Weird thing. WMP11 won't play VOB files, blank screen, it kinda doesn't seem to even find the file, here's what happens:
I load a .mpg or .avi or .mkv file:
- WMP says 'playing Red Hot Chili Peppers - Can't Stop'
- In properties =>file tab; it says 'Location: I:\music videos D1\Red Hot Chili Peppers - Can't Stop.mpg'
I load a .vob file:
- WMP says 'Playing I'
- In properties =>file tab; it says 'Location: wmpdvd://I?contentdir=I:\music videos D1'
I have Mpeg2 decoders installed, I tried using ffdshow's codec, with and without the 'DVD decoding' option. No change whatsoever.
(Oh, and please don't say ' just use blahplayer-x or blehplayer-y'. I want to be able to playback and make playlists for all possible videofiles and I want it in WMP11.)
Results 1 to 22 of 22
Originally Posted by poisondeathray -
Originally Posted by raffie
You can try Demultiplex the vob (e.g. DGIndex), use mkvmergegui and put the mpeg2 video, and "x" audio into mkv . Enter the DAR information in the format specific options tab. I tested it and it works in WMP11.
Cheers -
Some info by GSPOT:
CONT_BASETYPE MPEG (.MPG/.MPEG/.VOB)
CONT_BYTES_MISSING
CONT_INTERLEAVE_ALIGN
CONT_INTERLEAVE_PRELOAD
CONT_INTERLEAVE_TIME
CONT_SUBTYPE
CONT_TOTAL_BITRATE 10080
VIDEO_BITRATE 5000
VIDEO_CODEC_NAME MPEG-2
VIDEO_CODEC_STATUS Codec(s) are Installed
VIDEO_CODEC_TYPE MPEG2
VIDEO_DAR 1.333
VIDEO_DURATION 3:22.204
VIDEO_FIELDS_PER_SEC 59.940
VIDEO_FRAME_COUNT 6060
VIDEO_FRAMES_PER_SEC 29.970
VIDEO_MPEG2 MPEG-2
AUDIO_CODEC DVD_LPCM_AUDIO
AUDIO_CODEC_STATUS Codec(s) are Installed
AUDIO_MPEG_STREAM_ID 0xbd
AUDIO_MPEG_SUBSTREAM_ID 0xa0
AUDIO_SAMPLE_RATE
I'm not entirely sure what splitter is used, I have Haali installed but I'm not sure it's applied when using VOB files. -
You can render the file in graphstudio to identify the current splitter
I´m watching VOBs directly in WMP 11, no problem.
First check with DecCheck.exe (available for free from Microsoft) if your used MPEG2 decoder is compatible with WMP 11. And if it´s set to preferred decoder.
Than don´t allow WMP to automatically download missing codecs.
Don´t let WMP search for missing codecs.
If this doesn´t help, then you can still make some changes in the registry.
But first rename VOB to MPG and try, just to see what happens... -
Originally Posted by NoBuddy
I have already been tinkering about in the registry, to no avail unfortunatelyThought I'd use the same info used for MPG files, copy that and use it for VOB files. No-go. (set everything back as it was) If you'd know what to do, it would be much appreciated.
I had the problem after installing Mediainfo, it changed the Default program to open the .ifo from WMP to Mediainfo.
If you want to play a .vob the problem is that alot of the DVD software splits the .vob chapters into 1Gb chunks, thus ending up with only a portion of the chapter in each .vob. I think in DVDShrink and IMGBurn you can change in the options to prevent the chapters from being split into 1Gb chunks. I am not sure if any other DVD sofware allows this, I have not been converting for quite some time so I am a little rusty. -
Originally Posted by kasius
When you select a VOB file WMP appears to enter its DVD playing mode and requires a full VOB/IFO set. And it starts playing the first VOB of the set, not the selected VOB. It doesn't seem to use any DirectShow installed VOB/MPG file reader/splitter. Aside from renaming the file I couldn't find any way around this. Another worthless WMP "feature".
Originally Posted by Amerzone
Thanks for your reply. I'm @ the office right now, so I may be wrong, but when I try to open an mkv with WMP, I get an error message that "this file type is not supported" (or something similar). It doesn't try to download any codecs, or whatever, it only complains that this file type is not supported. As I said, in MPC the mkv files play perfectly (and ffdshow A/V decoder and Haali splitter icons appear at the systray). I have NOT installed any codec pack (I hate them...)
Originally Posted by jagabo
Now, renaming extentions is no way aaf going about things. It would mean I'd have to remux every VOB I have (and will get) to MPG, and I'm not gonna do that, that would be the hard/stupid/long way around when there's certainly an easy solution out there...[/video]
Which codecs to play .vob files?
By chewie8008 in forum Software PlayingReplies: 21Last Post: 8th Dec 2013, 16:18 -
No sound on MPEG-2 files in WMP11 after uninstalling 3rd party codecs
By brassplyer in forum Software PlayingReplies: 1Last Post: 12th Jan 2012, 03:15 -
please recommend movie codecs for XP/WMP11
By JohnnyBob in forum Software PlayingReplies: 3Last Post: 15th Aug 2011, 02:57 -
missing audio codecs WMP11 ??
By DirtBikeMike in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jul 2010, 10:30 -
WMP11/Vista (Business) Codecs
By ctdvd in forum Software PlayingReplies: 3Last Post: 1st Mar 2009, 11:52
