I don't know what I did but there are 2 or 3 days ago I'm being importuned with sites such as
http://argentbux.... http://abhsoft... http://radio-dj... http://trahwija.... http://winmoney... http://safearena...
and so on.
What must I do to eliminate these intrusions without to format or reinstall the Windows XP?
Thank you for your help.
Results 1 to 13 of 13
first see if your computer has been infected with spyware/malware. malwarebytes, adaware, trojanhunter and other scanners should find most junk.
and start using firefox,and stop browsing porno/poker sites
be sure to turn system restore off before you run malwarebytes -
Restart your machine in safe mode (press F8 ) before you run the anti-spyware app to really kill the infection.
I had one a while back where that didn't work. Not by itself, anyway. I had to both disconnect from the internet as well as start in safe mode to finally get rid of it. minidv2dvd's suggestion of Malwarebytes is a good one. That's what finally got rid of it for me. You don't need the paid version:Originally Posted by Soopafresh
http://www.malwarebytes.org/mbam.php -
Before nulling the infection you should disable system restore, otherwise re-infestation could take place ... re-enable after cleanup.
As for inappropriate sites in browser > http://www.k9webprotection.com/ -
Thank you to everyone that answered me and helped me.
But, Bjs, how can I disable system restore and re-enable after the cleaning?
Cheers.
P.S. - By the way, AVG ended its scanning and the results ( Infected, warnings, etc.) were all 0. -
Start->Programs->Accessories->System Tools->System Restore->System Restore Settings.
That's on XP. Dunno if it's different for others. -
Dont visit Poker sites ... I know people who did ... dumbOriginally Posted by MJA
Porno site ... ha ha ... I have two favorite sites ... send me a PM message if you interested.
I dont want the way they do things at these two sites to change ... they are great ... so I wont mention them here.
Most likely against the rules anyways. I use to have two yellow pillows above my avatar for almost a year
Try Malwarebytes .... works for me ... very nice program ... works really good ... trial version works wondersOriginally Posted by Jomapil
I suggest also running http://www.superantispyware.com/index.html it will find things that MBAM doesn't and vice cersa.
It also has a lot of handy tools in the repair tab under preferences.
To block sites
By Jomapil in forum ComputerReplies: 13Last Post: 24th Apr 2012, 19:12 -
Useful HTPC tools, sites
By Baldrick in forum Media Center PC / MediaCentersReplies: 3Last Post: 4th Oct 2011, 17:51 -
Download Sites?
By wulf109 in forum ComputerReplies: 5Last Post: 8th Jul 2009, 18:19 -
Cannot Access certain sites
By dudesmn in forum ComputerReplies: 68Last Post: 8th May 2007, 16:46 -
Downloading FLV from other sites?
By whoisquilty in forum MacReplies: 12Last Post: 6th May 2007, 11:21
