Hi,
The other week I bought myself a spindle with 25 Philips DVD+RW. Off these 25 I already have two DVD's I can't burn after the first time use. Is this though luck, getting a batch of DVD's with a high percentage of failures?
I use Nero to burn under Windows, but burning the same DVD under Linux failed too. (And I don't hope this is caused by a faulty toaster).
Does someone mind to comment on my troubles?
Abel
My experience with re-writable DVDs is that this sometimes happens. The discs are cheap so when it happens I just throw the bad disc away and don't worry about it. I advise that in the future you consider buying Verbatim DVD+RW discs instead. Verbatim makes the highest quality re-writable DVDs and you may have more success with them.
Thanks. And I thought Philips delivered the best quality. Verbatim it will be the next time.
Rip DVD-R's, edit out commercials, burn new DVD Dual Layer...software?
By ruehl84 in forum Authoring (DVD)Replies: 5Last Post: 23rd Feb 2012, 04:06 -
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 13:42 -
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 05:26 -
Advice required when trying to burn with img burn
By IPBR21054 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 1st Aug 2009, 17:29 -
Burn Software with Menu & burn xvid avi
By CynthiaBlue in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2007, 21:46
