Results 1 to 13 of 13
    Feb 2009
    Germany
    Every time I use this programm and want to author a new DVD with a Menu and several .vob Files I get this failure message:
    Microsoft Windows [Version 6.0.6001]
    Copyright (c) 2006 Microsoft Corporation. Alle Rechte vorbehalten.
    C:\Users\Chris\Documents\GFDOutDir\Temp>Time: 16.02.2009 11:17:51
    (shrink and) mux video and audio files
    INFO: [mplex.exe] mplex version 1.9.0 (2.2.7 $Date: 2006/02/01 22:23:01 $)
    INFO: [mplex.exe] File e:\Gilmore Girls\Staffel 1\Episode 4\DVD\Gilmore_Girls_2009-02-05_115907.001.m2v looks like an MPEG Video stream.
    INFO: [mplex.exe] File e:\Gilmore Girls\Staffel 1\Episode 4\DVD\Gilmore_Girls_2009-02-05_115907.001.mp2 looks like an MPEG Audio stream.
    INFO: [mplex.exe] Video stream 0: profile 8 selected - ignoring non-standard options!
    INFO: [mplex.exe] Found 1 audio streams and 1 video streams
    INFO: [mplex.exe] Selecting dvdauthor DVD output profile
    INFO: [mplex.exe] Multiplexing video program stream!
    INFO: [mplex.exe] Scanning for header info: Video stream e0 (e:\Gilmore Girls\Staffel 1\Episode 4\DVD\Gilmore_Girls_2009-02-05_115907.001.m2v)
    INFO: [mplex.exe] VIDEO STREAM: e0
    INFO: [mplex.exe] Frame width : 720
    INFO: [mplex.exe] Frame height : 576
    INFO: [mplex.exe] Aspect ratio : 4:3 display
    INFO: [mplex.exe] Picture rate : 25.000 frames/sec
    INFO: [mplex.exe] Bit rate : 7045600 bits/sec
    INFO: [mplex.exe] Vbv buffer size : 229376 bytes
    INFO: [mplex.exe] CSPF : 0
    INFO: [mplex.exe] Scanning for header info: Audio stream c0 (e:\Gilmore Girls\Staffel 1\Episode 4\DVD\Gilmore_Girls_2009-02-05_115907.001.mp2)
    INFO: [mplex.exe] MPEG AUDIO STREAM: c0
    INFO: [mplex.exe] Audio version : 1.0
    INFO: [mplex.exe] Layer : 2
    INFO: [mplex.exe] CRC checksums : no
    INFO: [mplex.exe] Bit rate : 24576 bytes/sec (192 kbit/sec)
    INFO: [mplex.exe] Frequency : 48000 Hz
    INFO: [mplex.exe] Mode : 0 stereo
    INFO: [mplex.exe] Mode extension : 0
    INFO: [mplex.exe] Copyright bit : 0 no copyright
    INFO: [mplex.exe] Original/Copy : 1 original
    INFO: [mplex.exe] Emphasis : 0 none
    INFO: [mplex.exe] SYSTEMS/PROGRAM stream:
    INFO: [mplex.exe] rough-guess multiplexed stream data rate : 7391896
    INFO: [mplex.exe] target data-rate specified : 10080000
    INFO: [mplex.exe] Setting specified specified data rate: 10080000
    INFO: [mplex.exe] Run-in delay = 7200 Video delay = 7200 Audio delay = 10800
    INFO: [mplex.exe] New sequence commences...
    INFO: [mplex.exe] Video e0: buf= 0 frame=000000 sector=00000000
    INFO: [mplex.exe] Audio c0: buf= 0 frame=000000 sector=00000000
    INFO: [mplex.exe] Scanned to end AU 64193
    INFO: [mplex.exe] STREAM e0 completed
    INFO: [mplex.exe] STREAM c0 completed
    INFO: [mplex.exe] Multiplex completion at SCR=231100708.
    INFO: [mplex.exe] Video e0: completed
    INFO: [mplex.exe] Audio c0: completed
    INFO: [mplex.exe] VIDEO_STATISTICS: e0
    INFO: [mplex.exe] Video Stream length: 1114432364 bytes
    INFO: [mplex.exe] Sequence headers: 5350
    INFO: [mplex.exe] Sequence ends : 1
    INFO: [mplex.exe] No. Pictures : 64194
    INFO: [mplex.exe] No. Groups : 5350
    INFO: [mplex.exe] No. I Frames : 5350 avg. size 69935 bytes
    INFO: [mplex.exe] No. P Frames : 16050 avg. size 18679 bytes
    INFO: [mplex.exe] No. B Frames : 42794 avg. size 10292 bytes
    INFO: [mplex.exe] Average bit-rate : 3472000 bits/sec
    INFO: [mplex.exe] Peak bit-rate : 7046000 bits/sec
    INFO: [mplex.exe] BUFFERING min 15 Buf max 158218
    INFO: [mplex.exe] AUDIO_STATISTICS: c0
    INFO: [mplex.exe] Audio stream length 61626240 bytes.
    INFO: [mplex.exe] Syncwords : 106990
    INFO: [mplex.exe] Frames : 106990 padded
    INFO: [mplex.exe] Frames : 0 unpadded
    INFO: [mplex.exe] BUFFERING min 15 Buf max 587
    INFO: [mplex.exe] MUX STATUS: no under-runs detected.
    C:\Users\Chris\Documents\GFDOutDir\Temp>Time: 16.02.2009 11:21:45
    *creating MMback.m2v
    C:\Users\Chris\Documents\GFDOutDir\Temp>Time: 16.02.2009 11:25:12
    *mux to MMback.mpg
    INFO: [mplex.exe] File C:\Users\Chris\Documents\GFDOutDir\Temp\MMBackg.m2 v looks like an MPEG Video stream.
    INFO: [mplex.exe] File d:\Downloads\02 - The Las - There She Goes.wav.MP2 looks like an MPEG Audio stream.
    INFO: [mplex.exe] Scanning for header info: Video stream e0 (C:\Users\Chris\Documents\GFDOutDir\Temp\MMBackg.m 2v)
    INFO: [mplex.exe] Bit rate : 7000000 bits/sec
    INFO: [mplex.exe] Scanning for header info: Audio stream c0 (d:\Downloads\02 - The Las - There She Goes.wav.MP2)
    INFO: [mplex.exe] Bit rate : 20480 bytes/sec (160 kbit/sec)
    INFO: [mplex.exe] Frequency : 44100 Hz
    INFO: [mplex.exe] rough-guess multiplexed stream data rate : 7311896
    ++ WARN: [mplex.exe] Stream e0: data will arrive too late sent(SCR)=7314 required(DTS)=7200
    ++ WARN: [mplex.exe] Video e0: buf= 99212 frame=000001 sector=00000049
    ++ WARN: [mplex.exe] Audio c0: buf= 0 frame=000000 sector=00000000
    INFO: [mplex.exe] Scanned to end AU 1154
    INFO: [mplex.exe] Multiplex completion at SCR=4153490.
    INFO: [mplex.exe] Video Stream length: 14044710 bytes
    INFO: [mplex.exe] Sequence headers: 77
    INFO: [mplex.exe] No. Pictures : 1155
    INFO: [mplex.exe] No. Groups : 77
    INFO: [mplex.exe] No. I Frames : 77 avg. size106349 bytes
    INFO: [mplex.exe] No. P Frames : 309 avg. size 8115 bytes
    INFO: [mplex.exe] No. B Frames : 769 avg. size 4353 bytes
    INFO: [mplex.exe] Average bit-rate : 2431600 bits/sec
    INFO: [mplex.exe] Peak bit-rate : 2841200 bits/sec
    INFO: [mplex.exe] BUFFERING min 18 Buf max 232156
    INFO: [mplex.exe] Audio stream length 923689 bytes.
    INFO: [mplex.exe] Syncwords : 1768
    INFO: [mplex.exe] Frames : 975 padded
    INFO: [mplex.exe] Frames : 793 unpadded
    INFO: [mplex.exe] BUFFERING min 15 Buf max 536
    **ERROR: [mplex.exe] MUX STATUS: Frame data under-runs detected!
    *creating menufile MMMenu.mpg
    DVDAuthor:pumux, version 0.6.14-GfD-2.
    Build options: gnugetopt iconv freetype
    Send bugs to <gfd@boraxsoft.de>
    STAT: 0:00:00.000
    INFO: PNG had 2 colors
    INFO: Constructing blank img
    INFO: Pickbuttongroups, success with 1 groups, useimg=1
    INFO: Found EOF in .sub file.
    INFO: Max_sub_size=5434
    INFO: 1 subtitles added, 0 subtitles skipped, stream: 32, offset: 0.12
    Does anyone knwos something about it?
  2. Try to use MuxMan as authoring engine.
    -> http://download.videohelp.com/gfd/Help/DefaultPermSettings.html
    If you still get an error, maybe your bitrate is to high (but from the log it seems to be ok).
    Feb 2009
    Germany
    I have downloaded Muxman and wanted tu use it as authoriing engine. But now, I can`t select my .vob files!! What format have I to convert my .vobs tu use them with muxman?
    One time when I only dropped 2 instead of 4 films for the menu, it worked with dvdauthor. I had a DVD with nice menu! If I want to use 4 films, I ever get that failure!
    Feb 2009
    Germany
    This is the log, if I use only 2 Films. The same Preferences and it works!!
    C:\Users\Chris\Documents\GFDOutDir\Temp>Time: 17.02.2009 18:40:33
    C:\Users\Chris\Documents\GFDOutDir\Temp>Time: 17.02.2009 18:43:46
    *mux to MMback.mpg
    INFO: [mplex.exe] Video Stream length: 10220293 bytes
    INFO: [mplex.exe] No. I Frames : 77 avg. size 84887 bytes
    INFO: [mplex.exe] No. P Frames : 309 avg. size 4892 bytes
    INFO: [mplex.exe] No. B Frames : 769 avg. size 2824 bytes
    INFO: [mplex.exe] Average bit-rate : 1769600 bits/sec
    INFO: [mplex.exe] Peak bit-rate : 2239200 bits/sec
    INFO: [mplex.exe] BUFFERING min 22 Buf max 214272
    STAT: 0:00:00.000
    INFO: Max_sub_size=2652
    C:\Users\Chris\Documents\GFDOutDir\Temp>Time: 17.02.2009 18:43:48
    *creating TS1back.m2v
    INFO: [png2yuv.exe] Parsing & checking input files.
    INFO: [png2yuv.exe] Image dimensions are 720x576
    INFO: [png2yuv.exe] Movie frame rate is: 25.000000 frames/second
    INFO: [png2yuv.exe] Non-interlaced/progressive frames.
    INFO: [png2yuv.exe] Frame size: 720 x 576
    INFO: [png2yuv.exe] Now generating YUV4MPEG stream.
    INFO: [mpeg2enc.exe] SETTING EXTENDED MMX for MOTION!
    INFO: [mpeg2enc.exe] SETTING MMX for TRANSFORM!
    INFO: [mpeg2enc.exe] SETTING EXTENDED MMX for PREDICTION!
    INFO: [mpeg2enc.exe] Selecting DVD with dummy navigation packets output profile
    INFO: [mpeg2enc.exe] Encoding MPEG-2 video to C:\Users\Chris\Documents\GFDOutDir\Temp\TS1Backg.m 2v
    INFO: [mpeg2enc.exe] Horizontal size: 720 pel
    INFO: [mpeg2enc.exe] Vertical size: 576 pel
    INFO: [mpeg2enc.exe] Aspect ratio code: 2 = 4:3 display
    INFO: [mpeg2enc.exe] Frame rate code: 3 = 25.0 (PAL/SECAM VIDEO / converted FILM)
    INFO: [mpeg2enc.exe] Bitrate: 7000 KBit/s
    INFO: [mpeg2enc.exe] Quality factor: 1 (Quantisation = 1) (1=best, 31=worst)
    INFO: [mpeg2enc.exe] Field order for input: none/progressive
    INFO: [mpeg2enc.exe] Sequence unlimited length
    INFO: [mpeg2enc.exe] Search radius: 16
    INFO: [mpeg2enc.exe] DualPrime: no
    INFO: [mpeg2enc.exe] Using one-pass rate controller
    INFO: [mpeg2enc.exe] GOP SIZE RANGE 7 TO 15
    INFO: [mpeg2enc.exe] Setting colour/gamma parameters to "PAL B/G"
    INFO: [mpeg2enc.exe] Progressive format frames = 1
    INFO: [mpeg2enc.exe] Using default unmodified quantization matrices
    INFO: [mpeg2enc.exe] SETTING MMX and MMX for QUANTIZER!
    INFO: [mpeg2enc.exe] NEW GOP INIT length 15
    INFO: [mpeg2enc.exe] Signaling last frame = 0
    INFO: [mpeg2enc.exe] Enc1 0 0( 0) I q=3.70 [100% Intra]
    INFO: [mpeg2enc.exe] Sequence end reached
    INFO: [mpeg2enc.exe] Pass2 0 0( 0) I q=7.15 RECODED
    INFO: [mpeg2enc.exe] Guesstimated final muxed size = 43696
    C:\Users\Chris\Documents\GFDOutDir\Temp>Time: 17.02.2009 18:43:49
    *mux to TS1back.mpg
    INFO: [mplex.exe] File C:\Users\Chris\Documents\GFDOutDir\Temp\TS1Backg.m 2v looks like an MPEG Video stream.
    INFO: [mplex.exe] Found 0 audio streams and 1 video streams
    INFO: [mplex.exe] Scanning for header info: Video stream e0 (C:\Users\Chris\Documents\GFDOutDir\Temp\TS1Backg. m2v)
    INFO: [mplex.exe] rough-guess multiplexed stream data rate : 7144696
    INFO: [mplex.exe] Scanned to end AU 0
    INFO: [mplex.exe] Multiplex completion at SCR=3364.
    INFO: [mplex.exe] Video Stream length: 43696 bytes
    INFO: [mplex.exe] Sequence headers: 1
    INFO: [mplex.exe] No. Groups : 1
    INFO: [mplex.exe] No. I Frames : 1 avg. size 43696 bytes
    INFO: [mplex.exe] No. P Frames : 0 avg. size 0 bytes
    INFO: [mplex.exe] No. B Frames : 0 avg. size 0 bytes
    INFO: [mplex.exe] Average bit-rate : 8739200 bits/sec
    INFO: [mplex.exe] Peak bit-rate : 0 bits/sec
    INFO: [mplex.exe] BUFFERING stream too short for useful statistics
    *creating menufile TS1Menu.mpg
    STAT: 0:00:00.000
    INFO: Max_sub_size=260
    *creating TS2back.m2v
    INFO: [mpeg2enc.exe] Encoding MPEG-2 video to C:\Users\Chris\Documents\GFDOutDir\Temp\TS2Backg.m 2v
    C:\Users\Chris\Documents\GFDOutDir\Temp>Time: 17.02.2009 18:43:50
    *mux to TS2back.mpg
    INFO: [mplex.exe] File C:\Users\Chris\Documents\GFDOutDir\Temp\TS2Backg.m 2v looks like an MPEG Video stream.
