I am working on a project. I edit in Final Cut Pro.
Users have submitted around 30 video clips to an event. My task is to assemble them into 1 video to be played at the event. The clips include, SD 4:3, SD 16:9, HD 720, HD 1080, and some are weird like, 864x480, 960x540.
The final export will be shown via a large movie theater projector (its an older theater and there is a good chance it is not HD, no way to verify before the event). We will use a high quality H.264 QT movie export played via a laptop.
My question is what would you advice I use for my sequence settings in FCP and what should my final output be. I am thinking of using NTSC SD 720x480. Things in 16:9 will be letterboxed. HD will just be scaled down to fit. I think that is better then scaling up the SD videos to HD dimensions. Do you agree? Any warnings you would like to give me?
Thanks!
Results 1 to 1 of 1
FCP 7: HD Playback with NTSC Sequence Settings?
By TeeHee in forum Newbie / General discussionsReplies: 3Last Post: 2nd Aug 2010, 23:17 -
FCP MOV to x264 produces separate Audio and Video MP4 output files?
By skywriter in forum ffmpegX general discussionReplies: 3Last Post: 10th Feb 2010, 16:49 -
massive trubb with FCP output
By blunderbus in forum MacReplies: 0Last Post: 20th Feb 2009, 09:51 -
FCP: What is the best way to work with .m2v files in a FCP timeline?
By murraymile in forum MacReplies: 1Last Post: 23rd Jan 2009, 16:59 -
Convert from FCP output (DV-PAL) to a format playable on PC in WMP
By Ferry99 in forum Video ConversionReplies: 1Last Post: 24th Dec 2007, 20:32
