Hello all.Could someone please tell me what the line/mic jack is on a camcorder?And can you give me some examples of what sources would go into this jack?What is the difference between the line/mic jack and a line jack and a mic jack?Thank you.
Generally (and there's always exceptions)
Line might come from a mixing board or anything powered and already amplified. The line input on the camera will not supply any signal boost.
Mic would come from...a mic. The mic-in connection on the camera might supply power and/or a signal boost/amplification. -
Further, line would be consumer unbalanced high impedance similar to the red/white audio jacks on all consumer audio or video products. External mic levels for camcorders do not match pro mics or computer mics in most cases. You should get a mic designed for consumer camcorder use.
http://www.kiva.org/about
Using wireless mic with shotgun mic on Canon HF G10
By jimleben in forum AudioReplies: 5Last Post: 23rd Jan 2012, 20:11 -
LG HT 305SU (MIC IN / MIC OUT Problem)
By iamjamal in forum DVD & Blu-ray PlayersReplies: 0Last Post: 25th May 2011, 16:38 -
[Hauppauge PVR 150] Any Ways to Live-Record Mic Input AND Line-in Audio?
By darkarn in forum Capturing and VCRReplies: 0Last Post: 27th Jul 2010, 20:13 -
Mini DV - using the 1/8 " Mic input for LINE level sources
By dizzyzuma in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 32Last Post: 7th Jun 2010, 19:07 -
Using the line in port on my G5 with a headset mic...no audio
By Huntr777 in forum MacReplies: 6Last Post: 9th Nov 2009, 15:45