    INFO: [mplex.exe] Scanning for header info: Video stream e0 (C:\Users\Chris\Documents\GFDOutDir\Temp\TS2Backg. m2v)
    *creating menufile TS2Menu.mpg
    STAT: 0:00:00.000
    author DVD
    DVDAuthor::dvdauthor, version 0.6.14-GfD-2.
    INFO: dvdauthor creating VTS
    STAT: Picking VTS 01
    STAT: Processing C:\Users\Chris\Documents\GFDOutDir\Temp\TS1Menu.mp g...
    INFO: Video pts = 0.120 .. 0.160
    INFO: Audio[32] pts = 0.120 .. 0.120
    STAT: VOBU 1 at 0MB, 1 PGCS
    INFO: Generating VTSM with the following video attributes:
    INFO: MPEG version: mpeg2
    INFO: TV standard: pal
    INFO: Aspect ratio: 4:3
    INFO: Resolution: 720x576
    STAT: Processing e:\Gilmore Girls\Staffel 1\Episode 1 - Alles auf Anfang\Geschnitten\DVD\Episode 1.vob...
    STAT: VOBU 16 at 1MB, 1 PGCS
    STAT: VOBU 32 at 5MB, 1 PGCS
    STAT: VOBU 48 at 9MB, 1 PGCS
    STAT: VOBU 64 at 13MB, 1 PGCS
    STAT: VOBU 80 at 17MB, 1 PGCS
    STAT: VOBU 96 at 20MB, 1 PGCS
    STAT: VOBU 112 at 23MB, 1 PGCS
    STAT: VOBU 128 at 26MB, 1 PGCS
    STAT: VOBU 144 at 30MB, 1 PGCS
    STAT: VOBU 160 at 33MB, 1 PGCS
    STAT: VOBU 176 at 35MB, 1 PGCS
    STAT: VOBU 192 at 39MB, 1 PGCS
    STAT: VOBU 208 at 42MB, 1 PGCS
    STAT: VOBU 224 at 45MB, 1 PGCS
    STAT: VOBU 240 at 49MB, 1 PGCS
    STAT: VOBU 256 at 52MB, 1 PGCS
    STAT: VOBU 272 at 55MB, 1 PGCS
    STAT: VOBU 288 at 58MB, 1 PGCS
    STAT: VOBU 304 at 62MB, 1 PGCS
    STAT: VOBU 320 at 65MB, 1 PGCS
    STAT: VOBU 336 at 69MB, 1 PGCS
    STAT: VOBU 352 at 72MB, 1 PGCS
    STAT: VOBU 368 at 76MB, 1 PGCS
    STAT: VOBU 384 at 79MB, 1 PGCS
    STAT: VOBU 400 at 82MB, 1 PGCS
    STAT: VOBU 416 at 86MB, 1 PGCS
    STAT: VOBU 432 at 90MB, 1 PGCS
    STAT: VOBU 448 at 93MB, 1 PGCS
    STAT: VOBU 464 at 96MB, 1 PGCS
    STAT: VOBU 480 at 100MB, 1 PGCS
    STAT: VOBU 496 at 103MB, 1 PGCS
    STAT: VOBU 512 at 107MB, 1 PGCS
    STAT: VOBU 528 at 110MB, 1 PGCS
    STAT: VOBU 544 at 114MB, 1 PGCS
    STAT: VOBU 560 at 117MB, 1 PGCS
    STAT: VOBU 576 at 120MB, 1 PGCS
    STAT: VOBU 592 at 123MB, 1 PGCS
    STAT: VOBU 608 at 126MB, 1 PGCS
    STAT: VOBU 624 at 129MB, 1 PGCS
    STAT: VOBU 640 at 133MB, 1 PGCS
    STAT: VOBU 656 at 136MB, 1 PGCS
    STAT: VOBU 672 at 139MB, 1 PGCS
    STAT: VOBU 688 at 143MB, 1 PGCS
    STAT: VOBU 704 at 146MB, 1 PGCS
    STAT: VOBU 720 at 149MB, 1 PGCS
    STAT: VOBU 736 at 152MB, 1 PGCS
    STAT: VOBU 752 at 154MB, 1 PGCS
    STAT: VOBU 768 at 157MB, 1 PGCS
    STAT: VOBU 784 at 160MB, 1 PGCS
    STAT: VOBU 800 at 163MB, 1 PGCS
    STAT: VOBU 816 at 166MB, 1 PGCS
    STAT: VOBU 832 at 169MB, 1 PGCS
    STAT: VOBU 848 at 172MB, 1 PGCS
    STAT: VOBU 864 at 175MB, 1 PGCS
    STAT: VOBU 880 at 178MB, 1 PGCS
    STAT: VOBU 896 at 182MB, 1 PGCS
    STAT: VOBU 912 at 186MB, 1 PGCS
    STAT: VOBU 928 at 189MB, 1 PGCS
    STAT: VOBU 944 at 192MB, 1 PGCS
    STAT: VOBU 960 at 196MB, 1 PGCS
    STAT: VOBU 976 at 200MB, 1 PGCS
    STAT: VOBU 992 at 203MB, 1 PGCS
    STAT: VOBU 1008 at 207MB, 1 PGCS
    STAT: VOBU 1024 at 210MB, 1 PGCS
    STAT: VOBU 1040 at 213MB, 1 PGCS
    STAT: VOBU 1056 at 215MB, 1 PGCS
    STAT: VOBU 1072 at 218MB, 1 PGCS
    STAT: VOBU 1088 at 221MB, 1 PGCS
    STAT: VOBU 1104 at 224MB, 1 PGCS
    STAT: VOBU 1120 at 227MB, 1 PGCS
    STAT: VOBU 1136 at 230MB, 1 PGCS
    STAT: VOBU 1152 at 234MB, 1 PGCS
    STAT: VOBU 1168 at 237MB, 1 PGCS
    STAT: VOBU 1184 at 240MB, 1 PGCS
    STAT: VOBU 1200 at 244MB, 1 PGCS
    STAT: VOBU 1216 at 247MB, 1 PGCS
    STAT: VOBU 1232 at 250MB, 1 PGCS
    STAT: VOBU 1248 at 253MB, 1 PGCS
    STAT: VOBU 1264 at 256MB, 1 PGCS
    STAT: VOBU 1280 at 260MB, 1 PGCS
    STAT: VOBU 1296 at 263MB, 1 PGCS
    STAT: VOBU 1312 at 267MB, 1 PGCS
    STAT: VOBU 1328 at 271MB, 1 PGCS
    STAT: VOBU 1344 at 274MB, 1 PGCS
    STAT: VOBU 1360 at 276MB, 1 PGCS
    STAT: VOBU 1376 at 280MB, 1 PGCS
    STAT: VOBU 1392 at 282MB, 1 PGCS
    STAT: VOBU 1408 at 286MB, 1 PGCS
    STAT: VOBU 1424 at 289MB, 1 PGCS
    STAT: VOBU 1440 at 292MB, 1 PGCS
    STAT: VOBU 1456 at 295MB, 1 PGCS
    STAT: VOBU 1472 at 298MB, 1 PGCS
    STAT: VOBU 1488 at 301MB, 1 PGCS
    STAT: VOBU 1504 at 305MB, 1 PGCS
    STAT: VOBU 1520 at 309MB, 1 PGCS
    STAT: VOBU 1536 at 313MB, 1 PGCS
    STAT: VOBU 1552 at 317MB, 1 PGCS
    STAT: VOBU 1568 at 321MB, 1 PGCS
    STAT: VOBU 1584 at 325MB, 1 PGCS
    STAT: VOBU 1600 at 328MB, 1 PGCS
    STAT: VOBU 1616 at 332MB, 1 PGCS
    STAT: VOBU 1632 at 335MB, 1 PGCS
    STAT: VOBU 1648 at 338MB, 1 PGCS
    STAT: VOBU 1664 at 341MB, 1 PGCS
    STAT: VOBU 1680 at 344MB, 1 PGCS
    STAT: VOBU 1696 at 347MB, 1 PGCS
    STAT: VOBU 1712 at 350MB, 1 PGCS
    STAT: VOBU 1728 at 353MB, 1 PGCS
    STAT: VOBU 1744 at 356MB, 1 PGCS
    STAT: VOBU 1760 at 360MB, 1 PGCS
    STAT: VOBU 1776 at 363MB, 1 PGCS
    STAT: VOBU 1792 at 367MB, 1 PGCS
    STAT: VOBU 1808 at 371MB, 1 PGCS
    STAT: VOBU 1824 at 374MB, 1 PGCS
    STAT: VOBU 1840 at 377MB, 1 PGCS
    STAT: VOBU 1856 at 380MB, 1 PGCS
    STAT: VOBU 1872 at 383MB, 1 PGCS
    STAT: VOBU 1888 at 386MB, 1 PGCS
    STAT: VOBU 1904 at 389MB, 1 PGCS
    STAT: VOBU 1920 at 392MB, 1 PGCS
    STAT: VOBU 1936 at 396MB, 1 PGCS
    STAT: VOBU 1952 at 399MB, 1 PGCS
    STAT: VOBU 1968 at 401MB, 1 PGCS
    STAT: VOBU 1984 at 404MB, 1 PGCS
    STAT: VOBU 2000 at 407MB, 1 PGCS
    STAT: VOBU 2016 at 409MB, 1 PGCS
    STAT: VOBU 2032 at 412MB, 1 PGCS
    STAT: VOBU 2048 at 415MB, 1 PGCS
    STAT: VOBU 2064 at 418MB, 1 PGCS
    STAT: VOBU 2080 at 420MB, 1 PGCS
    STAT: VOBU 2096 at 423MB, 1 PGCS
    STAT: VOBU 2112 at 426MB, 1 PGCS
    STAT: VOBU 2128 at 429MB, 1 PGCS
    STAT: VOBU 2144 at 433MB, 1 PGCS
    STAT: VOBU 2160 at 436MB, 1 PGCS
    STAT: VOBU 2176 at 439MB, 1 PGCS
    STAT: VOBU 2192 at 442MB, 1 PGCS
    STAT: VOBU 2208 at 446MB, 1 PGCS
    STAT: VOBU 2224 at 449MB, 1 PGCS
    STAT: VOBU 2240 at 452MB, 1 PGCS
    STAT: VOBU 2256 at 456MB, 1 PGCS
    STAT: VOBU 2272 at 459MB, 1 PGCS
    STAT: VOBU 2288 at 462MB, 1 PGCS
    STAT: VOBU 2304 at 465MB, 1 PGCS
    STAT: VOBU 2320 at 469MB, 1 PGCS
    STAT: VOBU 2336 at 472MB, 1 PGCS
    STAT: VOBU 2352 at 476MB, 1 PGCS
    STAT: VOBU 2368 at 480MB, 1 PGCS
    STAT: VOBU 2384 at 482MB, 1 PGCS
    STAT: VOBU 2400 at 485MB, 1 PGCS
    STAT: VOBU 2416 at 489MB, 1 PGCS
    STAT: VOBU 2432 at 491MB, 1 PGCS
    STAT: VOBU 2448 at 494MB, 1 PGCS
    STAT: VOBU 2464 at 497MB, 1 PGCS
    STAT: VOBU 2480 at 499MB, 1 PGCS
    STAT: VOBU 2496 at 502MB, 1 PGCS
    STAT: VOBU 2512 at 505MB, 1 PGCS
    STAT: VOBU 2528 at 508MB, 1 PGCS
    STAT: VOBU 2544 at 510MB, 1 PGCS
    STAT: VOBU 2560 at 513MB, 1 PGCS
    STAT: VOBU 2576 at 516MB, 1 PGCS
    STAT: VOBU 2592 at 519MB, 1 PGCS
    STAT: VOBU 2608 at 521MB, 1 PGCS
    STAT: VOBU 2624 at 524MB, 1 PGCS
    STAT: VOBU 2640 at 526MB, 1 PGCS
    STAT: VOBU 2656 at 529MB, 1 PGCS
    STAT: VOBU 2672 at 531MB, 1 PGCS
    STAT: VOBU 2688 at 534MB, 1 PGCS
    STAT: VOBU 2704 at 537MB, 1 PGCS
    STAT: VOBU 2720 at 540MB, 1 PGCS
    STAT: VOBU 2736 at 543MB, 1 PGCS
    STAT: VOBU 2752 at 546MB, 1 PGCS
    STAT: VOBU 2768 at 549MB, 1 PGCS
    STAT: VOBU 2784 at 552MB, 1 PGCS
    STAT: VOBU 2800 at 555MB, 1 PGCS
    STAT: VOBU 2816 at 557MB, 1 PGCS
    STAT: VOBU 2832 at 560MB, 1 PGCS
    STAT: VOBU 2848 at 563MB, 1 PGCS
    STAT: VOBU 2864 at 566MB, 1 PGCS
    STAT: VOBU 2880 at 568MB, 1 PGCS
    STAT: VOBU 2896 at 571MB, 1 PGCS
    STAT: VOBU 2912 at 574MB, 1 PGCS
    STAT: VOBU 2928 at 577MB, 1 PGCS
    STAT: VOBU 2944 at 580MB, 1 PGCS
    STAT: VOBU 2960 at 582MB, 1 PGCS
    STAT: VOBU 2976 at 585MB, 1 PGCS
    STAT: VOBU 2992 at 587MB, 1 PGCS
    STAT: VOBU 3008 at 590MB, 1 PGCS
    STAT: VOBU 3024 at 594MB, 1 PGCS
    STAT: VOBU 3040 at 599MB, 1 PGCS
    STAT: VOBU 3056 at 603MB, 1 PGCS
    STAT: VOBU 3072 at 607MB, 1 PGCS
    STAT: VOBU 3088 at 611MB, 1 PGCS
    STAT: VOBU 3104 at 614MB, 1 PGCS
    STAT: VOBU 3120 at 617MB, 1 PGCS
    STAT: VOBU 3136 at 620MB, 1 PGCS
    STAT: VOBU 3152 at 623MB, 1 PGCS
    STAT: VOBU 3168 at 626MB, 1 PGCS
    STAT: VOBU 3184 at 629MB, 1 PGCS
    STAT: VOBU 3200 at 632MB, 1 PGCS
    STAT: VOBU 3216 at 634MB, 1 PGCS
    STAT: VOBU 3232 at 637MB, 1 PGCS
    STAT: VOBU 3248 at 641MB, 1 PGCS
    STAT: VOBU 3264 at 643MB, 1 PGCS
    STAT: VOBU 3280 at 646MB, 1 PGCS
    STAT: VOBU 3296 at 648MB, 1 PGCS
    STAT: VOBU 3312 at 651MB, 1 PGCS
    STAT: VOBU 3328 at 654MB, 1 PGCS
    STAT: VOBU 3344 at 657MB, 1 PGCS
    STAT: VOBU 3360 at 660MB, 1 PGCS
    STAT: VOBU 3376 at 662MB, 1 PGCS
    STAT: VOBU 3392 at 665MB, 1 PGCS
    STAT: VOBU 3408 at 668MB, 1 PGCS
    STAT: VOBU 3424 at 670MB, 1 PGCS
    STAT: VOBU 3440 at 673MB, 1 PGCS
    STAT: VOBU 3456 at 676MB, 1 PGCS
    STAT: VOBU 3472 at 679MB, 1 PGCS
    STAT: VOBU 3488 at 683MB, 1 PGCS
    STAT: VOBU 3504 at 687MB, 1 PGCS
    STAT: VOBU 3520 at 690MB, 1 PGCS
    STAT: VOBU 3536 at 693MB, 1 PGCS
    STAT: VOBU 3552 at 697MB, 1 PGCS
    STAT: VOBU 3568 at 700MB, 1 PGCS
    STAT: VOBU 3584 at 704MB, 1 PGCS
    STAT: VOBU 3600 at 707MB, 1 PGCS
    STAT: VOBU 3616 at 710MB, 1 PGCS
    STAT: VOBU 3632 at 714MB, 1 PGCS
    STAT: VOBU 3648 at 717MB, 1 PGCS
    STAT: VOBU 3664 at 720MB, 1 PGCS
    STAT: VOBU 3680 at 724MB, 1 PGCS
    STAT: VOBU 3696 at 728MB, 1 PGCS
    STAT: VOBU 3712 at 731MB, 1 PGCS
    STAT: VOBU 3728 at 733MB, 1 PGCS
    STAT: VOBU 3744 at 736MB, 1 PGCS
    STAT: VOBU 3760 at 739MB, 1 PGCS
    STAT: VOBU 3776 at 741MB, 1 PGCS
    STAT: VOBU 3792 at 744MB, 1 PGCS
    STAT: VOBU 3808 at 747MB, 1 PGCS
    STAT: VOBU 3824 at 750MB, 1 PGCS
