i need to use my PC monitor to watch TV and attach rca / composite plugs to it (including my WII/Gamecube)
I know there are various ways and boxes but i'm not that knowledgeable on such matter
If possible, I wish to have both my PC and my WII connected to this single monitor, without disconnecting and shifting inputs, and if possible I wish also to have this device work as a good quality capture card. It doesnt really matter if I need to switch the PC on to watch TV or have my WII displayed on screen AS LONG as the quality is crystal clear.
I already own a capture card - and even though it records /captures really well, the "view without rec" option is really sluggish...
If there are any suggestions of such tuners/captures etc pls share your thoughts
So far locally I found only these two, but non of the stores have it on display to see the picture quality
http://www.manhattan-products.com/en...onverter-tuner
http://www.media-tech.eu/page.php?do...id=1402&kid=23
thanks
what kind of monitor is it? a crt or lcd? what kind of inputs does it have now?
if its an older crt, you are going to have to buy a fairly expensive converter box. -
I couldn't follow your links, since they're not exactly correct.
Something like this should work well. I have one on a spare monitor. -
An LCD-TV would be the better solution.
http://www.kiva.org/about -
Not if he's limited on space or cash.
The original poster lives in Malta so I presume requires a PC card with PAL tuner? I use an old A-Ver card myself but it requires a reasonably strong signal to produce a clear picture.
PC or monitor?
By Jomapil in forum ComputerReplies: 11Last Post: 16th Oct 2009, 11:08 -
Can I use a headrest monitor as my server monitor when traveling
By regtcnlgy in forum ComputerReplies: 4Last Post: 17th Aug 2009, 08:43 -
HD TV monitor?
By toolady in forum DVB / IPTVReplies: 4Last Post: 30th Oct 2008, 18:28 -
Use DV as second monitor?
By boyerama in forum Newbie / General discussionsReplies: 1Last Post: 29th May 2007, 02:38 -
Monitor
By JonathanK in forum AudioReplies: 2Last Post: 13th May 2007, 17:15
