Results 1 to 14 of 14
  1. Member RogerTango's Avatar
    Nov 2007
    http://danielvlog.com/
    I am looking for "beta testers" to check the stream on the page above.
    It is a streaming MP4 clip, a section of what I shot off my Canon HF10 tonight.
    If you have success or failure either one, please report the following:
    1) Browser (Firefox, MSIE, Etc)
    2) OS (Mac, XP, Vista, Etc)
    3) Adobe Flash Ver (10, Etc)
    It is supposed to need version 10 or better.
    Comments about video quality is welcome. I will be posting back with details on how I did it if there is enough interest.
    Thanks for your help!
    Andrew
  2. Pretty boring video.
    1. Internet Explorer
    2. XP SP2
    3. Some version of 9
    The quality seems OK. Personally, I don't care how you did it. Maybe others do.
    1. Firefox 3.
    2. XP SP3
    3. 10.
    And yep good quality.
    If it's mp4 with h264 video you just need version 9.0.115 or higher.
    Dec 2005
    Canada
    Firefox
    XP
    9
    Good quality.
  5. Annoying drop-field deinterlace.
  6. 1) IE
    2) XP SP2
    3) 10
    decent quality, but you could do better using different settings - at least avc main or high profile. This would allow cabac which itself provides for 20% better compression on average, (or better quality at the same bitrate) - which is useful for web streaming / reducing bandwidth expenses
    if you bobbed it and made jagabo happy, slower computers might have difficulty with playback. I don't know who your audience primarily consists of
  7. I wouldn't bob it. Use a smart deinterlacer. Even better, use a camcorder that shoots progressive.
    Jan 2007
    Republic of Texas
    Forgive me for posting without providing any real helpful advice, but I just couldn't resist commenting about the title of this thread: "Check my stream please?" -- Sounds like a urology issue.
  9. Member RogerTango's Avatar
    Nov 2007
    Im pretty sure the source and encoded MP4 are both 30p, why would I want to deinterlace?
    "at least avc main or high profile"
    Ill look into that, I can also use x264.exe- Ill look at the help and see what the switches are, if I can set the profile as you suggest.
    "Even better, use a camcorder that shoots progressive. "
    Canon HF10, the source is already progressive. I guess you didnt read the first post.
    "Sounds like a urology issue"
    Uh Oh. It does, doesnt it?
    " 9.0.115"
    Thx rick, good info!
    Thanks,
    Andrew
  10. Member RogerTango's Avatar
    Nov 2007
    Okay, MediaInfo says:
    Scan type : Interlaced
    Scan order : Top Field First
    If your interested, heres the full spit on MediaInfo on one of my MTS files:
    General
    Complete name : F:\DigitalVideo\12 Feb 09 - Jujitsu\00003.MTS
    Format : BDAV
    Format/Info : BluRay Video
    File size : 2.02 MiB
    Duration : 989ms
    Overall bit rate : 17.1 Mbps
    Maximum Overall bit rate : 18.0 Mbps
    Video
    Menu ID : 1 (0x1)
    Format : AVC
    Format profile : High@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 2 frames
    Duration : 1s 0ms
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16/9
    Frame rate : 29.970 fps
    Resolution : 24 bits
    Colorimetry : 4:2:0
    Audio
    Menu ID : 1 (0x1)
    Format : AC-3
    Format/Info : Audio Coding 3
    Duration : 989ms
    Bit rate mode : Constant
    Bit rate : 256 Kbps
    Channel(s) : 2 channels
    Channel positions : L R
    Sampling rate : 48.0 KHz
    Video delay : -67ms
    Andrew
    That JW flash player is pretty slick..I use it on my site with the playlist attached at the bottom.
  12. 1080i video that's been drop field deinterlaced and resized down to SD resolution (in that order) usually has fewer buzzing edges than your streamed video. I suspect you downscaled to 480i with an interlace aware resizer, then drop field deinterlaced and scaled to 720x400.
  13. Member RogerTango's Avatar
    Nov 2007
    I just got done writing a program (GUI frontend for ffmpeg and lame) to convert MTS to AVI with XviD and MP3 if anyone wants a copy, let me know. It also does deinterlacing and resizing (via AVISynth).
    Andrew
  14. works fine in firefox 3.
    I like to have fun!
    Want to have fun yourself? Visit my website at:
    http://www.mikeytatelive.com.
