Hello
After a reinstall of XP, as I tried to rip a DVD using DVDDecrypter it wanted to set the region code for the DVD Writer (LiteOn and ASUS). I tried with my two DVD Writers, and for both I got the same message.
Now I have used DVDDecrypter for so many times earlier, but never received this type of message from DVDDecrypter earlier. So at present I could not rip the DVD properly. Note: DVDFab HD Decrypter worked without any problem.
I do not want to set the region code as I watch different DVDs which may have different codes sourced both from US and Europe.
Any help please?
আমি বাংলায় গান গাই
I get that all the time.
It hasn't affected the number of region code changes that are shown available for the drive.
try this software on your liteon
http://dhc014.rpc1.org/LtnRPC/
Can reset the region code an unlimited amount of times and/or set the drive to RPC-1
Also are you sure you can't rip dvds DVDDecrypter is supposed to brute force to get the keys if there is a region code mismatch. -
No need to have any additional programs running. DVD Decrypter is not asking to change the region code of your drive. Because of the RCE (Region Code Enhancement) the program just needs manual input of the region code of the DVD in order to process it. The region code of your drive remains unchanged and the resulting DVD files will be region free.
Thanks very much
Nope, Brute Force approach failed.Originally Posted by loster
Hmmmm...maybe that's why sambat is getting a unlimited chance...Originally Posted by RowMan
আমি বাংলায় গান গাই
Being able to set region code in LG BD550 blu ray player
By bevivek in forum DVD & Blu-ray PlayersReplies: 1Last Post: 22nd Oct 2011, 06:11 -
Change of Region Code incorrectly set on DVD player
By cashey007 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 12th Mar 2010, 21:12 -
Region Code Samsung ht-bd1220 - Code does not work
By mhschenk in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Oct 2009, 14:44 -
Need code for pioneeer bdp lx70 code for multi region ...
By SHERWOODSelectrical in forum DVD & Blu-ray PlayersReplies: 2Last Post: 21st Nov 2008, 12:42 -
DVDdecrypter region code not set. Help
By X_Splinter in forum Software PlayingReplies: 2Last Post: 9th Sep 2008, 17:08
