Evening Everyone!
I cant seem to figure out. this problem. I cannont install my binaries. it wont let me everytime I try I get this problem
"##/bin/sh: -c: line 0: unexpected EOF while looking for matching `''
/bin/sh: -c: line 1: syntax error: unexpected end of file"
anyone?
I am lost and having the same issue.
Nothing I do works. I have raked through the forum and attempted so many fixes. mencoder and mplayer are both red and mpeg2enc will not install but at least its black. I get that error msg and then it un-checks the mpeg2enc box. Anyone have any ideas? Several hours on this problem without success. I have an admin password and I am using it. No illegal characters.
If the installer script was faulty (e.g. a quotation mark where it shouldn't be), then more users would have this issue. That leaves just your setup, as far as I can tell. You didn't name your disk e.g. Pete's Disk, or have a folder John's downloads, i.e. used an apostrophe in a place where the installer script might encounter it?
To rule out user account password problems, change it temporarily to "aa" (without the quotes) or something similarly simple.
Thanks Case. I re-read your first post and looked at the folder name where the files were stored and sure enough it was named using an apostrophe. The simplest answer was the correct one. I removed the offending punctuation mark and everything installed perfectly. Thanks for your help. Very appreciated.
Can't install binaries for ffmpegX 0.0.9y
By kostas1969 in forum ffmpegX general discussionReplies: 2Last Post: 21st Feb 2012, 12:14 -
installing ffmpegx' binaries | ##/bin/sh: line 1: 5146 Illegal instruction
By veranyon in forum ffmpegX general discussionReplies: 1Last Post: 29th Oct 2008, 13:13 -
Can't install ffmpegx binaries on Macbook Pro OSX 10.4.11
By camelsauce in forum ffmpegX general discussionReplies: 3Last Post: 7th Aug 2008, 12:49 -
ffmpegX additional binaries - where the h*ll should they be?!
By nickelbump in forum ffmpegX general discussionReplies: 10Last Post: 31st Dec 2007, 20:12 -
installing Binaries
By mahanpots in forum ffmpegX general discussionReplies: 1Last Post: 14th Dec 2007, 10:16