    STAT: VOBU 3840 at 753MB, 1 PGCS
    STAT: VOBU 3856 at 755MB, 1 PGCS
    STAT: VOBU 3872 at 758MB, 1 PGCS
    STAT: VOBU 3888 at 761MB, 1 PGCS
    STAT: VOBU 3904 at 764MB, 1 PGCS
    STAT: VOBU 3920 at 767MB, 1 PGCS
    STAT: VOBU 3936 at 771MB, 1 PGCS
    STAT: VOBU 3952 at 775MB, 1 PGCS
    STAT: VOBU 3968 at 778MB, 1 PGCS
    STAT: VOBU 3984 at 782MB, 1 PGCS
    STAT: VOBU 4000 at 785MB, 1 PGCS
    STAT: VOBU 4016 at 789MB, 1 PGCS
    STAT: VOBU 4032 at 792MB, 1 PGCS
    STAT: VOBU 4048 at 795MB, 1 PGCS
    STAT: VOBU 4064 at 799MB, 1 PGCS
    STAT: VOBU 4080 at 802MB, 1 PGCS
    STAT: VOBU 4096 at 805MB, 1 PGCS
    STAT: VOBU 4112 at 808MB, 1 PGCS
    STAT: VOBU 4128 at 811MB, 1 PGCS
    STAT: VOBU 4144 at 814MB, 1 PGCS
    STAT: VOBU 4160 at 817MB, 1 PGCS
    STAT: VOBU 4176 at 821MB, 1 PGCS
    STAT: VOBU 4192 at 824MB, 1 PGCS
    STAT: VOBU 4208 at 827MB, 1 PGCS
    STAT: VOBU 4224 at 830MB, 1 PGCS
    STAT: VOBU 4240 at 834MB, 1 PGCS
    STAT: VOBU 4256 at 837MB, 1 PGCS
    STAT: VOBU 4272 at 840MB, 1 PGCS
    STAT: VOBU 4288 at 843MB, 1 PGCS
    STAT: VOBU 4304 at 846MB, 1 PGCS
    STAT: VOBU 4320 at 850MB, 1 PGCS
    STAT: VOBU 4336 at 853MB, 1 PGCS
    STAT: VOBU 4352 at 855MB, 1 PGCS
    STAT: VOBU 4368 at 858MB, 1 PGCS
    STAT: VOBU 4384 at 861MB, 1 PGCS
    STAT: VOBU 4400 at 864MB, 1 PGCS
    STAT: VOBU 4416 at 867MB, 1 PGCS
    STAT: VOBU 4432 at 871MB, 1 PGCS
    STAT: VOBU 4448 at 874MB, 1 PGCS
    STAT: VOBU 4464 at 877MB, 1 PGCS
    STAT: VOBU 4480 at 881MB, 1 PGCS
    STAT: VOBU 4496 at 884MB, 1 PGCS
    STAT: VOBU 4512 at 888MB, 1 PGCS
    STAT: VOBU 4528 at 892MB, 1 PGCS
    STAT: VOBU 4544 at 896MB, 1 PGCS
    STAT: VOBU 4560 at 899MB, 1 PGCS
    STAT: VOBU 4576 at 902MB, 1 PGCS
    STAT: VOBU 4592 at 905MB, 1 PGCS
    STAT: VOBU 4608 at 908MB, 1 PGCS
    STAT: VOBU 4624 at 911MB, 1 PGCS
    STAT: VOBU 4640 at 915MB, 1 PGCS
    STAT: VOBU 4656 at 918MB, 1 PGCS
    STAT: VOBU 4672 at 922MB, 1 PGCS
    STAT: VOBU 4688 at 925MB, 1 PGCS
    STAT: VOBU 4704 at 929MB, 1 PGCS
    STAT: VOBU 4720 at 933MB, 1 PGCSSTAT: VOBU 4736 at 937MB, 1 PGCS
    STAT: VOBU 4752 at 940MB, 1 PGCS
    STAT: VOBU 4768 at 944MB, 1 PGCS
    STAT: VOBU 4784 at 947MB, 1 PGCS
    STAT: VOBU 4800 at 951MB, 1 PGCS
    STAT: VOBU 4816 at 954MB, 1 PGCS
    STAT: VOBU 4832 at 957MB, 1 PGCS
    STAT: VOBU 4848 at 960MB, 1 PGCS
    STAT: VOBU 4864 at 963MB, 1 PGCS
    STAT: VOBU 4880 at 966MB, 1 PGCS
    STAT: VOBU 4896 at 969MB, 1 PGCS
    STAT: VOBU 4912 at 973MB, 1 PGCS
    STAT: VOBU 4928 at 975MB, 1 PGCS
    STAT: VOBU 4944 at 979MB, 1 PGCS
    STAT: VOBU 4960 at 983MB, 1 PGCS
    STAT: VOBU 4976 at 986MB, 1 PGCS
    STAT: VOBU 4992 at 988MB, 1 PGCS
    STAT: VOBU 5008 at 991MB, 1 PGCS
    STAT: VOBU 5024 at 994MB, 1 PGCS
    STAT: VOBU 5040 at 997MB, 1 PGCS
    STAT: VOBU 5056 at 1000MB, 1 PGCS
    STAT: VOBU 5072 at 1003MB, 1 PGCS
    STAT: VOBU 5088 at 1005MB, 1 PGCS
    STAT: VOBU 5104 at 1008MB, 1 PGCS
    STAT: VOBU 5120 at 1011MB, 1 PGCS
    STAT: VOBU 5136 at 1014MB, 1 PGCS
    STAT: VOBU 5152 at 1017MB, 1 PGCS
    STAT: VOBU 5168 at 1021MB, 1 PGCS
    STAT: VOBU 5184 at 1025MB, 1 PGCS
    STAT: VOBU 5200 at 1028MB, 1 PGCS
    INFO: Video pts = 0.280 .. 2497.000
    INFO: Audio[8] pts = 0.280 .. 2497.000
    STAT: VOBU 5202 at 1028MB, 1 PGCS
    INFO: Generating VTS with the following video attributes:
    INFO: Audio ch 0 format: mp2/2ch, 48khz 16bps
    STAT: fixed 1 VOBUS
    STAT: fixing VOBU at 1MB (17/5202, 0%)
    STAT: fixing VOBU at 5MB (33/5202, 0%)
    STAT: fixing VOBU at 9MB (49/5202, 0%)
    STAT: fixing VOBU at 13MB (65/5202, 1%)
    STAT: fixing VOBU at 17MB (81/5202, 1%)
    STAT: fixing VOBU at 20MB (97/5202, 1%)
    STAT: fixing VOBU at 23MB (113/5202, 2%)
    STAT: fixing VOBU at 26MB (129/5202, 2%)
    STAT: fixing VOBU at 30MB (145/5202, 2%)
    STAT: fixing VOBU at 33MB (161/5202, 3%)
    STAT: fixing VOBU at 35MB (177/5202, 3%)
    STAT: fixing VOBU at 39MB (193/5202, 3%)
    STAT: fixing VOBU at 42MB (209/5202, 3%)
    STAT: fixing VOBU at 45MB (225/5202, 4%)
    STAT: fixing VOBU at 49MB (241/5202, 4%)
    STAT: fixing VOBU at 52MB (257/5202, 4%)
    STAT: fixing VOBU at 55MB (273/5202, 5%)
    STAT: fixing VOBU at 58MB (289/5202, 5%)
    STAT: fixing VOBU at 62MB (305/5202, 5%)
    STAT: fixing VOBU at 65MB (321/5202, 6%)
    STAT: fixing VOBU at 69MB (337/5202, 6%)
    STAT: fixing VOBU at 72MB (353/5202, 6%)
    STAT: fixing VOBU at 76MB (369/5202, 7%)
    STAT: fixing VOBU at 79MB (385/5202, 7%)
    STAT: fixing VOBU at 82MB (401/5202, 7%)
    STAT: fixing VOBU at 86MB (417/5202, 7%)
    STAT: fixing VOBU at 90MB (433/5202, 8%)
    STAT: fixing VOBU at 93MB (449/5202, 8%)
    STAT: fixing VOBU at 96MB (465/5202, 8%)
    STAT: fixing VOBU at 100MB (481/5202, 9%)
    STAT: fixing VOBU at 103MB (497/5202, 9%)
    STAT: fixing VOBU at 107MB (513/5202, 9%)
    STAT: fixing VOBU at 110MB (529/5202, 10%)
    STAT: fixing VOBU at 114MB (545/5202, 10%)
    STAT: fixing VOBU at 117MB (561/5202, 10%)
    STAT: fixing VOBU at 120MB (577/5202, 11%)
    STAT: fixing VOBU at 123MB (593/5202, 11%)
    STAT: fixing VOBU at 126MB (609/5202, 11%)
    STAT: fixing VOBU at 129MB (625/5202, 11%)
    STAT: fixing VOBU at 133MB (641/5202, 12%)
    STAT: fixing VOBU at 136MB (657/5202, 12%)
    STAT: fixing VOBU at 139MB (673/5202, 12%)
    STAT: fixing VOBU at 143MB (689/5202, 13%)
    STAT: fixing VOBU at 146MB (705/5202, 13%)
    STAT: fixing VOBU at 149MB (721/5202, 13%)
    STAT: fixing VOBU at 152MB (737/5202, 14%)
    STAT: fixing VOBU at 154MB (753/5202, 14%)
    STAT: fixing VOBU at 157MB (769/5202, 14%)
    STAT: fixing VOBU at 160MB (785/5202, 15%)
    STAT: fixing VOBU at 163MB (801/5202, 15%)
    STAT: fixing VOBU at 166MB (817/5202, 15%)
    STAT: fixing VOBU at 169MB (833/5202, 15%)
    STAT: fixing VOBU at 172MB (849/5202, 16%)
    STAT: fixing VOBU at 175MB (865/5202, 16%)
    STAT: fixing VOBU at 178MB (881/5202, 16%)
    STAT: fixing VOBU at 182MB (897/5202, 17%)
    STAT: fixing VOBU at 186MB (913/5202, 17%)
    STAT: fixing VOBU at 189MB (929/5202, 17%)
    STAT: fixing VOBU at 192MB (945/5202, 18%)
    STAT: fixing VOBU at 196MB (961/5202, 18%)
    STAT: fixing VOBU at 200MB (977/5202, 18%)
    STAT: fixing VOBU at 203MB (993/5202, 19%)
    STAT: fixing VOBU at 207MB (1009/5202, 19%)
    STAT: fixing VOBU at 210MB (1025/5202, 19%)
    STAT: fixing VOBU at 213MB (1041/5202, 19%)
    STAT: fixing VOBU at 215MB (1057/5202, 20%)
    STAT: fixing VOBU at 218MB (1073/5202, 20%)
    STAT: fixing VOBU at 221MB (1089/5202, 20%)
    STAT: fixing VOBU at 224MB (1105/5202, 21%)
    STAT: fixing VOBU at 227MB (1121/5202, 21%)
    STAT: fixing VOBU at 230MB (1137/5202, 21%)
    STAT: fixing VOBU at 234MB (1153/5202, 22%)
    STAT: fixing VOBU at 237MB (1169/5202, 22%)
    STAT: fixing VOBU at 240MB (1185/5202, 22%)
    STAT: fixing VOBU at 244MB (1201/5202, 23%)
    STAT: fixing VOBU at 247MB (1217/5202, 23%)
    STAT: fixing VOBU at 250MB (1233/5202, 23%)
    STAT: fixing VOBU at 253MB (1249/5202, 23%)
    STAT: fixing VOBU at 256MB (1265/5202, 24%)
    STAT: fixing VOBU at 260MB (1281/5202, 24%)
    STAT: fixing VOBU at 263MB (1297/5202, 24%)
    STAT: fixing VOBU at 267MB (1313/5202, 25%)
    STAT: fixing VOBU at 271MB (1329/5202, 25%)
    STAT: fixing VOBU at 274MB (1345/5202, 25%)
    STAT: fixing VOBU at 276MB (1361/5202, 26%)
    STAT: fixing VOBU at 280MB (1377/5202, 26%)
    STAT: fixing VOBU at 282MB (1393/5202, 26%)
    STAT: fixing VOBU at 286MB (1409/5202, 27%)
    STAT: fixing VOBU at 289MB (1425/5202, 27%)
    STAT: fixing VOBU at 292MB (1441/5202, 27%)
    STAT: fixing VOBU at 295MB (1457/5202, 27%)
    STAT: fixing VOBU at 298MB (1473/5202, 28%)
    STAT: fixing VOBU at 301MB (1489/5202, 28%)
    STAT: fixing VOBU at 305MB (1505/5202, 28%)
    STAT: fixing VOBU at 309MB (1521/5202, 29%)
    STAT: fixing VOBU at 313MB (1537/5202, 29%)
    STAT: fixing VOBU at 317MB (1553/5202, 29%)
    STAT: fixing VOBU at 321MB (1569/5202, 30%)
    STAT: fixing VOBU at 325MB (1585/5202, 30%)
    STAT: fixing VOBU at 328MB (1601/5202, 30%)
    STAT: fixing VOBU at 332MB (1617/5202, 31%)
    STAT: fixing VOBU at 335MB (1633/5202, 31%)
    STAT: fixing VOBU at 338MB (1649/5202, 31%)
    STAT: fixing VOBU at 341MB (1665/5202, 31%)
    STAT: fixing VOBU at 344MB (1681/5202, 32%)
    STAT: fixing VOBU at 347MB (1697/5202, 32%)
    STAT: fixing VOBU at 350MB (1713/5202, 32%)
    STAT: fixing VOBU at 353MB (1729/5202, 33%)
    STAT: fixing VOBU at 356MB (1745/5202, 33%)
    STAT: fixing VOBU at 360MB (1761/5202, 33%)
    STAT: fixing VOBU at 363MB (1777/5202, 34%)
    STAT: fixing VOBU at 367MB (1793/5202, 34%)
    STAT: fixing VOBU at 371MB (1809/5202, 34%)
    STAT: fixing VOBU at 374MB (1825/5202, 35%)
    STAT: fixing VOBU at 377MB (1841/5202, 35%)
    STAT: fixing VOBU at 380MB (1857/5202, 35%)
    STAT: fixing VOBU at 383MB (1873/5202, 35%)
    STAT: fixing VOBU at 386MB (1889/5202, 36%)
    STAT: fixing VOBU at 389MB (1905/5202, 36%)
    STAT: fixing VOBU at 392MB (1921/5202, 36%)
    STAT: fixing VOBU at 396MB (1937/5202, 37%)
    STAT: fixing VOBU at 399MB (1953/5202, 37%)
    STAT: fixing VOBU at 401MB (1969/5202, 37%)
    STAT: fixing VOBU at 404MB (1985/5202, 38%)
    STAT: fixing VOBU at 407MB (2001/5202, 38%)
    STAT: fixing VOBU at 409MB (2017/5202, 38%)
    STAT: fixing VOBU at 412MB (2033/5202, 39%)
    STAT: fixing VOBU at 415MB (2049/5202, 39%)
    STAT: fixing VOBU at 418MB (2065/5202, 39%)
    STAT: fixing VOBU at 420MB (2081/5202, 39%)
