I have no clue on how to burn this WMV HD file I have on to a disc. The file is 11.5 gigs. Can someone show me how I can go about doing this? I just want to back this up on to a DvD so I can watch it on a later time.
Thank-you
Results 1 to 13 of 13
You could split the file with something like this: http://www.solveigmm.com/?Products&id=VideoSplitter#Buy_now_SolveigMM_Video_Splitter Probably other WMV splitters out there that other members know about.
You could split it to burn as a data file on two dual layer DVD discs, Verbatim DL + recommended. -
Any splitters that are easy to use and cost effective namely $0.00 lol . Also, what do you use to burn dual layer discs? I'm very new at this sort of thing.
Alternatives are to burn to Blu-ray $$ Or re-encode to a lower quality/more compressed format. A DVD-9 DL disc holds about 7.95GB, a single layer DVD-5 disc holds about 4.37GBs. Re-encoding can take quite a bit of time. It takes about six hours for me to re-encode a Blu-ray 25GB file to a 7.95GB MKV file. That's with a quad core running at 3.3GHz and and a two pass encode.
Just use HJSplit or any file splitter to break it into ~4 GB pieces. Burn onto DVDs. Restore the pieces later with the same software (the individual pieces won't be playable, you have to join them back together).
Hmm, so basically I have to re-encode them to a lower quality and more compressed version ( under 8 gigs). Or split them up (kinda pointless, seeing as it cant be played from disc because you have to rejoin them again just to watch). This is annoying, never thought this would be so much work. Better off just getting original retail blue ray.
Originally Posted by jman98
Encoding and burning and capturing plus splitting is all done by trial and error at first and reading lots of info from sources such as google and videohelp,Learning all this stuff can be trying,you just gotta be patient and try what is suggested.After you get the hang of it then you can try different methods.
I had to learn all about blu-ray and avchd and how to encode and author and burn it and what tools to use and hardware to buy but once i got it sorted out i wont go back to dvd.Also its fun doing this type of stuff if its your type of hobby/work.I think,therefore i am a hamster. -
So, There is a way then? So using Asfbin I can split the file into 3 dvds and play each disc separately. Anything in that program I need to know before I begin doing a trial and error on it?
ok, I just tried several times and have no clue how to us this program asfbin. Keeps giving me an out file that is 2kb size? what am i supposed to do with that?
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 12:42 -
Why are cdr burn rings lighter than dvdr burn rings?
By yoda313 in forum Newbie / General discussionsReplies: 4Last Post: 27th May 2010, 17:55 -
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 04:26 -
Advice required when trying to burn with img burn
By IPBR21054 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 1st Aug 2009, 16:29 -
Burn Software with Menu & burn xvid avi
By CynthiaBlue in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2007, 20:46
