Evening All,
I am using AVsToDVD to burn a number of cartoons to DVD. I took them off my PVR, converted to MPEG with MPEG Stream Clip and an now burning them. First up, I put 12 of them one a DVD (they're only 4 minutes long each). When I put the DVD in the player, I get the menu with all 12 titles, but when I play them, they are all using the audio from the same title!! I tried burning fewer titles (9) and got an even more bizarre problem - all titles still use the same audio, but the audio is not even from one of the titles that I burnt!!
Does AvsToDVD cope well with multiple titles? The sound is fine on the MPGs when I view with VideoLAN - I did have two audio tracks when I pulled them off the PVR, had to delete one using MPEG Stream Clip. I have had the chapter interval set at 5 minutes and 999 minutes, didn't seem to make a difference.
Any thoughts?
Cheers,
Al.
Results 1 to 16 of 16
I can't preview in AVsToDVD as I don't have the Quicktime support installed.Originally Posted by _MrC_
I downloaded the new version of AVsToDVD last night and tried it out, but when I tried to load in my MPGs it said that it was unable to detect playtime and I would have to enter it manually - the old version didn't do this. Does this point to a problem with my MPGs?
I think this is the log (called DVD_3.log in the My Documents folder):
<11-02-2009 21:38:44>
START PROCESS
DVD SETTINGS
DVD Titles number: 9
DVD Video Standard: PAL
DVD Chapters Interval: 999 min
DVD Menu: Static DVD Menu
DVD Label: DVD
DVD Burning Drive: D: TSSTcorp DVD+-RW TS-L632H D300
DVD Burning Speed: 2x
DVD Size: 453/4435 MB (10%)
DVD Output Setup: Burn DVD
Delete Temp Process Files: Yes
Delete Working Files: Yes
Edit Command Parameters: No
Save Log file: Yes
Output Folder: C:\Documents and Settings\Administrator\My Documents
TITLE 1 SOURCE FILES
Video: C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Hiccups.mpg
Info: MPEG-2 Video - 276 kbps - 720x576 - DAR 1.778 - 25 fps - PPF - 13:04 minutes - 19609 frames
Audio: C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Hiccups.mpg
Info: MPEG-1 Audio layer 2 - 192 kbps - CBR - 48000Hz - 2ch - 13:03 minutes
Subs:
[MediaInfoLib - v0.7.8]
AVISYNTH SCRIPT
Import("C:\Program Files\AVStoDVD\Lib\A2DSource.avsi")
Video = A2DVideoSource("C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Hiccups.mpg", CacheFolder = "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp")
Video = Video.ConvertToYV12
Video = Video.Lanczos4Resize(720,576)
Audio = A2DAudioSource("C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Hiccups.mpg", CacheFolder = "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp")
AudioDub(Video, Audio)
START VIDEO DEMUXING OPERATIONS
Target Video FileSize: 25.8 MB
FFmpeg Parameters: -i "C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Hiccups.mpg" -vcodec copy "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_01_Hiccups.m2v"
<11-02-2009 21:38:47>
END VIDEO ENCODING OPERATIONS
Created File: C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_01_Hiccups.m2v (38.4 MB)
START TRANSCODING OPERATIONS
ReJig Parameters: -size 25 -o "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_01_Hiccups.ReJig.m2v" -i "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_01_Hiccups.m2v" -auto -close -quiet
<11-02-2009 21:38:50>
END TRANSCODING OPERATIONS
Transcoding excuted on File: C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_01_Hiccups.m2v (25.5 MB)
<11-02-2009 21:38:51>
OUTPUT VIDEO INFO:
Filename: DVD_3_Title_01_Hiccups
Filesize: 26729307 Byte
Format: MPEG Video
Time: 13:04 minutes
Compression: MPEG-2 Video
AvgBitRate: 270
Resolution: 720x576
Aspect Ratio: 1.778
FPS: 25.000
Interlacement: PPF
Frames: 19609
START AUDIO ENCODING OPERATIONS
FFmpeg (WAV) Parameters: -i "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_3_Title_01 _Hiccups.avs" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_3_Title_01 _Hiccups.wav"
Aften (AC3) Parameters: -b 192 "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_3_Title_01 _Hiccups.wav" "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_01_Hiccups.ac3"
<11-02-2009 21:39:10>
END AUDIO ENCODING OPERATIONS
Created File: C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_01_Hiccups.ac3 (6.8 MB)
TITLE 2 SOURCE FILES
Video: C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Babysitting.mpg
Info: MPEG-2 Video - 558 kbps - 720x576 - DAR 1.778 - 25 fps - PPF - 9:50 minutes - 14773 frames
Audio: C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Babysitting.mpg
Info: MPEG-1 Audio layer 2 - 192 kbps - CBR - 48000Hz - 2ch - 9:50 minutes
