    Feb 2009
    I currently have a dead Sony DCR-DVD-308. I need one that is better. I like the view finder. I need something that will be better at low light sports like hockey, basketball. I get more confused the more I try to figure it out. Any suggestions? Under 1200 ish.. need more thant 15x zoom. I don't care about HD of DVD.
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Canon HV20/HV30
    http://www.hv20.com/
    http://www.kiva.org/about
  3. Originally Posted by dktrfmly
    I bought a refurb hv20 from onecall.com it shoots in both HD and Dv .you can get it right now for $439 shipped +5-Year Protection Plan for $95
    https://forum.videohelp.com/topic358525.html?highlight=hv20
    http://www.onecall.com/ProductDetails.aspx?id=92302
    since money isn't a big issue .wait for HV40
    check this clip from Racer-X
    http://www.vimeo.com/1123167
  4. Member edDV's Avatar
    Mar 2004
    The HV40 only has advantage for 24p. Since OP is shooting sports, he should stay with interlace 29.97 fps (1080i HDV or 480i DV). Next best cam would be ~3500 XH-A1. Best would be the $5000 JVC GY-HD200U (720p @59.94 fps) or higher.
