    Apr 2008
    Dream Realm
    My capture device seems to record ONLY at 16:9, which is a bit unfortunate. It's not so bad when watching stuff on TV, since I can change the TV's resolution on the fly, but that doesn't mean anything regarding the capture device. It stretches out 3:4 images to 16:9.
    Is there a program that can scrunch 16:9 up to 3:4?
    Apr 2004
    Miskatonic U
    What is your capture device ?
    What resolution are you capturing to ?
    What is your source ?
    Yes, it is possible through resizing, but if your device can be tuned to capture correctly in the first place, it will save you time and quality.
    Read my blog here.
    Apr 2008
    Dream Realm
    It can't. I've thought to look at options and such already. And it's HD PVR.
    http://www.hauppauge.com/site/products/data_hdpvr.html