    STAT: fixing VOBU at 423MB (2097/5202, 40%)
    STAT: fixing VOBU at 426MB (2113/5202, 40%)
    STAT: fixing VOBU at 429MB (2129/5202, 40%)
    STAT: fixing VOBU at 433MB (2145/5202, 41%)
    STAT: fixing VOBU at 436MB (2161/5202, 41%)
    STAT: fixing VOBU at 439MB (2177/5202, 41%)
    STAT: fixing VOBU at 442MB (2193/5202, 42%)
    STAT: fixing VOBU at 446MB (2209/5202, 42%)
    STAT: fixing VOBU at 449MB (2225/5202, 42%)
    STAT: fixing VOBU at 452MB (2241/5202, 43%)
    STAT: fixing VOBU at 456MB (2257/5202, 43%)
    STAT: fixing VOBU at 459MB (2273/5202, 43%)
    STAT: fixing VOBU at 462MB (2289/5202, 43%)
    STAT: fixing VOBU at 465MB (2305/5202, 44%)
    STAT: fixing VOBU at 469MB (2321/5202, 44%)
    STAT: fixing VOBU at 472MB (2337/5202, 44%)
    STAT: fixing VOBU at 476MB (2353/5202, 45%)
    STAT: fixing VOBU at 480MB (2369/5202, 45%)
    STAT: fixing VOBU at 482MB (2385/5202, 45%)
    STAT: fixing VOBU at 485MB (2401/5202, 46%)
    STAT: fixing VOBU at 489MB (2417/5202, 46%)
    STAT: fixing VOBU at 491MB (2433/5202, 46%)
    STAT: fixing VOBU at 494MB (2449/5202, 47%)
    STAT: fixing VOBU at 497MB (2465/5202, 47%)
    STAT: fixing VOBU at 499MB (2481/5202, 47%)
    STAT: fixing VOBU at 502MB (2497/5202, 47%)
    STAT: fixing VOBU at 505MB (2513/5202, 48%)
    STAT: fixing VOBU at 508MB (2529/5202, 48%)
    STAT: fixing VOBU at 510MB (2545/5202, 48%)
    STAT: fixing VOBU at 513MB (2561/5202, 49%)
    STAT: fixing VOBU at 516MB (2577/5202, 49%)
    STAT: fixing VOBU at 519MB (2593/5202, 49%)
    STAT: fixing VOBU at 521MB (2609/5202, 50%)
    STAT: fixing VOBU at 524MB (2625/5202, 50%)
    STAT: fixing VOBU at 526MB (2641/5202, 50%)
    STAT: fixing VOBU at 529MB (2657/5202, 51%)
    STAT: fixing VOBU at 531MB (2673/5202, 51%)
    STAT: fixing VOBU at 534MB (2689/5202, 51%)
    STAT: fixing VOBU at 537MB (2705/5202, 51%)
    STAT: fixing VOBU at 540MB (2721/5202, 52%)
    STAT: fixing VOBU at 543MB (2737/5202, 52%)
    STAT: fixing VOBU at 546MB (2753/5202, 52%)
    STAT: fixing VOBU at 549MB (2769/5202, 53%)
    STAT: fixing VOBU at 552MB (2785/5202, 53%)
    STAT: fixing VOBU at 555MB (2801/5202, 53%)
    STAT: fixing VOBU at 557MB (2817/5202, 54%)
    STAT: fixing VOBU at 560MB (2833/5202, 54%)
    STAT: fixing VOBU at 563MB (2849/5202, 54%)
    STAT: fixing VOBU at 566MB (2865/5202, 55%)
    STAT: fixing VOBU at 568MB (2881/5202, 55%)
    STAT: fixing VOBU at 571MB (2897/5202, 55%)
    STAT: fixing VOBU at 574MB (2913/5202, 55%)
    STAT: fixing VOBU at 577MB (2929/5202, 56%)
    STAT: fixing VOBU at 580MB (2945/5202, 56%)
    STAT: fixing VOBU at 582MB (2961/5202, 56%)
    STAT: fixing VOBU at 585MB (2977/5202, 57%)
    STAT: fixing VOBU at 587MB (2993/5202, 57%)
    STAT: fixing VOBU at 590MB (3009/5202, 57%)
    STAT: fixing VOBU at 594MB (3025/5202, 58%)
    STAT: fixing VOBU at 599MB (3041/5202, 58%)
    STAT: fixing VOBU at 603MB (3057/5202, 58%)
    STAT: fixing VOBU at 607MB (3073/5202, 59%)
    STAT: fixing VOBU at 611MB (3089/5202, 59%)
    STAT: fixing VOBU at 614MB (3105/5202, 59%)
    STAT: fixing VOBU at 617MB (3121/5202, 59%)
    STAT: fixing VOBU at 620MB (3137/5202, 60%)
    STAT: fixing VOBU at 623MB (3153/5202, 60%)
    STAT: fixing VOBU at 626MB (3169/5202, 60%)
    STAT: fixing VOBU at 629MB (3185/5202, 61%)
    STAT: fixing VOBU at 632MB (3201/5202, 61%)
    STAT: fixing VOBU at 634MB (3217/5202, 61%)
    STAT: fixing VOBU at 637MB (3233/5202, 62%)
    STAT: fixing VOBU at 641MB (3249/5202, 62%)
    STAT: fixing VOBU at 643MB (3265/5202, 62%)
    STAT: fixing VOBU at 646MB (3281/5202, 63%)
    STAT: fixing VOBU at 648MB (3297/5202, 63%)
    STAT: fixing VOBU at 651MB (3313/5202, 63%)
    STAT: fixing VOBU at 654MB (3329/5202, 63%)
    STAT: fixing VOBU at 657MB (3345/5202, 64%)
    STAT: fixing VOBU at 660MB (3361/5202, 64%)
    STAT: fixing VOBU at 662MB (3377/5202, 64%)
    STAT: fixing VOBU at 665MB (3393/5202, 65%)
    STAT: fixing VOBU at 668MB (3409/5202, 65%)
    STAT: fixing VOBU at 670MB (3425/5202, 65%)
    STAT: fixing VOBU at 673MB (3441/5202, 66%)
    STAT: fixing VOBU at 676MB (3457/5202, 66%)
    STAT: fixing VOBU at 679MB (3473/5202, 66%)
    STAT: fixing VOBU at 683MB (3489/5202, 67%)
    STAT: fixing VOBU at 687MB (3505/5202, 67%)
    STAT: fixing VOBU at 690MB (3521/5202, 67%)
    STAT: fixing VOBU at 693MB (3537/5202, 67%)
    STAT: fixing VOBU at 697MB (3553/5202, 68%)
    STAT: fixing VOBU at 700MB (3569/5202, 68%)
    STAT: fixing VOBU at 704MB (3585/5202, 68%)
    STAT: fixing VOBU at 707MB (3601/5202, 69%)
    STAT: fixing VOBU at 710MB (3617/5202, 69%)
    STAT: fixing VOBU at 714MB (3633/5202, 69%)
    STAT: fixing VOBU at 717MB (3649/5202, 70%)
    STAT: fixing VOBU at 720MB (3665/5202, 70%)
    STAT: fixing VOBU at 724MB (3681/5202, 70%)
    STAT: fixing VOBU at 728MB (3697/5202, 71%)
    STAT: fixing VOBU at 731MB (3713/5202, 71%)
    STAT: fixing VOBU at 733MB (3729/5202, 71%)
    STAT: fixing VOBU at 736MB (3745/5202, 71%)
    STAT: fixing VOBU at 739MB (3761/5202, 72%)
    STAT: fixing VOBU at 741MB (3777/5202, 72%)
    STAT: fixing VOBU at 744MB (3793/5202, 72%)
    STAT: fixing VOBU at 747MB (3809/5202, 73%)
    STAT: fixing VOBU at 750MB (3825/5202, 73%)
    STAT: fixing VOBU at 753MB (3841/5202, 73%)
    STAT: fixing VOBU at 755MB (3857/5202, 74%)
    STAT: fixing VOBU at 758MB (3873/5202, 74%)
    STAT: fixing VOBU at 761MB (3889/5202, 74%)
    STAT: fixing VOBU at 764MB (3905/5202, 75%)
    STAT: fixing VOBU at 767MB (3921/5202, 75%)
    STAT: fixing VOBU at 771MB (3937/5202, 75%)
    STAT: fixing VOBU at 775MB (3953/5202, 75%)
    STAT: fixing VOBU at 778MB (3969/5202, 76%)
    STAT: fixing VOBU at 782MB (3985/5202, 76%)
    STAT: fixing VOBU at 785MB (4001/5202, 76%)
    STAT: fixing VOBU at 789MB (4017/5202, 77%)
    STAT: fixing VOBU at 792MB (4033/5202, 77%)
    STAT: fixing VOBU at 795MB (4049/5202, 77%)
    STAT: fixing VOBU at 799MB (4065/5202, 78%)
    STAT: fixing VOBU at 802MB (4081/5202, 78%)
    STAT: fixing VOBU at 805MB (4097/5202, 78%)
    STAT: fixing VOBU at 808MB (4113/5202, 79%)
    STAT: fixing VOBU at 811MB (4129/5202, 79%)
    STAT: fixing VOBU at 814MB (4145/5202, 79%)
    STAT: fixing VOBU at 817MB (4161/5202, 79%)
    STAT: fixing VOBU at 821MB (4177/5202, 80%)
    STAT: fixing VOBU at 824MB (4193/5202, 80%)
    STAT: fixing VOBU at 827MB (4209/5202, 80%)
    STAT: fixing VOBU at 830MB (4225/5202, 81%)
    STAT: fixing VOBU at 834MB (4241/5202, 81%)
    STAT: fixing VOBU at 837MB (4257/5202, 81%)
    STAT: fixing VOBU at 840MB (4273/5202, 82%)
    STAT: fixing VOBU at 843MB (4289/5202, 82%)
    STAT: fixing VOBU at 846MB (4305/5202, 82%)
    STAT: fixing VOBU at 850MB (4321/5202, 83%)
    STAT: fixing VOBU at 853MB (4337/5202, 83%)
    STAT: fixing VOBU at 855MB (4353/5202, 83%)
    STAT: fixing VOBU at 858MB (4369/5202, 83%)
    STAT: fixing VOBU at 861MB (4385/5202, 84%)
    STAT: fixing VOBU at 864MB (4401/5202, 84%)
    STAT: fixing VOBU at 867MB (4417/5202, 84%)
    STAT: fixing VOBU at 871MB (4433/5202, 85%)
    STAT: fixing VOBU at 874MB (4449/5202, 85%)
    STAT: fixing VOBU at 877MB (4465/5202, 85%)
    STAT: fixing VOBU at 881MB (4481/5202, 86%)
    STAT: fixing VOBU at 884MB (4497/5202, 86%)
    STAT: fixing VOBU at 888MB (4513/5202, 86%)
    STAT: fixing VOBU at 892MB (4529/5202, 87%)
    STAT: fixing VOBU at 896MB (4545/5202, 87%)
    STAT: fixing VOBU at 899MB (4561/5202, 87%)
    STAT: fixing VOBU at 902MB (4577/5202, 87%)
    STAT: fixing VOBU at 905MB (4593/5202, 88%)
    STAT: fixing VOBU at 908MB (4609/5202, 88%)
    STAT: fixing VOBU at 911MB (4625/5202, 88%)
    STAT: fixing VOBU at 915MB (4641/5202, 89%)
    STAT: fixing VOBU at 918MB (4657/5202, 89%)
    STAT: fixing VOBU at 922MB (4673/5202, 89%)
    STAT: fixing VOBU at 925MB (4689/5202, 90%)
    STAT: fixing VOBU at 929MB (4705/5202, 90%)
    STAT: fixing VOBU at 933MB (4721/5202, 90%)
    STAT: fixing VOBU at 937MB (4737/5202, 91%)
    STAT: fixing VOBU at 940MB (4753/5202, 91%)
    STAT: fixing VOBU at 944MB (4769/5202, 91%)
    STAT: fixing VOBU at 947MB (4785/5202, 91%)
    STAT: fixing VOBU at 951MB (4801/5202, 92%)
    STAT: fixing VOBU at 954MB (4817/5202, 92%)
    STAT: fixing VOBU at 957MB (4833/5202, 92%)
    STAT: fixing VOBU at 960MB (4849/5202, 93%)
    STAT: fixing VOBU at 963MB (4865/5202, 93%)
    STAT: fixing VOBU at 966MB (4881/5202, 93%)
    STAT: fixing VOBU at 969MB (4897/5202, 94%)
    STAT: fixing VOBU at 973MB (4913/5202, 94%)
    STAT: fixing VOBU at 975MB (4929/5202, 94%)
    STAT: fixing VOBU at 979MB (4945/5202, 95%)
    STAT: fixing VOBU at 983MB (4961/5202, 95%)
    STAT: fixing VOBU at 986MB (4977/5202, 95%)
    STAT: fixing VOBU at 988MB (4993/5202, 95%)
    STAT: fixing VOBU at 991MB (5009/5202, 96%)
    STAT: fixing VOBU at 994MB (5025/5202, 96%)
    STAT: fixing VOBU at 997MB (5041/5202, 96%)
    STAT: fixing VOBU at 1000MB (5057/5202, 97%)
    STAT: fixing VOBU at 1003MB (5073/5202, 97%)
    STAT: fixing VOBU at 1005MB (5089/5202, 97%)
    STAT: fixing VOBU at 1008MB (5105/5202, 98%)
    STAT: fixing VOBU at 1011MB (5121/5202, 98%)
    STAT: fixing VOBU at 1014MB (5137/5202, 98%)
    STAT: fixing VOBU at 1017MB (5153/5202, 99%)
    STAT: fixing VOBU at 1021MB (5169/5202, 99%)
    STAT: fixing VOBU at 1025MB (5185/5202, 99%)
    STAT: fixing VOBU at 1028MB (5201/5202, 99%)
    STAT: fixed 5202 VOBUS
    STAT: Picking VTS 02
    STAT: Processing C:\Users\Chris\Documents\GFDOutDir\Temp\TS2Menu.mp g...
