    Mar 2007
    Are Adobe Premeire Pro 1.5 projects/files compatible with CS3/CS4?
    Apr 2004
    Miskatonic U
    You should be able to open them, assuming you have updated versions of any plugins you have used as well.
    However if you save them out from CS3/4, you may not be able to load the same projects back into PP1.5
    Read my blog here.
    Mar 2007
    How are these specs for CS3?:
    - Genuine Windows Vista Home Premium with Service Pack 1 (32-bit)
    - Intel(R) Core(TM) 2 Quad processor Q8300 [2.5GHz]
    - 3GB DDR2-800MHz SDRAM
    - 500GB 7200 rpm SATA 3Gb/s hard drive
    - 256MB NVIDIA GeForce 9300 [DVI, HDMI, VGA adapter]
    - Integrated 7.1 channel sound with front audio ports
    CS3 System Requirements:
    - Intel Pentium 4 (1.4 GHz processor for DV, 3.4 GHz processor for HDV); Intel Centrino; Intel Xeon (dual Xeon 2.8 GHz processors for HD); Intel Core Duo or compatible processor (SSE2-enabled processor required for AMD systems)
    - Microsoft Windows XP Home or Professional with Service Pack 2; Windows Vista Home Premium, Business, Enterprise, Ultimate (certified support for 32-bit editions only)
    - 1280x1024 monitor resolution with 32 bit color adapter; Adobe recommended graphics card for GPU-accelerated playback*
    - For SD/HD workflows, an Adobe-certified card for capture and export to tape*
    - OHCI-compatible IEEE 1394 port for DV and HDV capture, export to tape, transmit to DV device
    - Microsoft DirectX or ASIO-compatible sound card
    - 1 GB of RAM or more recommended for DV; 2 GB of RAM or more recommended for HDV and HD
    - 10 GB of available hard-disk space (additional free space required during installation)
    - Dedicated 7200 RPM hard drive for DV and HDV editing; striped disk array storage (RAID 0) for HD, SCSI disk subsystem preferred
    Mar 2007
    Anyone else know whether Adobe Premiere Pro 1.5 project/files work with Adobe Premiere Pro CS3 or CS4?
    I have one big Premiere Pro 1.5 project that is not yet completed when my computer crashed and if it won't work in CS3/CS4 then I'll need to keep Premiere Pro 1.5 and install XP Home on my new computer.
    Computer is arriving this Thursday and XP retail CD is arriving Tuesday. This will help me determine whether I send back the XP retail CD to amazon.
  5. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    I would stick with XP regardless
    Read my blog here.
    Mar 2007
    Reason?
    Mar 2007
    I may decide to stick with Vista and get an academic version of Premiere Pro CS4 (or commercial version of CS3 on eBay, transfer liscense). Too bad I already purchased XP retail CD. Now I may have to sell it.
    I could not find answers on whether Pro 1.5 would work with CS3/CS4. The only thing I found was that some effects that was in 1.5 may not be available in CS3/CS4. However, I just got my new computer, downloaded the trial of CS4 and I am able to open Premiere Pro 1.5 project in CS4. Effects that I use (cross dissolve) is still available. So no problems there. When you open a Pro 1.5 project in CS4, it tells you that the project was created in an earlier version of Premiere and that it would need to be converted.
