you have your DVDR connected to Sky box via scart. Then any recordings from the sky planner can be marked to copy. When you invoke copy, those recordings are played back and so can be recorded by the DVDR.Originally Posted by snadgeSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
i dont have a DVD-Recorder
ah well , thanks for the info anyway - i may get one -
The dealers who sell them here call them dual, quad, octo, etc. If you were to call them anything else they wouldn't know what you were talking about. Also the type sold for Sky dishes is considerably different from the type sold for standard dishes.Originally Posted by [_chef_
Sky+ HD to PC
By BIGD22 in forum DVB / IPTVReplies: 4Last Post: 27th Sep 2011, 14:59 -
recording SKY+HD
By snadge in forum DVB / IPTVReplies: 0Last Post: 26th Feb 2009, 13:15 -
SKY HD or FreesatHD...which is best?
By snadge in forum DVB / IPTVReplies: 5Last Post: 19th Feb 2009, 06:07 -
Sky + And/Or Sky HD Recording To Pc With DAZZLE
By akenny01 in forum Capturing and VCRReplies: 0Last Post: 7th Mar 2008, 19:02 -
Sky+ to PC
By pjvw in forum Capturing and VCRReplies: 10Last Post: 13th Sep 2007, 13:00