    STAT: Processing e:\Gilmore Girls\Staffel 1\Episode 2\DVD\VTS_01_1.VOB...
    STAT: VOBU 16 at 2MB, 1 PGCS
    STAT: VOBU 48 at 8MB, 1 PGCS
    STAT: VOBU 64 at 11MB, 1 PGCS
    STAT: VOBU 80 at 15MB, 1 PGCS
    STAT: VOBU 96 at 18MB, 1 PGCS
    STAT: VOBU 112 at 22MB, 1 PGCS
    STAT: VOBU 128 at 25MB, 1 PGCS
    STAT: VOBU 144 at 29MB, 1 PGCS
    STAT: VOBU 160 at 32MB, 1 PGCS
    STAT: VOBU 176 at 36MB, 1 PGCS
    STAT: VOBU 192 at 40MB, 1 PGCS
    STAT: VOBU 208 at 44MB, 1 PGCS
    STAT: VOBU 224 at 48MB, 1 PGCS
    STAT: VOBU 240 at 51MB, 1 PGCS
    STAT: VOBU 256 at 55MB, 1 PGCS
    STAT: VOBU 272 at 59MB, 1 PGCS
    STAT: VOBU 288 at 62MB, 1 PGCS
    STAT: VOBU 304 at 65MB, 1 PGCS
    STAT: VOBU 320 at 68MB, 1 PGCS
    STAT: VOBU 336 at 71MB, 1 PGCS
    STAT: VOBU 352 at 74MB, 1 PGCS
    STAT: VOBU 368 at 77MB, 1 PGCS
    STAT: VOBU 384 at 81MB, 1 PGCS
    STAT: VOBU 400 at 84MB, 1 PGCS
    STAT: VOBU 416 at 87MB, 1 PGCS
    STAT: VOBU 432 at 91MB, 1 PGCS
    STAT: VOBU 448 at 94MB, 1 PGCS
    STAT: VOBU 464 at 97MB, 1 PGCS
    STAT: VOBU 480 at 99MB, 1 PGCS
    STAT: VOBU 496 at 102MB, 1 PGCS
    STAT: VOBU 512 at 104MB, 1 PGCS
    STAT: VOBU 528 at 107MB, 1 PGCS
    STAT: VOBU 544 at 110MB, 1 PGCS
    STAT: VOBU 560 at 112MB, 1 PGCS
    STAT: VOBU 576 at 115MB, 1 PGCS
    STAT: VOBU 592 at 118MB, 1 PGCS
    STAT: VOBU 608 at 122MB, 1 PGCS
    STAT: VOBU 624 at 125MB, 1 PGCS
    STAT: VOBU 640 at 129MB, 1 PGCS
    STAT: VOBU 656 at 132MB, 1 PGCS
    STAT: VOBU 672 at 135MB, 1 PGCS
    STAT: VOBU 688 at 137MB, 1 PGCS
    STAT: VOBU 704 at 141MB, 1 PGCS
    STAT: VOBU 720 at 143MB, 1 PGCS
    STAT: VOBU 736 at 146MB, 1 PGCS
    STAT: VOBU 752 at 149MB, 1 PGCS
    STAT: VOBU 768 at 153MB, 1 PGCS
    STAT: VOBU 784 at 156MB, 1 PGCS
    STAT: VOBU 800 at 158MB, 1 PGCS
    STAT: VOBU 816 at 161MB, 1 PGCS
    STAT: VOBU 832 at 163MB, 1 PGCS
    STAT: VOBU 848 at 166MB, 1 PGCS
    STAT: VOBU 864 at 169MB, 1 PGCS
    STAT: VOBU 880 at 172MB, 1 PGCS
    STAT: VOBU 896 at 174MB, 1 PGCS
    STAT: VOBU 912 at 177MB, 1 PGCS
    STAT: VOBU 928 at 179MB, 1 PGCS
    STAT: VOBU 944 at 183MB, 1 PGCS
    STAT: VOBU 960 at 186MB, 1 PGCS
    STAT: VOBU 976 at 189MB, 1 PGCS
    STAT: VOBU 992 at 192MB, 1 PGCS
    STAT: VOBU 1008 at 195MB, 1 PGCS
    STAT: VOBU 1024 at 198MB, 1 PGCS
    STAT: VOBU 1040 at 200MB, 1 PGCS
    STAT: VOBU 1056 at 203MB, 1 PGCS
    STAT: VOBU 1072 at 206MB, 1 PGCS
    STAT: VOBU 1088 at 208MB, 1 PGCS
    STAT: VOBU 1104 at 211MB, 1 PGCS
    STAT: VOBU 1120 at 214MB, 1 PGCS
    STAT: VOBU 1136 at 216MB, 1 PGCS
    STAT: VOBU 1152 at 219MB, 1 PGCS
    STAT: VOBU 1168 at 222MB, 1 PGCS
    STAT: VOBU 1184 at 224MB, 1 PGCS
    STAT: VOBU 1200 at 227MB, 1 PGCS
    STAT: VOBU 1216 at 230MB, 1 PGCS
    STAT: VOBU 1232 at 232MB, 1 PGCS
    STAT: VOBU 1248 at 235MB, 1 PGCS
    STAT: VOBU 1264 at 237MB, 1 PGCS
    STAT: VOBU 1280 at 240MB, 1 PGCS
    STAT: VOBU 1296 at 243MB, 1 PGCS
    STAT: VOBU 1312 at 246MB, 1 PGCS
    STAT: VOBU 1328 at 250MB, 1 PGCS
    STAT: VOBU 1344 at 253MB, 1 PGCS
    STAT: VOBU 1360 at 256MB, 1 PGCS
    STAT: VOBU 1376 at 259MB, 1 PGCS
    STAT: VOBU 1392 at 262MB, 1 PGCS
    STAT: VOBU 1408 at 264MB, 1 PGCS
    STAT: VOBU 1424 at 267MB, 1 PGCS
    STAT: VOBU 1440 at 270MB, 1 PGCS
    STAT: VOBU 1456 at 273MB, 1 PGCS
    STAT: VOBU 1472 at 276MB, 1 PGCS
    STAT: VOBU 1488 at 279MB, 1 PGCS
    STAT: VOBU 1504 at 282MB, 1 PGCS
    STAT: VOBU 1520 at 284MB, 1 PGCS
    STAT: VOBU 1536 at 287MB, 1 PGCS
    STAT: VOBU 1552 at 290MB, 1 PGCS
    STAT: VOBU 1568 at 293MB, 1 PGCS
    STAT: VOBU 1584 at 296MB, 1 PGCS
    STAT: VOBU 1600 at 300MB, 1 PGCS
    STAT: VOBU 1616 at 303MB, 1 PGCS
    STAT: VOBU 1632 at 306MB, 1 PGCS
    STAT: VOBU 1648 at 309MB, 1 PGCS
    STAT: VOBU 1664 at 312MB, 1 PGCS
    STAT: VOBU 1680 at 316MB, 1 PGCS
    STAT: VOBU 1696 at 320MB, 1 PGCS
    STAT: VOBU 1712 at 323MB, 1 PGCS
    STAT: VOBU 1728 at 326MB, 1 PGCS
    STAT: VOBU 1744 at 329MB, 1 PGCS
    STAT: VOBU 1760 at 332MB, 1 PGCS
    STAT: VOBU 1776 at 334MB, 1 PGCS
    STAT: VOBU 1792 at 337MB, 1 PGCS
    STAT: VOBU 1808 at 340MB, 1 PGCS
    STAT: VOBU 1824 at 343MB, 1 PGCS
    STAT: VOBU 1840 at 346MB, 1 PGCS
    STAT: VOBU 1856 at 349MB, 1 PGCS
    STAT: VOBU 1872 at 352MB, 1 PGCS
    STAT: VOBU 1888 at 355MB, 1 PGCS
    STAT: VOBU 1904 at 357MB, 1 PGCS
    STAT: VOBU 1920 at 360MB, 1 PGCS
    STAT: VOBU 1936 at 364MB, 1 PGCS
    STAT: VOBU 1952 at 367MB, 1 PGCS
    STAT: VOBU 1968 at 370MB, 1 PGCS
    STAT: VOBU 1984 at 373MB, 1 PGCS
    STAT: VOBU 2000 at 377MB, 1 PGCS
    STAT: VOBU 2016 at 380MB, 1 PGCS
    STAT: VOBU 2032 at 383MB, 1 PGCS
    STAT: VOBU 2048 at 386MB, 1 PGCS
    STAT: VOBU 2064 at 389MB, 1 PGCS
    STAT: VOBU 2080 at 392MB, 1 PGCS
    STAT: VOBU 2096 at 395MB, 1 PGCS
    STAT: VOBU 2112 at 398MB, 1 PGCS
    STAT: VOBU 2128 at 401MB, 1 PGCS
    STAT: VOBU 2144 at 404MB, 1 PGCS
    STAT: VOBU 2160 at 408MB, 1 PGCS
    STAT: VOBU 2176 at 411MB, 1 PGCS
    STAT: VOBU 2192 at 413MB, 1 PGCS
    STAT: VOBU 2208 at 416MB, 1 PGCS
    STAT: VOBU 2224 at 419MB, 1 PGCS
    STAT: VOBU 2240 at 422MB, 1 PGCS
    STAT: VOBU 2256 at 425MB, 1 PGCS
    STAT: VOBU 2272 at 428MB, 1 PGCS
    STAT: VOBU 2288 at 431MB, 1 PGCS
    STAT: VOBU 2304 at 434MB, 1 PGCS
    STAT: VOBU 2320 at 436MB, 1 PGCS
    STAT: VOBU 2336 at 438MB, 1 PGCS
    STAT: VOBU 2352 at 441MB, 1 PGCS
    STAT: VOBU 2368 at 444MB, 1 PGCS
    STAT: VOBU 2384 at 447MB, 1 PGCS
    STAT: VOBU 2400 at 450MB, 1 PGCS
    STAT: VOBU 2416 at 454MB, 1 PGCS
    STAT: VOBU 2432 at 457MB, 1 PGCS
    STAT: VOBU 2448 at 460MB, 1 PGCS
    STAT: VOBU 2464 at 463MB, 1 PGCS
    STAT: VOBU 2480 at 466MB, 1 PGCS
    STAT: VOBU 2496 at 468MB, 1 PGCS
    STAT: VOBU 2512 at 471MB, 1 PGCS
    STAT: VOBU 2528 at 474MB, 1 PGCS
    STAT: VOBU 2544 at 477MB, 1 PGCS
    STAT: VOBU 2560 at 480MB, 1 PGCS
    STAT: VOBU 2576 at 482MB, 1 PGCS
    STAT: VOBU 2592 at 485MB, 1 PGCS
    STAT: VOBU 2608 at 488MB, 1 PGCS
    STAT: VOBU 2624 at 490MB, 1 PGCS
    STAT: VOBU 2640 at 493MB, 1 PGCS
    STAT: VOBU 2656 at 496MB, 1 PGCS
    STAT: VOBU 2672 at 500MB, 1 PGCS
    STAT: VOBU 2688 at 503MB, 1 PGCS
    STAT: VOBU 2704 at 506MB, 1 PGCS
    STAT: VOBU 2720 at 509MB, 1 PGCS
    STAT: VOBU 2736 at 513MB, 1 PGCS
    STAT: VOBU 2752 at 517MB, 1 PGCS
    STAT: VOBU 2768 at 520MB, 1 PGCS
    STAT: VOBU 2784 at 523MB, 1 PGCS
    STAT: VOBU 2800 at 526MB, 1 PGCS
    STAT: VOBU 2816 at 530MB, 1 PGCS
    STAT: VOBU 2832 at 533MB, 1 PGCS
    STAT: VOBU 2848 at 536MB, 1 PGCS
    STAT: VOBU 2864 at 540MB, 1 PGCS
    STAT: VOBU 2880 at 543MB, 1 PGCS
    STAT: VOBU 2896 at 545MB, 1 PGCS
    STAT: VOBU 2912 at 549MB, 1 PGCS
    STAT: VOBU 2928 at 552MB, 1 PGCS
    STAT: VOBU 2944 at 555MB, 1 PGCS
    STAT: VOBU 2960 at 557MB, 1 PGCS
    STAT: VOBU 2976 at 560MB, 1 PGCS
    STAT: VOBU 2992 at 564MB, 1 PGCS
    STAT: VOBU 3008 at 568MB, 1 PGCS
    STAT: VOBU 3024 at 571MB, 1 PGCS
    STAT: VOBU 3040 at 575MB, 1 PGCS
    STAT: VOBU 3056 at 579MB, 1 PGCS
    STAT: VOBU 3072 at 581MB, 1 PGCS
    STAT: VOBU 3088 at 584MB, 1 PGCS
    STAT: VOBU 3104 at 587MB, 1 PGCS
    STAT: VOBU 3120 at 590MB, 1 PGCS
    STAT: VOBU 3136 at 593MB, 1 PGCS
    STAT: VOBU 3152 at 596MB, 1 PGCS
    STAT: VOBU 3168 at 600MB, 1 PGCS
    STAT: VOBU 3184 at 604MB, 1 PGCS
    STAT: VOBU 3200 at 607MB, 1 PGCS
    STAT: VOBU 3216 at 610MB, 1 PGCS
    STAT: VOBU 3232 at 613MB, 1 PGCS
    STAT: VOBU 3248 at 616MB, 1 PGCS
    STAT: VOBU 3264 at 619MB, 1 PGCS
    STAT: VOBU 3280 at 622MB, 1 PGCS
    STAT: VOBU 3296 at 625MB, 1 PGCS
    STAT: VOBU 3312 at 628MB, 1 PGCS
    STAT: VOBU 3328 at 631MB, 1 PGCS
    STAT: VOBU 3344 at 635MB, 1 PGCS
    STAT: VOBU 3360 at 637MB, 1 PGCS
    STAT: VOBU 3376 at 641MB, 1 PGCS
    STAT: VOBU 3392 at 643MB, 1 PGCS
    STAT: VOBU 3408 at 646MB, 1 PGCS
    STAT: VOBU 3424 at 650MB, 1 PGCS
    STAT: VOBU 3440 at 653MB, 1 PGCS
    STAT: VOBU 3456 at 656MB, 1 PGCS
    STAT: VOBU 3472 at 659MB, 1 PGCS
    STAT: VOBU 3488 at 662MB, 1 PGCS
    STAT: VOBU 3504 at 664MB, 1 PGCS
    STAT: VOBU 3520 at 667MB, 1 PGCS
    STAT: VOBU 3536 at 670MB, 1 PGCS
    STAT: VOBU 3552 at 673MB, 1 PGCS
    STAT: VOBU 3568 at 676MB, 1 PGCS
    STAT: VOBU 3584 at 679MB, 1 PGCS
    STAT: VOBU 3600 at 682MB, 1 PGCS
    STAT: VOBU 3616 at 685MB, 1 PGCS
    STAT: VOBU 3632 at 688MB, 1 PGCS
    STAT: VOBU 3648 at 691MB, 1 PGCS
    STAT: VOBU 3664 at 694MB, 1 PGCS
    STAT: VOBU 3680 at 698MB, 1 PGCS
    STAT: VOBU 3696 at 701MB, 1 PGCS
    STAT: VOBU 3712 at 704MB, 1 PGCS
    STAT: VOBU 3728 at 707MB, 1 PGCS
    STAT: VOBU 3744 at 709MB, 1 PGCS
    STAT: VOBU 3760 at 712MB, 1 PGCS
    STAT: VOBU 3776 at 716MB, 1 PGCS
    STAT: VOBU 3792 at 719MB, 1 PGCS
    STAT: VOBU 3808 at 722MB, 1 PGCS
    STAT: VOBU 3824 at 725MB, 1 PGCS
    STAT: VOBU 3840 at 728MB, 1 PGCS
    STAT: VOBU 3856 at 732MB, 1 PGCS
    STAT: VOBU 3872 at 735MB, 1 PGCS
    STAT: VOBU 3888 at 739MB, 1 PGCS
    STAT: VOBU 3904 at 742MB, 1 PGCS
    STAT: VOBU 3920 at 746MB, 1 PGCS
    STAT: VOBU 3936 at 749MB, 1 PGCS
