Is it possible to convert mp3 files to wma files?
Results 1 to 9 of 9
I was looking for something to convert my mp3s to wmas so that they can be smaller and allow me to put more on my mp4 player since it also plays wma files.
compression is similar between mp3, and wma9 .
All you are doing is losing quality by re-encoding. So you can choose a lower bitrate if you want it smaller, but it will definitely sound worse
filesize = bitrate x running time -
So what you are saying is that my best bet is to get a sd card to expand the size of my player instead of converting to smaller files although when I rip using wma from my cds they are smaller than the mp3s with the same bitrate with windows media player?
Yes I would get more storage spaceOriginally Posted by t_jay17
If they are the same bitrate, they are the same filesize (filesize = bitrate x running time)
If both are 128kb/s for example, they should be the same size (slightly different from overhead in the container). They should sound similar between wma9 and mp3.
AAC is better, you could probably use 100kb/s and have it sound the same as 128kb/s mp3 or wma9 on most sources -
Also is there a way to drop the bitrate so that the files are smaller mine are around 192kb/s and maybe if i drop it down to 128 i can save space?
you can't just drop it, you have to re-encode it at that bitrate
start with the original cd, not the lossy mp3, because everytime you re-encode using a lossy format the quality decreases irreversibly
Convert expired WMA to MP3
By pchan in forum AudioReplies: 4Last Post: 20th Jul 2011, 10:44 -
wma to mp3
By rjc7394 in forum AudioReplies: 5Last Post: 14th Sep 2010, 15:00 -
wma > mp3 quit working
By marleyg in forum ffmpegX general discussionReplies: 1Last Post: 25th Jan 2010, 05:40 -
Help with MOD to mp3/wma
By Bluntz11 in forum AudioReplies: 10Last Post: 14th Apr 2009, 21:12 -
wma to mp3
By rjc7394 in forum AudioReplies: 0Last Post: 8th Jul 2007, 20:28
