Hi everyone, please help me!
I've downloaded the ffMpeg X program and I'm trying to convert a quicktime movie file into a FLash media file but it's just not working. I think I've downloaded the program correctly as I've followed all the things mentioned on the forum and when I convert to another format it works.
HOWVER, when going from a Mpeg 1 movie file and converting to FLV file it converts extremely quickly (like 2 seconds) and when I open the file it is black with no sound or image. Please help I've tried exporting the file as a variety of formats but always the same with FLV.
I get the following information when I open it up:
FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
Mac OSX universal build for ffmpegX
Sun Feb 15 23:22:38 GMT 2009
libavutil version: 49.0.0
libavcodec version: 51.9.0
libavformat version: 50.4.0
Input #0, mpeg, from '/Hush-Rambert - HUSH-MPEG-1 .mpg':
Duration: 00:26:46.8, start: 0.766200, bitrate: 2086 kb/s
Stream #0.0[0x1c0]: Audio: mp2, 48000 Hz, stereo, 192 kb/s
Stream #0.1[0x1e0], 25.00 fps(r): Video: mpeg1video, yuv420p, 352x288, 1850 kb/s
Codec type mismatch for mapping #0.0 -> #0.0
Any insights would be massively appreciated!
Thank you!
Michelle
Hi Michelle,
Welcome to our little corner of the 'net.
The last line in your log is the actual error message. "Codec type mismatch for mapping #0.0 -> #0.0" means that ffmpegX tries to convert the source audio (input stream #0.0) to target video (output stream #0.0). That fails because it wants a video codec to convert to video, and audio to audio. It seems your source file is somewhat odd, in that the audio is listed (#0.0) before the video (#0.1), when ffmpeg likes to see it the other way around.
ffmpeg's solution to this is to customize the stream mapping, so it can be reversed (#0.1 -> #0.0 and #0.0 -> #0.1). In ffmpegX's interface, this can be done with the "Invert mapping" checkbox in the Audio tab.
Unfortunately, conversions to FLV don't work well with inverted stream mapping: it introduces a stuttering issue with Flash Player.
For converting with ffmpegX to FLV from .mpg files with the audio stream listed before the video stream, I would recommend re-muxing: Demux into two files (video-only and audio-only), then mux them back again. The re-muxed file should be the same as the original, except for the stream order. The remuxed file should convert fine to FLV without needing to invert stream mapping: no more "Codec type mismatch for mapping"-errors.
(I've mentioned manually changing the stream order with QuickTime Pro in other topics on this forum, but that doesn't work for .mpg files.)
ffmpegX has demux and mux tools in the Tools tab, although I like MPEG Streamclip's demuxing better, as it can overcome some file errors, if present.
Let us know how it went, good or bad. Or if the above wasn't insightful enough.
Compress large FLV file to a smaller size FLV file
By RustyBob in forum Video ConversionReplies: 1Last Post: 26th Oct 2011, 17:21 -
How to trim .flv file without re-encoding
By Eye for Video in forum Newbie / General discussionsReplies: 7Last Post: 31st May 2010, 00:01 -
Certain FLV Files can't be Converted ?
By cheng in forum Video ConversionReplies: 7Last Post: 23rd Feb 2009, 22:27 -
Problem encoding to .flv - produces Zero KB file in one sec ?!
By toki4004 in forum ffmpegX general discussionReplies: 11Last Post: 25th Jan 2009, 05:58 -
How to find encoding info of a Flash video (.flv) file?
By Netozai in forum Newbie / General discussionsReplies: 2Last Post: 9th Oct 2007, 14:35
