Can anyone here recommend a good, reliable VCR for under $100? I now the new VCRs suck (cheap build quality/components) so I'm sure I'll have to go the ebay/used/refurb route, but I've got a friend in need for a reliable VCR and they're willing to go on ebay. They don't need anything fancy, just a good VCR for playback (they don't need it for transfers or anything).
So, can anyone recommend any good models that are easily obtainable?
Thanks!
Ministry88,
If you (or your friend) are looking for a deck for playback solutions, then you don't need a VCR (Video Cassette Recorder) but a VCP (Video Cassette Player). If space is of any concern, then I would recommend the compact VCP SVP-DC1 from Sony. However, if you want to power it via an electrical outlet, then you need an AC to DC adapter, if I recall correctly, but they are easy to find. Anyway, the important thing is that this deck is well below USD 100.00. There are some on Ebay right now for USD 35.00 plus shipping.
Best of luck,
Carlos Albert Laca
Looking for Good VCR for Capturing
By zerowalker in forum Capturing and VCRReplies: 0Last Post: 28th Nov 2011, 18:56 -
Mitsubishi VCR's - Any Good Alternatives to HS-U748 or 778
By jbd5010 in forum Capturing and VCRReplies: 1Last Post: 2nd Mar 2011, 00:29 -
Sony SL-HF600 Beta Vcr for $35 good deal?
By ryangarfield in forum Newbie / General discussionsReplies: 2Last Post: 25th Jun 2010, 22:56 -
Looking for a good dvd recorder vcr combo
By KateP in forum DVD & Blu-ray RecordersReplies: 10Last Post: 20th May 2009, 19:43 -
VCR'S which is good?
By demonwarrior in forum Newbie / General discussionsReplies: 13Last Post: 14th Dec 2007, 06:33
