I have a DVD that has ~15 subtitle tracks (according to dvdshrink, vlc etc). I want to imprint one of the tracks and convert the video to MP4 (x264) using Avidemux. First step is to create idx and sub with vobsub. When I open the vobsub dialog in avidemux for this I only see 5 of the subtitle tracks. The names of the tracks do not match the language that actually is in there and the track I want to imprint is not there. Is there any obvious reason why this could happen? I tried to remove all subtitles (with dvdshrink) except the one I want but then nothing is displayed in the dropdows with available tracks. Is there any other GUI to use vobsub to create external idx and sub files that I can utilize in Avidemux?
When I open the same DVD with autogk I see all the tracks and they have correct names. Don't autogk also use vobsub? How can the result differ?
Similiar behaviour appear on all DVD's, I used this example to keep it concrete.
You can't "imprint" subtitles on a video without re-encoding. Some containers do support inserting subs into the data stream without changing the video, and these subs can be displayed with appropriate players. I don't know if this is possible with the MP4 container.
Read my blog here.
Avidemux aspect ratio question [from newbie to Avidemux]
By ANOther1676 in forum EditingReplies: 1Last Post: 20th Jan 2012, 20:07 -
Vobsub
By leftspeaker2000 in forum SubtitleReplies: 0Last Post: 31st May 2011, 10:41 -
Problem with vobsub 2.23
By mop59136 in forum SubtitleReplies: 2Last Post: 8th Mar 2011, 11:07 -
Vobsub (or just sup??) for HDPlayer
By qknet in forum SubtitleReplies: 5Last Post: 28th Dec 2010, 18:38 -
Subtitles using VobSUB
By rafael_laffront in forum SubtitleReplies: 0Last Post: 8th May 2007, 15:39
