Hi, I have just got an HD camcorder (panasonic HDC-SD9) and am trying to burn the AVCHD files to a standard dvd for playback in my Bluray player (Sony s350).
Nothing I try seems to work, both camcorder and bd player have the AVCHD logo so you think it would be pretty straight forward!!
I am using Imgburn and found a site that shows 'step by step' how to do this but when I try to play the disc it says 'cannot read disc'
I am confused over whether I need to include a 'CERTIFICATE' folder or not? some site say I do and some say I do not. If I do, where is this folder found??
It seems pointless to have an HD camcorder if I cant burn HD footage, When I try to play through the computer (VLC or KMPlayer) the footage is not in HD!
ARRRRRRR!!!!!
Please help......
multiavchd will author the structure for you without re-encoding
it can even do simple menus
you need to burn with udf 2.5 profile -
Works perfectly, thanks!!
I think the reason that vlc and kmplayer do not play avchd files well is my video/graphics card is crap. I've heard that they should play files in 1080 p/i but the footage is jumpy and only plays at around 8 fps, also it's not as clear as when played through the camcorder.
I'm just glad that i can now store my videos in HD format for future viewing!
Thanks again!
AVCHD to BluRay question (again)
By pijetro in forum Authoring (Blu-ray)Replies: 0Last Post: 8th Jan 2012, 15:04 -
Playback of AVCHD on Bly Ray Player Choppy
By andy90 in forum Authoring (Blu-ray)Replies: 7Last Post: 1st Oct 2011, 00:30 -
29.97fps vs. 59.94fps playback on BluRay player
By texas1 in forum Newbie / General discussionsReplies: 5Last Post: 7th Apr 2011, 01:41 -
BluRay to AVCHD - HELP!!!
By Mr.Nosmo in forum Newbie / General discussionsReplies: 3Last Post: 14th Jul 2010, 18:13 -
Bluray player won't play avchd
By jayman13 in forum Authoring (Blu-ray)Replies: 5Last Post: 2nd Mar 2009, 13:22