    STAT: VOBU 3952 at 752MB, 1 PGCS
    STAT: VOBU 3968 at 756MB, 1 PGCS
    STAT: VOBU 3984 at 759MB, 1 PGCS
    STAT: VOBU 4000 at 762MB, 1 PGCS
    INFO: Video pts = 0.280 .. 1873.720
    INFO: Audio[8] pts = 0.280 .. 1873.720
    STAT: VOBU 4002 at 763MB, 1 PGCS
    STAT: fixed 1 VOBUS
    STAT: fixing VOBU at 2MB (17/4002, 0%)
    STAT: fixing VOBU at 5MB (33/4002, 0%)
    STAT: fixing VOBU at 8MB (49/4002, 1%)
    STAT: fixing VOBU at 11MB (65/4002, 1%)
    STAT: fixing VOBU at 15MB (81/4002, 1%)
    STAT: fixing VOBU at 18MB (97/4002, 2%)
    STAT: fixing VOBU at 22MB (113/4002, 2%)
    STAT: fixing VOBU at 25MB (129/4002, 3%)
    STAT: fixing VOBU at 29MB (145/4002, 3%)
    STAT: fixing VOBU at 32MB (161/4002, 3%)
    STAT: fixing VOBU at 36MB (177/4002, 4%)
    STAT: fixing VOBU at 40MB (193/4002, 4%)
    STAT: fixing VOBU at 44MB (209/4002, 5%)
    STAT: fixing VOBU at 48MB (225/4002, 5%)
    STAT: fixing VOBU at 51MB (241/4002, 5%)
    STAT: fixing VOBU at 55MB (257/4002, 6%)
    STAT: fixing VOBU at 59MB (273/4002, 6%)
    STAT: fixing VOBU at 62MB (289/4002, 7%)
    STAT: fixing VOBU at 65MB (305/4002, 7%)
    STAT: fixing VOBU at 68MB (321/4002, 7%)
    STAT: fixing VOBU at 71MB (337/4002, 8%)
    STAT: fixing VOBU at 74MB (353/4002, 8%)
    STAT: fixing VOBU at 77MB (369/4002, 9%)
    STAT: fixing VOBU at 81MB (385/4002, 9%)
    STAT: fixing VOBU at 84MB (401/4002, 9%)
    STAT: fixing VOBU at 87MB (417/4002, 10%)
    STAT: fixing VOBU at 91MB (433/4002, 10%)
    STAT: fixing VOBU at 94MB (449/4002, 11%)
    STAT: fixing VOBU at 97MB (465/4002, 11%)
    STAT: fixing VOBU at 99MB (481/4002, 11%)
    STAT: fixing VOBU at 102MB (497/4002, 12%)
    STAT: fixing VOBU at 104MB (513/4002, 12%)
    STAT: fixing VOBU at 107MB (529/4002, 13%)
    STAT: fixing VOBU at 110MB (545/4002, 13%)
    STAT: fixing VOBU at 112MB (561/4002, 13%)
    STAT: fixing VOBU at 115MB (577/4002, 14%)
    STAT: fixing VOBU at 118MB (593/4002, 14%)
    STAT: fixing VOBU at 122MB (609/4002, 15%)
    STAT: fixing VOBU at 125MB (625/4002, 15%)
    STAT: fixing VOBU at 129MB (641/4002, 15%)
    STAT: fixing VOBU at 132MB (657/4002, 16%)
    STAT: fixing VOBU at 135MB (673/4002, 16%)
    STAT: fixing VOBU at 137MB (689/4002, 17%)
    STAT: fixing VOBU at 141MB (705/4002, 17%)
    STAT: fixing VOBU at 143MB (721/4002, 17%)
    STAT: fixing VOBU at 146MB (737/4002, 18%)
    STAT: fixing VOBU at 149MB (753/4002, 18%)
    STAT: fixing VOBU at 153MB (769/4002, 19%)
    STAT: fixing VOBU at 156MB (785/4002, 19%)
    STAT: fixing VOBU at 158MB (801/4002, 19%)
    STAT: fixing VOBU at 161MB (817/4002, 20%)
    STAT: fixing VOBU at 163MB (833/4002, 20%)
    STAT: fixing VOBU at 166MB (849/4002, 21%)
    STAT: fixing VOBU at 169MB (865/4002, 21%)
    STAT: fixing VOBU at 172MB (881/4002, 21%)
    STAT: fixing VOBU at 174MB (897/4002, 22%)
    STAT: fixing VOBU at 177MB (913/4002, 22%)
    STAT: fixing VOBU at 179MB (929/4002, 23%)
    STAT: fixing VOBU at 183MB (945/4002, 23%)
    STAT: fixing VOBU at 186MB (961/4002, 23%)
    STAT: fixing VOBU at 189MB (977/4002, 24%)
    STAT: fixing VOBU at 192MB (993/4002, 24%)
    STAT: fixing VOBU at 195MB (1009/4002, 25%)
    STAT: fixing VOBU at 198MB (1025/4002, 25%)
    STAT: fixing VOBU at 200MB (1041/4002, 25%)
    STAT: fixing VOBU at 203MB (1057/4002, 26%)
    STAT: fixing VOBU at 206MB (1073/4002, 26%)
    STAT: fixing VOBU at 208MB (1089/4002, 27%)
    STAT: fixing VOBU at 211MB (1105/4002, 27%)
    STAT: fixing VOBU at 214MB (1121/4002, 27%)
    STAT: fixing VOBU at 216MB (1137/4002, 28%)
    STAT: fixing VOBU at 219MB (1153/4002, 28%)
    STAT: fixing VOBU at 222MB (1169/4002, 29%)
    STAT: fixing VOBU at 224MB (1185/4002, 29%)
    STAT: fixing VOBU at 227MB (1201/4002, 29%)
    STAT: fixing VOBU at 230MB (1217/4002, 30%)
    STAT: fixing VOBU at 232MB (1233/4002, 30%)
    STAT: fixing VOBU at 235MB (1249/4002, 31%)
    STAT: fixing VOBU at 237MB (1265/4002, 31%)
    STAT: fixing VOBU at 240MB (1281/4002, 31%)
    STAT: fixing VOBU at 243MB (1297/4002, 32%)
    STAT: fixing VOBU at 246MB (1313/4002, 32%)
    STAT: fixing VOBU at 250MB (1329/4002, 33%)
    STAT: fixing VOBU at 253MB (1345/4002, 33%)
    STAT: fixing VOBU at 256MB (1361/4002, 33%)
    STAT: fixing VOBU at 259MB (1377/4002, 34%)
    STAT: fixing VOBU at 262MB (1393/4002, 34%)
    STAT: fixing VOBU at 264MB (1409/4002, 35%)
    STAT: fixing VOBU at 267MB (1425/4002, 35%)
    STAT: fixing VOBU at 270MB (1441/4002, 35%)
    STAT: fixing VOBU at 273MB (1457/4002, 36%)
    STAT: fixing VOBU at 276MB (1473/4002, 36%)
    STAT: fixing VOBU at 279MB (1489/4002, 37%)
    STAT: fixing VOBU at 282MB (1505/4002, 37%)
    STAT: fixing VOBU at 284MB (1521/4002, 37%)
    STAT: fixing VOBU at 287MB (1537/4002, 38%)
    STAT: fixing VOBU at 290MB (1553/4002, 38%)
    STAT: fixing VOBU at 293MB (1569/4002, 39%)
    STAT: fixing VOBU at 296MB (1585/4002, 39%)
    STAT: fixing VOBU at 300MB (1601/4002, 39%)
    STAT: fixing VOBU at 303MB (1617/4002, 40%)
    STAT: fixing VOBU at 306MB (1633/4002, 40%)
    STAT: fixing VOBU at 309MB (1649/4002, 41%)
    STAT: fixing VOBU at 312MB (1665/4002, 41%)
    STAT: fixing VOBU at 316MB (1681/4002, 41%)
    STAT: fixing VOBU at 320MB (1697/4002, 42%)
    STAT: fixing VOBU at 323MB (1713/4002, 42%)
    STAT: fixing VOBU at 326MB (1729/4002, 43%)
    STAT: fixing VOBU at 329MB (1745/4002, 43%)
    STAT: fixing VOBU at 332MB (1761/4002, 43%)
    STAT: fixing VOBU at 334MB (1777/4002, 44%)
    STAT: fixing VOBU at 337MB (1793/4002, 44%)
    STAT: fixing VOBU at 340MB (1809/4002, 45%)
    STAT: fixing VOBU at 343MB (1825/4002, 45%)
    STAT: fixing VOBU at 346MB (1841/4002, 45%)
    STAT: fixing VOBU at 349MB (1857/4002, 46%)
    STAT: fixing VOBU at 352MB (1873/4002, 46%)
    STAT: fixing VOBU at 355MB (1889/4002, 47%)
    STAT: fixing VOBU at 357MB (1905/4002, 47%)
    STAT: fixing VOBU at 360MB (1921/4002, 47%)
    STAT: fixing VOBU at 364MB (1937/4002, 48%)
    STAT: fixing VOBU at 367MB (1953/4002, 48%)
    STAT: fixing VOBU at 370MB (1969/4002, 49%)
    STAT: fixing VOBU at 373MB (1985/4002, 49%)
    STAT: fixing VOBU at 377MB (2001/4002, 49%)
    STAT: fixing VOBU at 380MB (2017/4002, 50%)
    STAT: fixing VOBU at 383MB (2033/4002, 50%)
    STAT: fixing VOBU at 386MB (2049/4002, 51%)
    STAT: fixing VOBU at 389MB (2065/4002, 51%)
    STAT: fixing VOBU at 392MB (2081/4002, 51%)
    STAT: fixing VOBU at 395MB (2097/4002, 52%)
    STAT: fixing VOBU at 398MB (2113/4002, 52%)
    STAT: fixing VOBU at 401MB (2129/4002, 53%)
    STAT: fixing VOBU at 404MB (2145/4002, 53%)
    STAT: fixing VOBU at 408MB (2161/4002, 53%)
    STAT: fixing VOBU at 411MB (2177/4002, 54%)
    STAT: fixing VOBU at 413MB (2193/4002, 54%)
    STAT: fixing VOBU at 416MB (2209/4002, 55%)
    STAT: fixing VOBU at 419MB (2225/4002, 55%)
    STAT: fixing VOBU at 422MB (2241/4002, 55%)
    STAT: fixing VOBU at 425MB (2257/4002, 56%)
    STAT: fixing VOBU at 428MB (2273/4002, 56%)
    STAT: fixing VOBU at 431MB (2289/4002, 57%)
    STAT: fixing VOBU at 434MB (2305/4002, 57%)
    STAT: fixing VOBU at 436MB (2321/4002, 57%)
    STAT: fixing VOBU at 438MB (2337/4002, 58%)
    STAT: fixing VOBU at 441MB (2353/4002, 58%)
    STAT: fixing VOBU at 444MB (2369/4002, 59%)
    STAT: fixing VOBU at 447MB (2385/4002, 59%)
    STAT: fixing VOBU at 450MB (2401/4002, 59%)
    STAT: fixing VOBU at 454MB (2417/4002, 60%)
    STAT: fixing VOBU at 457MB (2433/4002, 60%)
    STAT: fixing VOBU at 460MB (2449/4002, 61%)
    STAT: fixing VOBU at 463MB (2465/4002, 61%)
    STAT: fixing VOBU at 466MB (2481/4002, 61%)
    STAT: fixing VOBU at 468MB (2497/4002, 62%)
    STAT: fixing VOBU at 471MB (2513/4002, 62%)
    STAT: fixing VOBU at 474MB (2529/4002, 63%)
    STAT: fixing VOBU at 477MB (2545/4002, 63%)
    STAT: fixing VOBU at 480MB (2561/4002, 63%)
    STAT: fixing VOBU at 482MB (2577/4002, 64%)
    STAT: fixing VOBU at 485MB (2593/4002, 64%)
    STAT: fixing VOBU at 488MB (2609/4002, 65%)
    STAT: fixing VOBU at 490MB (2625/4002, 65%)
    STAT: fixing VOBU at 493MB (2641/4002, 65%)
    STAT: fixing VOBU at 496MB (2657/4002, 66%)
    STAT: fixing VOBU at 500MB (2673/4002, 66%)
    STAT: fixing VOBU at 503MB (2689/4002, 67%)
    STAT: fixing VOBU at 506MB (2705/4002, 67%)
    STAT: fixing VOBU at 509MB (2721/4002, 67%)
    STAT: fixing VOBU at 513MB (2737/4002, 68%)
    STAT: fixing VOBU at 517MB (2753/4002, 68%)
    STAT: fixing VOBU at 520MB (2769/4002, 69%)
    STAT: fixing VOBU at 523MB (2785/4002, 69%)
    STAT: fixing VOBU at 526MB (2801/4002, 69%)
    STAT: fixing VOBU at 530MB (2817/4002, 70%)
    STAT: fixing VOBU at 533MB (2833/4002, 70%)
    STAT: fixing VOBU at 536MB (2849/4002, 71%)
    STAT: fixing VOBU at 540MB (2865/4002, 71%)
    STAT: fixing VOBU at 543MB (2881/4002, 71%)
    STAT: fixing VOBU at 545MB (2897/4002, 72%)
    STAT: fixing VOBU at 549MB (2913/4002, 72%)
    STAT: fixing VOBU at 552MB (2929/4002, 73%)
    STAT: fixing VOBU at 555MB (2945/4002, 73%)
    STAT: fixing VOBU at 557MB (2961/4002, 73%)
