Hi!
Well I'm very new to this and I'm usually pretty good with tech stuff but I have no idea how to fix this. I bought a Sony RDR-VX535 DVD Recorder & VCR Combo Player to dub my old VHS tapes onto DVDs. I did one and I used a DVD +R disc to dub. It worked fine on the Sony and I finalized it...then went to play it on my computer's DVD ROM player, but it didn't recognize the disc at all. It just behaves as if nothing's in the drive. What am I doing wrong? Are DVD+R's not compatible in this computer? It's a 2002 Dell running Windows XP. Very frustrating! I sincerely appreciate any help.
Thanks!!
Tracey
Hi Tracey. What brand of DVD discs are you using? Some of them really stink. Verbatim and Taiyo Yuden brands are the most reliable for the widest variety of players. Also, with a 2002 system, the DVD drive on your PC may be dying -- or simply may be dirty. These are some of the things that could be causing your problems.
Try, if you can, to play it on another dvd player, if it does not then I would re finalise it.
If it does, then re boot your pc, I have had dvd drives not see discs and re boot works.PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
How are you recording the DVD?
Make sure you select DVD Video instead of DVD+VR and finalize the disc.
Also see if there's a firmware update for your DVD-ROM:
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
FLV won't play correctly in another computer
By kfain in forum Video ConversionReplies: 6Last Post: 29th Dec 2011, 12:10 -
recorded dvd won't play on computer or other players??
By wundahoss in forum Newbie / General discussionsReplies: 6Last Post: 9th Jan 2011, 16:55 -
dvd won't play on player but will on computer
By bubbadss in forum Authoring (DVD)Replies: 9Last Post: 28th Apr 2010, 02:49 -
Help--Canon ZR85 Mini DV won't play on computer (Mac OSX)
By sjenn2001 in forum Newbie / General discussionsReplies: 3Last Post: 11th Oct 2009, 20:15 -
Burned DVD from TV and won't play in computer
By dnlowe in forum DVD & Blu-ray RecordersReplies: 4Last Post: 12th Sep 2009, 17:41
