Hey everybody I recorded a show called rage music channel and i record roughly 5 hours of it 14.00Gb and was seeking advice on which way i should cut it down into small 4min videos easily enough? thanks
	You'll need to be more specific. What type of file format was it recorded to? Wmv? avi? Mpg? dvr-ms?
 You can use gspot or avicodec to identify the file type.
 As far as cutting programs the one I like for mpeg based file types is mpg2cut2. It is very straight forward and good and free.
 There are a quite a few other choices available in the tools section as well - https://www.videohelp.com/tools
 Oh and welcome to the forum. Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
	OK ahh first of all the format is one i can convert anything the programs require like avi ahh second i was to cut them down in to music videos so roughly 3/4 mins depending on length of clip. i am then going to transfer the files to ps3 to they will be avi format... thanks you
	The short answer is that there is no simple way to do this, other than manually. What is the best way is up to what output you want. The PS3 will happily accept H264, which means you can either encode to the same quality as Xvid/Divx in a smaller filesize, or encode to a higher quality in the same filesize.
 AVIDemux is a good any any for doing this.
 Again, it would be interesting to know what format the source is. I am guessing mpg. If possible, I would cut using a smart renderer, saving the clips as mpg files (assuming that is what the source is) until they are all done. This would be the most painless way to edit. Once done, I would use Xvid4PSP to convert the files to .mp4 with the PS3 profile. You can batch convert, so you can just set up a queue with all the clips in it, and let it encode them all until it is done.Read my blog here.
	For dvr-ms you can convert to mpg2 and leave it as it is and the ps3 will play them.
 I can't think of a standalone app that will strip the protection at the moment - other than directshowdump but I haven't had a 100% success rate with that on all dvr-ms files.
 I do own Tmpgenc Dvd Author 2 and it has the ability to turn dvr-ms files into mpg files.
 I'm sure there are other apps I can't just can't think of them right now.
 Check here for more options:
 search by dvr-ms and you'll find more.
 But as I said you can keep them as mpeg2 and the ps3 will play them. Of course you'll need to convert them to a more compressed form like divx or xvid if you want to save space. But you don't have to convert if you just want to leave them as a mpg2 .mpg file.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
  [FR] Cutting TS Help Me PleaseBy KERNEL32 in forum EditingReplies: 5Last Post: 26th Feb 2010, 14:38
  Recording a better copy of an old recording.By cyber-junkie in forum Newbie / General discussionsReplies: 1Last Post: 9th Jan 2010, 16:48
  Alright, what IS the big deal with variable bit rate recording?By ministry88 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 1st Jul 2009, 17:26
  Big big troubles with firewirre PCI card.By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 1st Mar 2008, 00:51
  Cutting OutBy OG24 in forum Newbie / General discussionsReplies: 2Last Post: 12th Aug 2007, 19:55
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
