I want to convert VOB-files to .mov in order to import them into Final Cut Express. I want as little compression as possible on both video and sound, I donīt want to lose any quality.
All I want to do is some cuts and editing in FCE and then burn it on a DVD.
Iīm using MacOSX 10.4.11 and ffmpegX for conversion.
Best regards
Josef
Moving you to our mac section.
I would try Cinematize or MPEG StreamCLip. -
Forgot to ask the question:
What target format should I choose in ffmegx and what other values and options should I use to get as high quality as possible?
Josef -
If going into FCE, you'll have to deal with re-rendering the footage
after import into the timeline if you go as a .mov.
If you go DV Stream, then the footage will not have to
be re-rendered upon import to the timeline.
If you choose to go .mov, then from Mpeg-Streamclip export
with quality set to no less than 95%, and choose the Apple Motion JPeg-A
codec, with AIFF 48.1 khz 16bit audio and this wil make you a HQ .mov file.
But have enough target space for the file, it will be huge.
if all you have is ffmpegx, I would go DV video, as ffmpegx will only
let you do .mov using the .mp4 codec, and that will be compressed,
and will have to re-render into FCE as DV Stream anyway for
it to be usable into the Timeline."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
Thanks for quick and helpful advices!
I used MPEG StreamClip, it worked out just fine! -
U r welcome!
Urban Mac User
Covert .VOB to AVI with out losing quality. How ?!
By SB4 in forum Video ConversionReplies: 7Last Post: 29th Feb 2012, 19:46 -
Best format to convert HD videos without losing quality?
By fabitos in forum Video ConversionReplies: 19Last Post: 4th Dec 2011, 00:22 -
MKV to AVI - can you convert without losing quality?
By OM2 in forum Newbie / General discussionsReplies: 4Last Post: 12th Nov 2010, 08:52 -
VOB to something perceivable without losing quality and multichapters
By romashkin in forum Video ConversionReplies: 6Last Post: 14th Apr 2010, 15:33 -
Convert AVI to MPEG-1 without losing quality: What tool?
By GeekyChocolate in forum Video ConversionReplies: 8Last Post: 28th Mar 2009, 17:42
