I have Pinnacle DV Studio 7 package with a DV500 Plus capture card, which always worked fine under Windows 98 then on Windows XP. The last time I used it was November 2007 on XP with the latest service pack at the time, and there were no issues.
However, due to a virus, I recently had to reinstall Windows XP, put in all the latest upgrades (SP3, etc) and now I have problems installing the DV Studio 7 package. With the DV500 Plus plugged into the PCI slot, I run the Pinnacle Studio 7 installation CD supplied. The Studio 7 software installs fine, then the next stage when it's running the AV/DV Hardware installation, I get windows error (the type where it gives me the option to send the error to Microsoft) and I can't get passed this stage of the installation. As a result when I run the Studio 7 software, it lists my other capture devices (video card, webcam) but not the DV500 card (it should be listed as AV/DV analog, if I remember).
I can't find anything on the Pinnacle website on this, nor any updated drivers/patches for this package.
Has annyone else had this problem and how did they go around it?
Thanks.
http://www.pinnaclesys.com/PublicSite/us/Products/Consumer+Products/Advanced+Video/DV5...mode=documents
Hope that helps. The SP3 seems to have problems with certain programs (or the other way around), Iīd stick with SP2 only (and have since SP3 also gave trouble). I have a Studio DeLuxe card (with Sudio V. 9), simmilar but lacking support for Adobe Premiere (too bad because edit with Premiere)
This is what I would do; turn off and unplug the computer, remove the DV500 card (good time for some careful cleaning with a can of compressed air and a brush), reinstall windows XP, drivers, etc...(but only with SP2), turn off and unplug again, install DV500 card and turn on, when Windows says itīs found new hardware cancel the installation wizard and search in your install CDs for your AV/DV driver (in my case itīs called PCLEBendPCI.exe), restart and then proceed to install your Studio Software (and upgrades downloaded from the Pinnacle site)
Good luck -
Pinnacle stopped support for these cards in the early 2000's.
I maintain an old PIII dual boot Win98se/XP SP1 machine for Pinnacle DC-30+ and a DC-1000 with Premiere v6.5 and a SCSI RAID all frozen in time around 2004. I don't put this machine online or connect it to the network for fear of virus attack. So far it still works if I need to revisit an old Premiere project.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Easycap 2.0 Installation.
By xAnonymousx in forum Capturing and VCRReplies: 2Last Post: 7th Jun 2010, 08:37 -
VLC installation crashes PC
By hungledink in forum Software PlayingReplies: 1Last Post: 29th Nov 2009, 12:30 -
my current camera (jvc gr dv500) is messed up. making noises n weird lines
By bojadada in forum Newbie / General discussionsReplies: 4Last Post: 24th May 2009, 11:09 -
Installation Failures
By Frustrtated in forum Video ConversionReplies: 1Last Post: 29th Sep 2008, 19:06 -
Capture with DC 10 Pinnacle Card with OS Win 2k and Pinnacle studio11
By fjmr in forum Capturing and VCRReplies: 2Last Post: 7th Apr 2008, 18:02
