  1. Hi everyone, I upload mp3 songs to my iTouch using iTunes via my laptop and desktop. I never have to save my playlist since Apple iTouch remembers it on my laptop. But for some reason, on my desktop, it always erases it and I have to add back EVERY SINGLE song, even when I just want to add a couple to my iTouch.
    For example, if I have 100 mp3s on my iTouch and I have 2 new songs I want to load, I have to load 102 (not 2) songs to my iTouch. When I go to iTunes on my desktop, all my existing list is empty and I have to start over. Does anyone else experience this and am I doing something wrong since my laptop seems to always remember my playlist.
  2. Music file under LIBRARY become empty randomly. I dont get it.
  3. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    I have an iPod Touch 2nd gen 16GB model and have never had this problem but I only use one computer with iTunes.
    My guess is the fact that you have it on two computers and use it with two computers is somehow "throwing it off" or confusing it if you will.
    I'd look at the Apple forums and see if there is a solution. I'm guessing there is and that it probably is something silly easy.
    - John "FulciLives" Coleman
    Feb 2004
    Australia
    In itunes options disable the auto syncing when device connected ... its the cause to the file loss on the device.
    Mar 2007
    that is exactly the case.
  6. Hey guys, thanks for the replies, I didn't know having two computers confuse iTunes and throw it off. Would think that I can jump around computers with no problem.
    BJs, where is that located exactly? If I turn this feature off, I will be ok?
