Hi there
I have a lot of video clips or photos rather that I want to apply the same transition. I am wondering how I can do that ? I read somewhere that I would need a script, so anybody have that script available somewhere for free ???? It would be very time consuming applying for around 100 photos.
I think you can assign a default transition and duration that a convenient button uses
You could also select the clips then apply the transition
ctl + drag
Seems it's a common procedure in consumer editors... -
pp and fcp have a default transition that is settable but not vegas that i know of.
in vegas if you are going to do 300 of the same transition i'd make sure all videos are joined with crossfades, right click in the first video on the timeline, click select events to end, and then drag your transition of choice to the first crossfade. it will be applied to all of them.--
Sony Vegas, How do you change the clip length of multiple clips? Please hel
By Purplehayes in forum EditingReplies: 11Last Post: 30th Dec 2014, 06:19 -
Sony Vegas Pro - Importing clips from another project
By ClownInBrown in forum EditingReplies: 8Last Post: 18th Apr 2011, 20:43 -
Sony Vegas Pro 9: Batch Render Clips Separated by Markers
By mltwitz in forum EditingReplies: 0Last Post: 5th Apr 2010, 16:41 -
Sony Vegas Pro 8 - Adding VideoFX to many video clips at once.
By jnaizer in forum EditingReplies: 2Last Post: 30th Dec 2008, 21:28 -
VEGAS PRO - How to SELECT & DRAG multiple clips at once
By reniet in forum EditingReplies: 3Last Post: 19th Dec 2008, 21:22
