hi all, newbie here could anyone please advise me how to sort this probem out , atm the cds i have are all 700mb but the files over 900 so wont burn obviously does anyone have any quick fixes to sort this
thanks kelly
	You have a few choices.
 1) Re-encode the file (this is what Baldrick's suggestion will do) to a smaller size, but you will lose quality doing this. This may not meet your definition of "quick" either as it will take time to re-encode.
 2) Use some AVI editor to split the file into 2 pieces and burn each to a separate disc. VirtualDub can do this, for example.
 3) Use higher capacity discs such as 90 or 99 minute CD-Rs (assuming you can find them) or DVDs. A 99 minute CD-R might be large enough to hold your file as is, but I'm not sure. Note that 99 minute CD-Rs are tricky to burn and some devices may not burn them correctly and they may not play back correctly. I've found 90 minute CD-Rs to be reliable for burning and playback.
  making mkv smallerBy jetli68 in forum Authoring (Blu-ray)Replies: 2Last Post: 21st Sep 2011, 12:31
  Making a 1 gig HD wmv file to smaller portionsBy OzzyWeb in forum Video ConversionReplies: 5Last Post: 28th Mar 2010, 12:10
  Trying to convert AVI to MPEG file smaller then 4gigBy Lisn2me in forum Newbie / General discussionsReplies: 7Last Post: 30th Dec 2009, 12:01
  Can I make a AVI file smaller?By baebbe in forum Newbie / General discussionsReplies: 7Last Post: 15th Aug 2008, 16:04
  Making file smaller in Adobe Premiere ProBy JustinBaker in forum EditingReplies: 2Last Post: 18th Sep 2007, 16:07
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
