It means you don't have the Xvid codec installed, or another codec that can display Xvid files. Simplest is to install the Xvid codec and try again.
Read my blog here.
I downloaded xvid codec 1.2.1 and tried again but still the same error message , any ideas ?
OK here we go , i have downloaded sucessfully the xvid codec, it has now convertered the .avi file to a .m2v file but nero will still not burn this file as it has no vob files etc , ANY IDEAS ?
.m2v file is a video stream. It has no audio.
Try again with AVStoDVD. Set it to output either an ISO file, or better, a Video_TS folder. When it is finished, test play the DVD structure with Media Player Classic by opening the IFO file in the folder. When happy, burn with Imgburn.Read my blog here.
It will create them as part of the process, but at the end of the day you should have an ISO file ready to burn.
Personally, I output to a video_ts folder so I can test play it first, then burn if it is good. There is no speed advantage to burning from an ISO.Read my blog here.
AVI/Xvid MP3 to AVI/Xvid AC3
By MarquisdeOz in forum AudioReplies: 3Last Post: 10th Sep 2010, 06:59 -
VirtualDub/Xvid question: YV12 vs. XVID FourCC in the xvidvfw.dll driver???
By KneeRow in forum Video ConversionReplies: 14Last Post: 1st Aug 2010, 14:35 -
Pentax Camera AVI - Tried to use FourCC tool...
By peiklk in forum Video ConversionReplies: 6Last Post: 15th Feb 2010, 16:56 -
Intermediate codec and xvid question, and xvid to wmv.
By ^xRun^ in forum Video ConversionReplies: 9Last Post: 22nd Jul 2008, 18:13 -
question about converting wmv to avi (xvid) using Virtual Dubmod
By jimdagys in forum Video ConversionReplies: 5Last Post: 16th Apr 2008, 16:16
