hi i installed real alternative already but still can't play .rmvb files in my WMP ? what am i missing ?
i want to play it in WMP only.. please
Results 1 to 13 of 13
real alternative works for me for wmp / mpc
test it out on mpc, if it doesn't work, try re-installing it
are you sure the videos are not corrupted? -
Make sure only 1 player is active at 1 time or you get overlay issues (i.e. close all other media players)
another thing i tried playing 5 or 6 rmvb or rm files.. i could play at least 2 or 3 with WMP but the others dont work with WMP only. (all can be played with MPC)
i got messages like
Windows Media Player encountered a problem while playing the file. For additional assistance, click Web Help.
or
Windows Media Player cannot play the file. The Player might not support the file type or might not support the codec that was used to compress the file.
actually before i had this problem i had MEGA K-Lite Codec and could play everything but alot of people said codec packs were no good and i uninstalled it and i reinstalled real alternative... now i have this problem -
actually i too like MPC but i can't get MPC to http stream .avi files...
it says "Opening..." and is stuck there forever..
i tried streaming the same avi file with WMP:
http://www.megaupload.com/?d=IDAUJF50
and it worked... so thats why i am using WMP... if i can fix the problem in MPC i would like to fix it -
Let me repeat what I posted in your cross-post of this issue
You are trying to stream a non-streaming format from a non-streaming site - why would you expect it to work consistently ?
VLC is by far the best player for viewing incomplete or partially downloaded avi files. That is essentially what you are trying to do in this case.
MPC is not doing what you want because you are trying to do something silly, and MPC isn't designed to do it.Read my blog here.
If I want to use closed captions, MPC and VLC can't display them, but WMP can. PowerDVD 5 does as well, but mixes in any other data that my DVD recorder captured in addition to line 21 closed captions, resulting in garbled text. So WMP is not entirely redundant for some of us, though I do agree it isn't the best choice for what the OP wants to do.Originally Posted by poisondeathray
Thanks for the suggestion, but I'll pass. I don't want to clutter my system with more codecs that I won't use, and install a piece of software my antivirus won't like, just to add functionality to MPC that WMP already has.Originally Posted by poisondeathray
I only use a software player for watching DVDs. I tried MPC and VLC, and for that, I didn't find them any more useful the two software players I already had. For one thing VLC is less tolerant of disc read errors than either WMP or PowerDVD 5. (I get those sometimes when the spindle on my DVD recorder needs a good cleaning.)
How the make wmp automaticly play?
By obsh in forum Video Streaming DownloadingReplies: 0Last Post: 6th Sep 2011, 05:14 -
MKV DvdRip Xvid Downloads Play on WMP but wont play on my PVR
By dashas in forum Newbie / General discussionsReplies: 7Last Post: 25th May 2011, 06:15 -
Codecs for WMM | WMP | VirtualDub
By TheGame111 in forum EditingReplies: 1Last Post: 22nd Dec 2010, 18:42 -
rmvb with chinese characters won't play?
By js2k in forum Newbie / General discussionsReplies: 6Last Post: 15th Nov 2009, 12:39 -
samsung 1080p9 wanna play rmvb movies
By phantomeduke in forum Video ConversionReplies: 1Last Post: 29th Jul 2009, 13:50