    STAT: fixing VOBU at 560MB (2977/4002, 74%)
    STAT: fixing VOBU at 564MB (2993/4002, 74%)
    STAT: fixing VOBU at 568MB (3009/4002, 75%)
    STAT: fixing VOBU at 571MB (3025/4002, 75%)
    STAT: fixing VOBU at 575MB (3041/4002, 75%)
    STAT: fixing VOBU at 579MB (3057/4002, 76%)
    STAT: fixing VOBU at 581MB (3073/4002, 76%)
    STAT: fixing VOBU at 584MB (3089/4002, 77%)
    STAT: fixing VOBU at 587MB (3105/4002, 77%)
    STAT: fixing VOBU at 590MB (3121/4002, 77%)
    STAT: fixing VOBU at 593MB (3137/4002, 78%)
    STAT: fixing VOBU at 596MB (3153/4002, 78%)
    STAT: fixing VOBU at 600MB (3169/4002, 79%)
    STAT: fixing VOBU at 604MB (3185/4002, 79%)
    STAT: fixing VOBU at 607MB (3201/4002, 79%)
    STAT: fixing VOBU at 610MB (3217/4002, 80%)
    STAT: fixing VOBU at 613MB (3233/4002, 80%)
    STAT: fixing VOBU at 616MB (3249/4002, 81%)
    STAT: fixing VOBU at 619MB (3265/4002, 81%)
    STAT: fixing VOBU at 622MB (3281/4002, 81%)
    STAT: fixing VOBU at 625MB (3297/4002, 82%)
    STAT: fixing VOBU at 628MB (3313/4002, 82%)
    STAT: fixing VOBU at 631MB (3329/4002, 83%)
    STAT: fixing VOBU at 635MB (3345/4002, 83%)
    STAT: fixing VOBU at 637MB (3361/4002, 83%)
    STAT: fixing VOBU at 641MB (3377/4002, 84%)
    STAT: fixing VOBU at 643MB (3393/4002, 84%)
    STAT: fixing VOBU at 646MB (3409/4002, 85%)
    STAT: fixing VOBU at 650MB (3425/4002, 85%)
    STAT: fixing VOBU at 653MB (3441/4002, 85%)
    STAT: fixing VOBU at 656MB (3457/4002, 86%)
    STAT: fixing VOBU at 659MB (3473/4002, 86%)
    STAT: fixing VOBU at 662MB (3489/4002, 87%)
    STAT: fixing VOBU at 664MB (3505/4002, 87%)
    STAT: fixing VOBU at 667MB (3521/4002, 87%)
    STAT: fixing VOBU at 670MB (3537/4002, 88%)
    STAT: fixing VOBU at 673MB (3553/4002, 88%)
    STAT: fixing VOBU at 676MB (3569/4002, 89%)
    STAT: fixing VOBU at 679MB (3585/4002, 89%)
    STAT: fixing VOBU at 682MB (3601/4002, 89%)
    STAT: fixing VOBU at 685MB (3617/4002, 90%)
    STAT: fixing VOBU at 688MB (3633/4002, 90%)
    STAT: fixing VOBU at 691MB (3649/4002, 91%)
    STAT: fixing VOBU at 694MB (3665/4002, 91%)
    STAT: fixing VOBU at 698MB (3681/4002, 91%)
    STAT: fixing VOBU at 701MB (3697/4002, 92%)
    STAT: fixing VOBU at 704MB (3713/4002, 92%)
    STAT: fixing VOBU at 707MB (3729/4002, 93%)
    STAT: fixing VOBU at 709MB (3745/4002, 93%)
    STAT: fixing VOBU at 712MB (3761/4002, 93%)
    STAT: fixing VOBU at 716MB (3777/4002, 94%)
    STAT: fixing VOBU at 719MB (3793/4002, 94%)
    STAT: fixing VOBU at 722MB (3809/4002, 95%)
    STAT: fixing VOBU at 725MB (3825/4002, 95%)
    STAT: fixing VOBU at 728MB (3841/4002, 95%)
    STAT: fixing VOBU at 732MB (3857/4002, 96%)
    STAT: fixing VOBU at 735MB (3873/4002, 96%)
    STAT: fixing VOBU at 739MB (3889/4002, 97%)
    STAT: fixing VOBU at 742MB (3905/4002, 97%)
    STAT: fixing VOBU at 746MB (3921/4002, 97%)
    STAT: fixing VOBU at 749MB (3937/4002, 98%)
    STAT: fixing VOBU at 752MB (3953/4002, 98%)
    STAT: fixing VOBU at 756MB (3969/4002, 99%)
    STAT: fixing VOBU at 759MB (3985/4002, 99%)
    STAT: fixing VOBU at 762MB (4001/4002, 99%)
    STAT: fixed 4002 VOBUS
    INFO: dvdauthor creating table of contents
    INFO: Scanning C:\Users\Chris\Documents\GFDOutDir\DVD/VIDEO_TS/VTS_01_0.IFO
    INFO: Scanning C:\Users\Chris\Documents\GFDOutDir\DVD/VIDEO_TS/VTS_02_0.IFO
    INFO: Creating menu for TOC
    STAT: Processing C:\Users\Chris\Documents\GFDOutDir\Temp\MMMenu.mpg ...
    WARN: Discontinuity of 9404 in audio channel 8; please remultiplex input.
    WARN: Previous sector: 0.120 - 0.120
    WARN: Current sector: 0.224 - 0.224
    WARN: Previous sector: 0.224 - 0.224
    WARN: Current sector: 0.328 - 0.328
    WARN: Previous sector: 0.328 - 0.328
    WARN: Current sector: 0.433 - 0.433
    WARN: Previous sector: 0.433 - 0.433
    WARN: Current sector: 0.537 - 0.537
    WARN: Previous sector: 0.537 - 0.537
    WARN: Current sector: 0.642 - 0.642
    WARN: Previous sector: 0.642 - 0.642
    WARN: Current sector: 0.746 - 0.746
    WARN: Previous sector: 0.746 - 0.746
    WARN: Current sector: 0.851 - 0.851
    WARN: Discontinuity of 7053 in audio channel 8; please remultiplex input.
    WARN: Previous sector: 0.851 - 0.851
    WARN: Current sector: 0.929 - 0.929
    WARN: Previous sector: 0.929 - 0.929
    WARN: Current sector: 1.034 - 1.034
    WARN: Previous sector: 1.034 - 1.034
    WARN: Current sector: 1.138 - 1.138
    WARN: Previous sector: 1.138 - 1.138
    WARN: Current sector: 1.243 - 1.243
    WARN: Previous sector: 1.243 - 1.243
    WARN: Current sector: 1.347 - 1.347
    WARN: Discontinuity of 9405 in audio channel 8; please remultiplex input.
    WARN: Previous sector: 1.347 - 1.347
    WARN: Current sector: 1.452 - 1.452
    WARN: Previous sector: 1.452 - 1.452
    WARN: Current sector: 1.556 - 1.556
    WARN: Previous sector: 1.556 - 1.556
    WARN: Current sector: 1.635 - 1.635
    WARN: Previous sector: 1.635 - 1.635
    WARN: Current sector: 1.739 - 1.739
    WARN: Previous sector: 1.739 - 1.739
    WARN: Current sector: 1.844 - 1.844
    WARN: Previous sector: 1.844 - 1.844
    WARN: Current sector: 1.948 - 1.948
    WARN: Previous sector: 1.948 - 1.948
    WARN: Current sector: 2.053 - 2.053
    WARN: Previous sector: 2.053 - 2.053
    WARN: Current sector: 2.157 - 2.157
    WARN: Previous sector: 2.157 - 2.157
    WARN: Current sector: 2.262 - 2.262
    WARN: Previous sector: 2.262 - 2.262
    WARN: Current sector: 2.366 - 2.366
    WARN: Previous sector: 2.366 - 2.366
    WARN: Current sector: 2.444 - 2.444
    WARN: Previous sector: 2.444
    Feb 2009
    Germany
    Very strange. Now it worked fine with 4 films. Only thing I have changed is that I`ve put the films inside the lines. The attempts before i put it outside it...
  6. That's really strange. But usually this error arises if the 'complexity' of the background image or movie is to high. Maybe you have hidden some complex (high contrast) parts of your background now as you have put the buttons for the movies in the inner frame.
    BTW: Somethings wrong with your audio:
    WARN: Discontinuity in audio channel 8; please remultiplex input.
    Usually this error/warning means that your mp2 file has the wrong frequency. Which is obviously the case:
    On DVDs only 48000 Hz is allowed.
    For MuxMan you need elementary video and audio files. Just demultiplex your vob files.
    Feb 2009
    Germany
    Thank you for this information. I will try to use 48000 Hz on the next DVD!!
    Feb 2009
    Germany
    Now I have the same error like before although I have converted the audio file in 48000 HZ.
    I will try it now with MuxMan!!
    Feb 2009
    Germany
    Great. With MuxMan it works without any problemy.
    Thanks again!
    Feb 2009
    Germany
    Now I have the same problem with MuxMan:
    C:\Users\Chris\Documents\GFDOutDir\Temp>Time: 19.02.2009 10:03:32
    INFO: [mplex.exe] File e:\DVDs\David Kirsch\geschnitten\David Kirsch - Fitnesstest.new.m2v looks like an MPEG Video stream.
    INFO: [mplex.exe] File e:\DVDs\David Kirsch\geschnitten\David Kirsch - Fitnesstest.new.mp2 looks like an MPEG Audio stream.
    INFO: [mplex.exe] Scanning for header info: Video stream e0 (e:\DVDs\David Kirsch\geschnitten\David Kirsch - Fitnesstest.new.m2v)
    INFO: [mplex.exe] Frame width : 480
    INFO: [mplex.exe] Bit rate : 4406400 bits/sec
    INFO: [mplex.exe] Scanning for header info: Audio stream c0 (e:\DVDs\David Kirsch\geschnitten\David Kirsch - Fitnesstest.new.mp2)
    INFO: [mplex.exe] Original/Copy : 0 copy
    INFO: [mplex.exe] rough-guess multiplexed stream data rate : 4698600
    INFO: [mplex.exe] Scanned to end AU 32613
    INFO: [mplex.exe] Multiplex completion at SCR=117407012.
    INFO: [mplex.exe] Video Stream length: 278027092 bytes
    INFO: [mplex.exe] Sequence headers: 2718
    INFO: [mplex.exe] No. Pictures : 32614
    INFO: [mplex.exe] No. Groups : 2718
    INFO: [mplex.exe] No. I Frames : 2718 avg. size 38803 bytes
    INFO: [mplex.exe] No. P Frames : 8154 avg. size 12037 bytes
    INFO: [mplex.exe] No. B Frames : 21742 avg. size 3421 bytes
    INFO: [mplex.exe] Average bit-rate : 1704800 bits/sec
    INFO: [mplex.exe] Peak bit-rate : 4406800 bits/sec
    INFO: [mplex.exe] BUFFERING min 15 Buf max 171428
    INFO: [mplex.exe] Audio stream length 31309632 bytes.
    INFO: [mplex.exe] Syncwords : 54357
    INFO: [mplex.exe] Frames : 54357 padded
    INFO: [mplex.exe] mplex version 1.9.0 (2.2.7 $Date: 2006/02/01 22:23:01 $)
    INFO: [mplex.exe] File e:\DVDs\David Kirsch\geschnitten\David Kirsch - Vorprogramm.new.m2v looks like an MPEG Video stream.
    INFO: [mplex.exe] File e:\DVDs\David Kirsch\geschnitten\David Kirsch - Vorprogramm.new.mp2 looks like an MPEG Audio stream.
    INFO: [mplex.exe] Video stream 0: profile 8 selected - ignoring non-standard options!
    INFO: [mplex.exe] Found 1 audio streams and 1 video streams
    INFO: [mplex.exe] Selecting dvdauthor DVD output profile
    INFO: [mplex.exe] Multiplexing video program stream!
