When selecting items to generate a report there is a provision to "not select" certain files. Is there a way to "not select" certain folders. Several weeks ago I contacted the author(support) but have not heard from him.
In the "Where Is It?" help file, it says:
I have put folders in the query rather than files by selecting the advanced search option "Search by Item Paths" and then putting a not in front of it, and it works.How to search for items that do NOT match certain criteria
To search for items that do not match certain criteria you will have to use the advanced searching. Just prepare your search expression as you would normally do, put the whole expression in parentheses, and put the NOT command at the front.
For example, to search for all files that are not .DOC or .TXT documents, your expression will look something like that:
not ((File Mask = "*.doc") or (File Mask = "*.txt"))
See Also
Using Search Dialog
How to search by more than one criteria at once
How to search by narrowing down the results
For example:
not (Item Path includes: "archived")
-drjtechThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
drjtech,
Couldn't get it to work. What I'm trying to do is search thru movie data base and not get audio_ts and video_ts folders names. I set up the regular search with *.* to get everything and then setup advanced search like you said.
If this is not correct would you set me up with a complete search procedure? If I can get this to work I think that I can do the other searches by myself. Hate to be so picky but obviously I am doing something wrong.
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
A "why did they do that?" and question about "retro-editing" (if you will)
By takearushfan in forum EditingReplies: 10Last Post: 31st Jan 2010, 21:02 -
AutoGK question: Can I "Force IVTC" on "Hard-encoded NTSC&am
By BozQ in forum DVD RippingReplies: 11Last Post: 12th Jun 2009, 13:46 -
question about how to remove this software, "wmfdist95.exe" WMA
By jimdagys in forum ComputerReplies: 2Last Post: 15th May 2007, 04:07
