Hi all,
Is there any way to show, in a enconding process with mencoder, only the status line? (that is, the line that tells about percentage to complete, fps, ...)
The output of mencoder is too verbose and using -quiet or -really-quiet disables the status line.
Any ideas?
Thanks in advance.
	Hi again,
 I've found a solution, which is far from be perfect, but for now, It is the only one. So more ideas will be appreciated
 I have created a simple perl script:
 binmode STDIN;
 $line = '';
 while (($n = read STDIN, $data, 1) != 0) {
 $line .= $data;
 if ($data eq "\n") {
 $line = '';
 } elsif ($data eq "\r") {
 if ($line =~ m/^Pos.*fps\s*Trem.*\r$/) {
 print $line;
 $line = '';
 The idea is to pipe mencoder output to this perl script:
 mencoder -oac ... -ovc ... -o output.avi | cleanmencoder.exe
 Since I was using windows I had to pack the perl script to exe first (PAR::Packer) in order to be able to pipe mencoder output.
	An old post but the point it makes is perfectly valid. Why does mencoder spit out tons of lines, which scroll by too fast to be read? Yes, I can turn down verbosity with "-quiet" or "-really-quiet", but then I don't get the estimated file size and time. Why not print out a single, constantly updated status line with file size and time? Many DOS programs worked like this (defragmenters, disk checkers, etc). Unfortunately, I couldn't get the above Perl solution to work: I couldn't get dname for Win to compile PAR-Packer. If anyone knows of another solution (cygwin/awk perhaps), please let me know. If mencoder developers read this, give this issue some thought.
  Mencoder line help for trekstor i.beat move player [linux] - (solved)By tolostoi in forum Video ConversionReplies: 0Last Post: 2nd Jul 2009, 03:10
  Mencoder config and and command line -vf options not working together?By AlexGrim in forum DVD RippingReplies: 0Last Post: 1st Dec 2008, 13:00
  Mencoder: Request for official (or any) website on its comman-line params!By vhelp in forum Video ConversionReplies: 4Last Post: 22nd Mar 2008, 12:33
  Mencoder 2-pass Command Line to flvBy mrready in forum Video ConversionReplies: 1Last Post: 16th Dec 2007, 04:25
  Mencoder 2-pass Command Line to flvBy mrready in forum ffmpegX general discussionReplies: 2Last Post: 15th Dec 2007, 12:49
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
