I've been trying to figure this one out for a while. The sound happens just as the desktop is displayed on the screen. I can't find the WAV which gets played, otherwise I'd post the sound. It sounds like a drop of water dripping into a puddle (if that makes any sense).
do you have a read shield with an "x" on it by the clock, if so you have something disabled that windows finds wrong, such as auto updates, firewall, etc. if you have the balloon tips disabled, you can't see what it is complaining about.
If it's an ambulance...you got a chance. If it's a hearse...it's even worse!!!--Judge Alvin "JP" Valkenheiser
Want to extract audio from .vob files? Read my guide at https://www.videohelp.com/forum/viewtopic.php?t=187078 -
it would be doing if the stuff is turned off.
The *TRUE* sound of Windows !
The electronic components of the power part adopted a lot of Rubycons.
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 10:30 -
Review "HYFAI" MP3/MP4 "Nano" clone from ebay
By NG in forum Portable VideoReplies: 29Last Post: 18th Sep 2007, 05:45 -
Staxrip: "Constant Quality" vs. "Exact File Size"
By FallenAngelII in forum Video ConversionReplies: 1Last Post: 9th Aug 2007, 17:40
