Hi. I'm trying to burn the files that i have converted to DVD using FAVC with a simple DVD menu. All i want is a program that allows you to input the DVD .vob files created by FAVC, insert a custom background, with or without music, and some simple texts that can be selected so i can navigate to the episode that i want to watch. But most importantly, this program will not re-encode the files that i input since re-encoding will result in quality loss. Can anyone help me please? Or if there's no such programs exist, then what's a good authoring program to use? Thanks.
Results 1 to 10 of 10
Why didn't you do all that within FAVC?
http://www.digital-digest.com/articles/FAVC_Video_to_DVD_Guide_page2.html -
Other programs that do text buttons and custom backrounds
off the top of my head
Dvd Lab
MPEG Video Wizard DVD
TMPGEnc Authoring Works
and maybe VideoReDo Tv Suite
And Adobe Encore DVD -
GUIForDVDAuthor will do text only menus if that is what you want. You don't have to use the built in templates.
Read my blog here.
Oh, i forgot to include one important thing, that is out of these authoring programs which do text buttons with a custom background, which one of them also supports burning the final product to DVD without re-encoding?
I'm not sure if i explained clear enough. But basically, i want to insert these 10 converted files into an authoring program and burn from that program without having to re-encode again. That's what i want to do. Please help me, thanks. -
As you have encoded to DVD compliance using FAVC, no good authoring tool should re-encode. GUIForDVDAuthor does not have the facility to re-encode regardless, so it is a safe bet.
Burn the results with Imgburn to good media for best results.Read my blog here.
If you have installed Imgburn, you can enter the path to Imgburn in the GfD (GUIForDVDAuthor) settings, then you can burn (with Imgburn) directly from GfD. Concerning the text buttons with a custom background, that's pretty easy. Text buttons are the default in GfD and you may import any bmp, jpg, gif or png image as a custom background. After starting GfD, select 'Format' - 'Menu (Actual)' and click on the file open icon in the first line of the menu background dialog.
GUI for dvdauthor:
https://www.videohelp.com/~gfd/
Convert VOB files to Divx with DVD menu
By xtof in forum Video ConversionReplies: 1Last Post: 1st Mar 2011, 16:29 -
FAVC making an invalid IFO
By Nitemare in forum Video ConversionReplies: 1Last Post: 3rd Oct 2010, 03:41 -
problems making dvd from vob files only
By Dr_Sanguinary in forum Newbie / General discussionsReplies: 3Last Post: 17th Nov 2009, 08:20 -
DVD Demuxer tool making 0kb .VOB files
By Madvillain in forum DVD RippingReplies: 5Last Post: 6th Jul 2009, 05:11 -
How are ifo files created with only vob files?
By Han Solo1 in forum Newbie / General discussionsReplies: 0Last Post: 18th May 2008, 14:07
