I have no idea if this topic is in right place but I hope so
Now to my questions.
I have a digital video camera (I dont know what kind because I'm home and the camera is not).
The camera have a miniDV tape for a hour but I like to recording at least 8 hour non-stop and I guess I have to
use a firewire cable and connect the camera to a laptop.
Question 1
Is that possible, can all digital camera do that, and how (I know that is not easy when I dont know what kind of camera I
have but is that something "default").
Question 2
What program can I use, what I have found I can use windows movie maker but I like to have a program that can save as
good quality as possible in AVI or even maybe MPEG. so is that any free program I can use or is windows movie maker
good for me?
If the camera is MiniDV you will need an IEEE-1394 (aka Firewire or ILink) for best quality. If your laptop doesn't have this port you can add one with a PC card.
While MovieMaker can capture DV and export DV, the correct menu settings can get confusing. I recommend WinDV for capture which is simple.
DV format at 13GB/hr will require a large hard drive for storage (8hr = ~104GB).
Real time encoding can be done if your laptop is powerful enough. There will be a compromise in quality vs direct recording. Possible real time encoders
WMV - forced deinterlace.
MPeg2 - CPU intensive
MPeg4 - in most cases forced deinterlace and CPU intensive.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Windows Movie Maker will capture with exactly the same quality as comes from the camcorder. When you plug in your camcorder via the FireWire connection you should see a window pop-up with an option to import the video.
There are other programs that will work, too, giving identical quality - the most common and recommended is WinDV. But Windows Movie Maker will do the job if you want it to.John Miller -
Thanks for the fast replay
Yes I have a fast laptop but maybe not so big disk so I maybe have to add a USB disk to it but I think that is ok anyway. -
You just need to remember to export from Movie Maker in DV-AVI format, not default WMV.Originally Posted by JohnnyMalaria
An external USB2 drive should work well with a modern fast laptop.Recommends: Kiva.org - Loans that change lives.
photo capture from video signal hardware
By huegel in forum Capturing and VCRReplies: 0Last Post: 6th Mar 2012, 10:50 -
Capture video to anything besides a PC or laptop?
By gamermom in forum Capturing and VCRReplies: 1Last Post: 11th Dec 2010, 09:22 -
Outputting HDMI signal from laptop to TV
By Gojira in forum Software PlayingReplies: 2Last Post: 1st Jul 2009, 08:32 -
My capture card loses signal during some video game scene transitions
By Nintendo Fan in forum Capturing and VCRReplies: 1Last Post: 21st Mar 2009, 12:51 -
Video Recording to laptop...Underwater camera
By gravinus in forum Capturing and VCRReplies: 12Last Post: 9th Jan 2009, 11:40
