Hello, everyone
I will go straight to the point, about 2 weeks ago my system was OK and I was able to burn AVI's, Xvid, DivX and DVD files to DVD's using Nero 7, TMPGEnc aw 4, Xilisoft DVD creator, VSO convet X to DVD, and now all the dvd's that I burn for some reason they are corrupted I'm not able to play them on my dvd player, I get an error on tv stating dvd on player its dirty, my PC system warning reads please insert a blank media and other times reads what do i want to do with the blank media and I can't opened the DVD's a second warning reads unable to open or read disk,
I'm thinking that it may be a codec broken or corrupted, I have uninstall the codecs K-lite and Xp and installed a most recent version of them but no luck, the problem persist, also I have uninstall the media software and reinstalled again , I went and made restore a back up file when the system was running fine and the problem it's there
Do I need to start from ground cero and clean the drive c: reinstall the OS and so on ? or there is a tool to find any problems with codecs or test the burning drive ?
thanks in advance .........and hope there is a solution with out having to clean and reinstall everything
Chamuko, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:
Thanks,Try to choose a subject that describes your topic.
Please do not use topic subjects like Help me!!! or Problems.
Moderator redwudz -
Did you switch to a different DVD media recently? What DVD media are you using?
Have you tried the burned DVDs on any other PC or DVD player?
When you burn your DVDs, do you have Nero also verify what has been burned?
Also, you might try burning your DVDs one speed slower and see what happens...
This might be a good time to use DVDRWs so that you don't waste DVDR blanks while you're experimenting.
Frank Zappa: "People wouldn't know a good movie if it smacked 'em in the face."
Is there any reason to downconvert 1080p to 720p for hd-dvd to avhcd?
By yoda313 in forum Video ConversionReplies: 15Last Post: 28th Sep 2010, 08:34 -
Any reason why most dvd player only support xvid, divx and not rmvb and mkv
By c1steady in forum Newbie / General discussionsReplies: 7Last Post: 6th Dec 2009, 20:14 -
DVD drive stopped reading DVDs for a very random reason..
By narutoball in forum DVD & Blu-ray WritersReplies: 2Last Post: 11th Oct 2008, 16:23 -
Can a DVD R/W get corrupted?
By macamba in forum Newbie / General discussionsReplies: 7Last Post: 23rd Aug 2008, 21:13 -
Another reason to make sure your next TV or DVD recorder has a QAM tuner...
By zzyzzx in forum Off topicReplies: 2Last Post: 7th Jun 2007, 15:40