    INFO: [mplex.exe] Scanning for header info: Video stream e0 (e:\DVDs\David Kirsch\geschnitten\David Kirsch - Vorprogramm.new.m2v)
    INFO: [mplex.exe] VIDEO STREAM: e0
    INFO: [mplex.exe] Frame height : 576
    INFO: [mplex.exe] Aspect ratio : 4:3 display
    INFO: [mplex.exe] Picture rate : 25.000 frames/sec
    INFO: [mplex.exe] Bit rate : 7702000 bits/sec
    INFO: [mplex.exe] Vbv buffer size : 229376 bytes
    INFO: [mplex.exe] CSPF : 0
    INFO: [mplex.exe] Scanning for header info: Audio stream c0 (e:\DVDs\David Kirsch\geschnitten\David Kirsch - Vorprogramm.new.mp2)
    INFO: [mplex.exe] MPEG AUDIO STREAM: c0
    INFO: [mplex.exe] Audio version : 1.0
    INFO: [mplex.exe] Layer : 2
    INFO: [mplex.exe] CRC checksums : no
    INFO: [mplex.exe] Bit rate : 24576 bytes/sec (192 kbit/sec)
    INFO: [mplex.exe] Frequency : 48000 Hz
    INFO: [mplex.exe] Mode : 0 stereo
    INFO: [mplex.exe] Mode extension : 0
    INFO: [mplex.exe] Copyright bit : 0 no copyright
    INFO: [mplex.exe] Emphasis : 0 none
    INFO: [mplex.exe] SYSTEMS/PROGRAM stream:
    INFO: [mplex.exe] rough-guess multiplexed stream data rate : 8061744
    INFO: [mplex.exe] target data-rate specified : 10080000
    INFO: [mplex.exe] Setting specified specified data rate: 10080000
    INFO: [mplex.exe] Run-in delay = 7200 Video delay = 7200 Audio delay = 10800
    INFO: [mplex.exe] New sequence commences...
    INFO: [mplex.exe] Video e0: buf= 0 frame=000000 sector=00000000
    INFO: [mplex.exe] Audio c0: buf= 0 frame=000000 sector=00000000
    INFO: [mplex.exe] Scanned to end AU 36417
    INFO: [mplex.exe] STREAM e0 completed
    INFO: [mplex.exe] STREAM c0 completed
    INFO: [mplex.exe] Multiplex completion at SCR=131103597.
    INFO: [mplex.exe] Video e0: completed
    INFO: [mplex.exe] Audio c0: completed
    INFO: [mplex.exe] VIDEO_STATISTICS: e0
    INFO: [mplex.exe] Video Stream length: 390673432 bytes
    INFO: [mplex.exe] Sequence headers: 3035
    INFO: [mplex.exe] Sequence ends : 1
    INFO: [mplex.exe] No. Pictures : 36418
    INFO: [mplex.exe] No. Groups : 3035
    INFO: [mplex.exe] No. I Frames : 3035 avg. size 47607 bytes
    INFO: [mplex.exe] No. P Frames : 9105 avg. size 15633 bytes
    INFO: [mplex.exe] No. B Frames : 24278 avg. size 4277 bytes
    INFO: [mplex.exe] Average bit-rate : 2145200 bits/sec
    INFO: [mplex.exe] Peak bit-rate : 7702400 bits/sec
    INFO: [mplex.exe] BUFFERING min 15 Buf max 171389
    INFO: [mplex.exe] AUDIO_STATISTICS: c0
    INFO: [mplex.exe] Audio stream length 34961472 bytes.
    INFO: [mplex.exe] Syncwords : 60697
    INFO: [mplex.exe] Frames : 60697 padded
    INFO: [mplex.exe] Frames : 0 unpadded
    INFO: [mplex.exe] BUFFERING min 15 Buf max 587
    INFO: [mplex.exe] MUX STATUS: no under-runs detected.
    INFO: [mplex.exe] File e:\DVDs\David Kirsch\geschnitten\David Kirsch - Hauptprogramm Teil 1.new.m2v looks like an MPEG Video stream.
    INFO: [mplex.exe] File e:\DVDs\David Kirsch\geschnitten\David Kirsch - Hauptprogramm Teil 1.new.mp2 looks like an MPEG Audio stream.
    INFO: [mplex.exe] Scanning for header info: Video stream e0 (e:\DVDs\David Kirsch\geschnitten\David Kirsch - Hauptprogramm Teil 1.new.m2v)
    INFO: [mplex.exe] Bit rate : 4558400 bits/sec
    INFO: [mplex.exe] Scanning for header info: Audio stream c0 (e:\DVDs\David Kirsch\geschnitten\David Kirsch - Hauptprogramm Teil 1.new.mp2)
    INFO: [mplex.exe] rough-guess multiplexed stream data rate : 4853696
    INFO: [mplex.exe] Scanned to end AU 44553
    INFO: [mplex.exe] Multiplex completion at SCR=160395410.
    INFO: [mplex.exe] Video Stream length: 354324776 bytes
    INFO: [mplex.exe] Sequence headers: 3713
    INFO: [mplex.exe] No. Pictures : 44554
    INFO: [mplex.exe] No. Groups : 3713
    INFO: [mplex.exe] No. I Frames : 3713 avg. size 37419 bytes
    INFO: [mplex.exe] No. P Frames : 11139 avg. size 10678 bytes
    INFO: [mplex.exe] No. B Frames : 29702 avg. size 3246 bytes
    INFO: [mplex.exe] Average bit-rate : 1590400 bits/sec
    INFO: [mplex.exe] Peak bit-rate : 4558800 bits/sec
    INFO: [mplex.exe] BUFFERING min 15 Buf max 158312
    INFO: [mplex.exe] Audio stream length 42772032 bytes.
    INFO: [mplex.exe] Syncwords : 74257
    INFO: [mplex.exe] Frames : 74257 padded
    INFO: [mplex.exe] File e:\DVDs\David Kirsch\geschnitten\David Kirsch - Hauptprogramm Teil 2.new.m2v looks like an MPEG Video stream.
    INFO: [mplex.exe] File e:\DVDs\David Kirsch\geschnitten\David Kirsch - Hauptprogramm Teil 2.new.mp2 looks like an MPEG Audio stream.
    INFO: [mplex.exe] Scanning for header info: Video stream e0 (e:\DVDs\David Kirsch\geschnitten\David Kirsch - Hauptprogramm Teil 2.new.m2v)
    INFO: [mplex.exe] Bit rate : 4691200 bits/sec
    INFO: [mplex.exe] Scanning for header info: Audio stream c0 (e:\DVDs\David Kirsch\geschnitten\David Kirsch - Hauptprogramm Teil 2.new.mp2)
    INFO: [mplex.exe] rough-guess multiplexed stream data rate : 4989248
    INFO: [mplex.exe] Scanned to end AU 43773
    INFO: [mplex.exe] Multiplex completion at SCR=157585115.
    INFO: [mplex.exe] Video Stream length: 359195492 bytes
    INFO: [mplex.exe] Sequence headers: 3648
    INFO: [mplex.exe] No. Pictures : 43774
    INFO: [mplex.exe] No. Groups : 3648
    INFO: [mplex.exe] No. I Frames : 3648 avg. size 39498 bytes
    INFO: [mplex.exe] No. P Frames : 10944 avg. size 11194 bytes
    INFO: [mplex.exe] No. B Frames : 29182 avg. size 3173 bytes
    INFO: [mplex.exe] Average bit-rate : 1640800 bits/sec
    INFO: [mplex.exe] Peak bit-rate : 4691600 bits/sec
    INFO: [mplex.exe] BUFFERING min 16 Buf max 164073
    INFO: [mplex.exe] Audio stream length 42023232 bytes.
    INFO: [mplex.exe] Syncwords : 72957
    INFO: [mplex.exe] Frames : 72957 padded
    INFO: [mplex.exe] File e:\DVDs\David Kirsch\geschnitten\David Kirsch - unterer Koerperbereich.new.m2v looks like an MPEG Video stream.
    INFO: [mplex.exe] File e:\DVDs\David Kirsch\geschnitten\David Kirsch - unterer Koerperbereich.new.mp2 looks like an MPEG Audio stream.
    INFO: [mplex.exe] Scanning for header info: Video stream e0 (e:\DVDs\David Kirsch\geschnitten\David Kirsch - unterer Koerperbereich.new.m2v)
    INFO: [mplex.exe] Bit rate : 4637200 bits/sec
    INFO: [mplex.exe] Scanning for header info: Audio stream c0 (e:\DVDs\David Kirsch\geschnitten\David Kirsch - unterer Koerperbereich.new.mp2)
    INFO: [mplex.exe] rough-guess multiplexed stream data rate : 4934144
    INFO: [mplex.exe] Scanned to end AU 32169
    INFO: [mplex.exe] Multiplex completion at SCR=115808548.
    INFO: [mplex.exe] Video Stream length: 288830400 bytes
    INFO: [mplex.exe] Sequence headers: 2681
    INFO: [mplex.exe] No. Pictures : 32170
    INFO: [mplex.exe] No. Groups : 2681
    INFO: [mplex.exe] No. I Frames : 2681 avg. size 44727 bytes
    INFO: [mplex.exe] No. P Frames : 8043 avg. size 11917 bytes
    INFO: [mplex.exe] No. B Frames : 21446 avg. size 3406 bytes
    INFO: [mplex.exe] Average bit-rate : 1795600 bits/sec
    INFO: [mplex.exe] Peak bit-rate : 4637600 bits/sec
    INFO: [mplex.exe] BUFFERING min 15 Buf max 170577
    INFO: [mplex.exe] Audio stream length 30883392 bytes.
    INFO: [mplex.exe] Syncwords : 53617
    INFO: [mplex.exe] Frames : 53617 padded
    INFO: [mplex.exe] File e:\DVDs\David Kirsch\geschnitten\David Kirsch - Oberkoerper.new.m2v looks like an MPEG Video stream.
    INFO: [mplex.exe] File e:\DVDs\David Kirsch\geschnitten\David Kirsch - Oberkoerper.new.mp2 looks like an MPEG Audio stream.
    INFO: [mplex.exe] Scanning for header info: Video stream e0 (e:\DVDs\David Kirsch\geschnitten\David Kirsch - Oberkoerper.new.m2v)
    INFO: [mplex.exe] Bit rate : 5065200 bits/sec
    INFO: [mplex.exe] Scanning for header info: Audio stream c0 (e:\DVDs\David Kirsch\geschnitten\David Kirsch - Oberkoerper.new.mp2)
    INFO: [mplex.exe] rough-guess multiplexed stream data rate : 5370896
    INFO: [mplex.exe] Scanned to end AU 33885
    INFO: [mplex.exe] Multiplex completion at SCR=121990582.
    INFO: [mplex.exe] Video Stream length: 319949124 bytes
    INFO: [mplex.exe] Sequence headers: 2824
    INFO: [mplex.exe] No. Pictures : 33886
    INFO: [mplex.exe] No. Groups : 2824
    INFO: [mplex.exe] No. I Frames : 2824 avg. size 44088 bytes
    INFO: [mplex.exe] No. P Frames : 8472 avg. size 13362 bytes
    INFO: [mplex.exe] No. B Frames : 22590 avg. size 3640 bytes
    INFO: [mplex.exe] Average bit-rate : 1888000 bits/sec
    INFO: [mplex.exe] Peak bit-rate : 5065600 bits/sec
    INFO: [mplex.exe] BUFFERING min 15 Buf max 177250
    INFO: [mplex.exe] Audio stream length 32530752 bytes.
    INFO: [mplex.exe] Syncwords : 56477
    INFO: [mplex.exe] Frames : 56477 padded
    C:\Users\Chris\Documents\GFDOutDir\Temp>Time: 19.02.2009 10:09:28
    *creating MMback.m2v
    C:\Users\Chris\Documents\GFDOutDir\Temp>Time: 19.02.2009 10:10:49
    *mux to MMback.mpg
    INFO: [mplex.exe] File C:\Users\Chris\Documents\GFDOutDir\Temp\MMBackg.m2 v looks like an MPEG Video stream.
    INFO: [mplex.exe] File d:\David Kirsch - Fitnesstest.wav.MP2 looks like an MPEG Audio stream.
    INFO: [mplex.exe] Scanning for header info: Video stream e0 (C:\Users\Chris\Documents\GFDOutDir\Temp\MMBackg.m 2v)
    INFO: [mplex.exe] Frame width : 720
    INFO: [mplex.exe] Bit rate : 7000000 bits/sec
    INFO: [mplex.exe] Scanning for header info: Audio stream c0 (d:\David Kirsch - Fitnesstest.wav.MP2)
    INFO: [mplex.exe] Bit rate : 20480 bytes/sec (160 kbit/sec)
    INFO: [mplex.exe] Original/Copy : 1 original
    INFO: [mplex.exe] rough-guess multiplexed stream data rate : 7311896
    ++ WARN: [mplex.exe] Stream e0: data will arrive too late sent(SCR)=7314 required(DTS)=7200
    ++ WARN: [mplex.exe] Video e0: buf= 99212 frame=000000 sector=00000049
    ++ WARN: [mplex.exe] Audio c0: buf= 0 frame=000000 sector=00000000
    INFO: [mplex.exe] Scanned to end AU 381
    INFO: [mplex.exe] Multiplex completion at SCR=1373915.
    INFO: [mplex.exe] Video Stream length: 7409369 bytes
    INFO: [mplex.exe] No. Pictures : 382
    INFO: [mplex.exe] No. I Frames : 26 avg. size163940 bytes
    INFO: [mplex.exe] No. P Frames : 103 avg. size 14282 bytes
    INFO: [mplex.exe] No. B Frames : 253 avg. size 6623 bytes
    INFO: [mplex.exe] Average bit-rate : 3879200 bits/sec
    INFO: [mplex.exe] Peak bit-rate : 5837200 bits/sec
    INFO: [mplex.exe] BUFFERING min 20 Buf max 235543
    INFO: [mplex.exe] Audio stream length 305280 bytes.
    INFO: [mplex.exe] Syncwords : 636
    INFO: [mplex.exe] Frames : 636 padded
    INFO: [mplex.exe] BUFFERING min 19 Buf max 479
    **ERROR: [mplex.exe] MUX STATUS: Frame data under-runs detected!
    *creating menufile MMMenu.mpg
    DVDAuthor:pumux, version 0.6.14-GfD-2.
    Build options: gnugetopt iconv freetype
    Send bugs to <gfd@boraxsoft.de>
    STAT: 0:00:00.000
    INFO: PNG had 2 colors
    INFO: Constructing blank img
    INFO: Pickbuttongroups, success with 1 groups, useimg=1
    INFO: Found EOF in .sub file.
    INFO: Max_sub_size=6102
    INFO: 1 subtitles added, 0 subtitles skipped, stream: 32, offset: 0.12
    C:\Users\Chris\Documents\GFDOutDir\Temp>Time: 19.02.2009 10:10:51
  11. No, if you would use MuxMan as authoring engine, the log would be completely different (no mplex, spumux, dvdauthor...). Please check your (default - permanent) settings in GfD!
    Feb 2009
    Germany
    Sorry, my fault.
    But I have now the problem that the Video Size is not correct:
    480*576
    What formats do muxman support?
  13. Only 'real' dvd resolution.
    See here, what is allowed on a 'compliant' DVD:
    https://www.videohelp.com/dvd
