Hello.
I'm trying to save a few movies off my Dishnet satellite.
I'm using ATI's multimedia center to capture 320x240 uncompressed AVI's. I've wiped a 46 Gig ATA100 drive, installed W2K on it and installed the VirtualDub, the Divx codec plus ATI's MMC. That's it. It's in a removable drive and I'm only going to capture video with this disk. I have 43 Gigs free which is enough room for 2-1/2 hours of uncompress AVI.
I get a great capture with this setup. When I try to convert to Divx, it looks like crap. I'm using the howto here: http://www.vcdhelp.com/avi2divx.htm.
Is this what I'm suppose to be using? Am I wasting my time capturing satellite? What am I doing wrong? I've been fighting with this for 4 days, reading all the post and info on the net I can.
HELP!!!
Griminal
The default setting in some versions of the codec have low bitrates - try upping the bitare.
The default setting isn't always the best -
yeah, you should up the bit rate slider. I use low motion divx with the slider up to 6000 to convert my avi's to divx, and it looks great, and the file isn't that big.
You mean bump the 910 up to 6000?
Isn't that a little steep? What size files are you getting with a setting this high.... let's say an average 1 hr 30 min flick. -
Yep, the 910 up to 6000, and on audio, mpeg layer-3 44,100Hz stereo 224kBit/s... says 28Kb/s. I get about a 209 MB file of DBZ capture without commercials, 22 minutes long, dunno about longer caps tho. math wise, it looks to maybe fit on one cd : D
Final Cut Pro 5/File quality and conversion questions to .avi
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 0Last Post: 9th Feb 2010, 21:24 -
.divx to .avi XviD conversion?
By Benhermies in forum Newbie / General discussionsReplies: 2Last Post: 3rd Feb 2009, 19:15 -
DIVX to AVI conversion
By jjbodean1970 in forum Video ConversionReplies: 9Last Post: 18th Aug 2008, 01:05 -
VOB file conversion to AVI...many questions
By tonyclem in forum DVD RippingReplies: 19Last Post: 7th May 2008, 11:39 -
Many questions on MKV to AVI for DivX player
By MasterRoshi in forum Newbie / General discussionsReplies: 5Last Post: 21st Jan 2008, 12:42
