Hello,
I have received a total of 9 discs of DVD+R (SONY DVD+R ver1.3/1x-16x 'AccuCORE') recorded by my sister on her LG RH177S (standalone DVD Recorder). It contains episodes of a drama series recorded off the television broadcasted in Asia.
However I am residing in Canada and the discs that I recieved from her are 'unplayable' on any other standalone DVD player or computer/laptop, whether Windows XP or Vista. But she say she tested and they were playable on her LG RH 177S. I highly suspect she didn't finalized the discs.
When I tried the discs on a PS2 (dvd player mode) it was unable to read the discs. I also tried on a portable DVD player (those with built-in LCD screen), was unable to read the discs.
I also tried the discs on my IBM Notebook, under Windows XP->"My Computer" it detected the the disc as "DVD-ROM".
When Right-click->Properties-> File System: RAW.
When Double-clicking (opening) it revealed its contents are 'empty'.
I understand that a DVD Video disc would usually have two folders:
- VIDEO_TS folder
- AUDIO_TS folder
I have used DVD Dercypter before (many years), excellent program if not the BEST! I read in forums that the new iteration, 'ImgBurn' is able to manually CLOSE unfinalized DVDs. (Tools-> Driver->Close ->Track/Session/Disc)
Any advise/help is greatly appreciated, Thank you!
Sincerely,
Amos
Troubleshooting Done on
- IBM Thinkpad T43, Windows XP
Ultrabay Slim "MULTI RECORDER" DVD-/+RW
(MATSHITA DVD-RAM UJ-822S)
- Working on Disc 1 ONLY (1of9)
				Results 1 to 9 of 9
	2) Imgburn 2.4.2.0
 As advised by LIGHTING_UK in the forums, I HAVE TRIED in this order
 - Tools->Drive-> Close -> Track
 (After clicking, it seems that it was successful. But 'nothing' happens, no success prompt or any alert)
 - Tools->Drive-> Close -> Session
 (So I proceeded to try 'Close->Session'.)
 (I/O Error:
 Interpretation: Check Condition
 Intrpretation: Close Track/Session
 Interpretation: Illegal Mode For This Track)
 - Tools->Drive-> Close -> Disc
 (Similar I/O Error)
 Disc 1 (After using Tools>Drive->Close->Track)
 MATSHITA DVD-RAM UJ-822S 1.03 (ATA)
 Current Profile: DVD+R
 Disc Information:
 Status: Incomplete
 Erasable: No
 Sessions: 1
 Supported Write Speeds: 2.4x
 Physical Format Information (ADIP):
 Disc ID: SONY-D21-00
 Book Type: DVD+R
 Part Version: 1
 Disc Size: 120mm
 Maximum Read Rate: Not Specified
 Number of Layers: 1
 Track Path: Parallel Track Path (PTP)
 Linear Density: 0.267 um/bit
 Track Density: 0.74 um/track
 First Physical Sector of Data Area: 196,608
 Last Physical Sector of Data Area: 2,491,711
 Last Physical Sector in Layer 0: 0
 Physical Format Information (Last Recorded):
 Book Type: DVD+R
 Part Version: 1
 Disc Size: 120mm
 Number of Layers: 1
 Disc 2 (UNTOUCHED)
 Disc Information:
 Status: Incomplete
 Erasable: No
 Free Sectors: 15,872
 Free Space: 32,505,856 bytes
 Free Time: 03:33:47 (MM:SS:FF)
 Book Type: DVD+R
 Part Version: 1
 Disc Size: 120mm
 Number of Layers: 1
 Book Type: DVD+R
 Part Version: 1
 Disc Size: 120mm
 Number of Layers: 1
	Many recomend ISOBuster for DVD video recovery, so I tried it.
 3) ISO Buster 2.4
 Disc 2 onwards (3,,4,5,6,7,8,9)
 - Using its recovery function (lengthy extraction) I was to view and extract out the VIDEO_TS folders to my hard disk. SUCCESS!! (see screenshot)
 However on Disc 1
 - that was manually "CLOSED" using ImgBurn close function ('Tools->Disc->Close->Track)
 - was detected as a blank and unrecognizable
 - hence 'unrecoverable'
	you simply need a LG dvd recorder to finalise them, also would they be in pal or ntsc?
 The latest JVC dvd recorders mv-78/79/100 are LG clones and will finalise dvd\s.
 Now I thought that +R's didn;t need finalising, however I am victoria BC if you want help , ask away as I have a machine that will finalise for you.
 I think ISOBUSTER will take the data from the discs but its a longish processPAL/NTSC problem solver.
 USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS
	On Feb 13,2009 evening, I brought all the Discs to a nearby FUTURESHOP(Canadian Electronics superstore) in Edmonton, Alberta. I explained the situation and the tech/associate kindly assisted/allowed me to try out on their LG RH398 (DVD Recorder).
 Wah Lah!
 Disc 2 onwards (3,,4,5,6,7,8,9) - UNTOUCHED
 -was viewable/playable on their LG recorder
 - the tech confirmed that the discs were not 'finalized'
 However ONLY Disc 1
 - had difficulty reading the disc
 - I suspect ImgBurn close function (Tools->Close->Track) may have "damaged/corrupted" Disc1
 - If I didn't use ImgBurn to manually close, Disc1 will probably be able to be played on their LG recorder as ALL disc were burn as a batch together for the drama series.
 So now the ONLY Problem is Disc1. Any idea why whether an unsuccessful ImgBurn 'closing' would corrupt the disc or raw data?? thanks!
	Hey "Victoriabears" thanks for your kind response, I didn't expect anyone to reply so soon!
 I actually did try ISOBuster on my IBM T43, however it took a very long time to first create the "managed image files ( .IBP and IBQ files), after 4hrs it only moved to 1%. (My notebook's DVD-RW is only a 2x)
 Hence tonight I'm trying on my room-mates HP notebook dv3, it seems faster as it progressed to 2% within 1hr+.
 It may take days??
 I will post and update the progress/results. thanks!
	Actually, it shouldn't take that long to copy the file to your hard disk.
 Since it not finalized. Can try the those files in VIDEO_RM folder.
 Once these files are in your hard disk, change the extension to .mpg.
 Use any authoring program to author it back to DVD.
  Finalizing a DVD recorded in someone else's DVD recorder ...?By Bansaw in forum Newbie / General discussionsReplies: 8Last Post: 24th Jan 2011, 22:38
  my dvd recorder no longer viewing my movies i recorded from dish,By isabel5355 in forum Newbie / General discussionsReplies: 1Last Post: 2nd Mar 2009, 11:28
  i recorded a show from my dvr to my dvd recorderBy billrhonda in forum Newbie / General discussionsReplies: 4Last Post: 6th Jan 2009, 11:48
  Difficulting with dvd recorded on a LG dvd recorderBy victoriabears in forum Newbie / General discussionsReplies: 3Last Post: 1st Oct 2008, 11:45
  Editing recorded material made by DVD recorderBy sallywil in forum EditingReplies: 2Last Post: 26th Aug 2007, 20:58
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