Subs:
AVISYNTH SCRIPT
Video = A2DVideoSource("C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Babysitting.mpg", CacheFolder = "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp")
Audio = A2DAudioSource("C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Babysitting.mpg", CacheFolder = "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp")
Target Video FileSize: 39.3 MB
FFmpeg Parameters: -i "C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Babysitting.mpg" -vcodec copy "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_02_Babysitting.m2v"
<11-02-2009 21:39:17>
Created File: C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_02_Babysitting.m2v (47.3 MB)
ReJig Parameters: -size 39 -o "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_02_Babysitting.ReJig.m2v" -i "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_02_Babysitting.m2v" -auto -close -quiet
<11-02-2009 21:39:20>
Transcoding excuted on File: C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_02_Babysitting.m2v (39 MB)
OUTPUT VIDEO INFO:
Filename: DVD_3_Title_02_Babysitting
Filesize: 40939870 Byte
Format: MPEG Video
Time: 9:51 minutes
AvgBitRate: 557
Resolution: 720x576
Aspect Ratio: 1.778
FPS: 25.000
Interlacement: PPF
Frames: 14773
FFmpeg (WAV) Parameters: -i "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_3_Title_02 _Babysitting.avs" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_3_Title_02 _Babysitting.wav"
Aften (AC3) Parameters: -b 192 "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_3_Title_02 _Babysitting.wav" "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_02_Babysitting.ac3"
<11-02-2009 21:39:37>
Created File: C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_02_Babysitting.ac3 (6.8 MB)
TITLE 3 SOURCE FILES
Video: C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Best Friend.mpg
Info: MPEG-2 Video - 580 kbps - 720x576 - DAR 1.778 - 25 fps - - 9:12 minutes - 13813 frames
Audio: C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Best Friend.mpg
Info: MPEG-1 Audio layer 2 - 192 kbps - CBR - 48000Hz - 2ch - 9:12 minutes
Subs:
AVISYNTH SCRIPT
Video = A2DVideoSource("C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Best Friend.mpg", CacheFolder = "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp")
Audio = A2DAudioSource("C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Best Friend.mpg", CacheFolder = "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp")
Target Video FileSize: 38.2 MB
FFmpeg Parameters: -i "C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Best Friend.mpg" -vcodec copy "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_03_Best Friend.m2v"
<11-02-2009 21:39:42>
Created File: C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_03_Best Friend.m2v (45.2 MB)
ReJig Parameters: -size 38 -o "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_03_Best Friend.ReJig.m2v" -i "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_03_Best Friend.m2v" -auto -close -quiet
<11-02-2009 21:39:45>
Transcoding excuted on File: C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_03_Best Friend.m2v (38 MB)
OUTPUT VIDEO INFO:
Filename: DVD_3_Title_03_Best Friend
Filesize: 39863312 Byte
Format: MPEG Video
Time: 9:13 minutes
AvgBitRate: 580
Resolution: 720x576
Aspect Ratio: 1.778
FPS: 25.000
Interlacement:
Frames: 13813
FFmpeg (WAV) Parameters: -i "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_3_Title_03 _Best Friend.avs" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_3_Title_03 _Best Friend.wav"
Aften (AC3) Parameters: -b 192 "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_3_Title_03 _Best Friend.wav" "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_03_Best Friend.ac3"
<11-02-2009 21:40:02>
Created File: C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_03_Best Friend.ac3 (6.8 MB)
TITLE 4 SOURCE FILES
Video: C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Bicycles.mpg
Info: MPEG-2 Video - 463 kbps - 720x576 - DAR 1.778 - 25 fps - PPF - 10:14 minutes - 15361 frames
Audio: C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Bicycles.mpg
Info: MPEG-1 Audio layer 2 - 192 kbps - CBR - 48000Hz - 2ch - 10:14 minutes
Subs:
AVISYNTH SCRIPT
Video = A2DVideoSource("C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Bicycles.mpg", CacheFolder = "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp")
Audio = A2DAudioSource("C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Bicycles.mpg", CacheFolder = "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp")
Target Video FileSize: 33.9 MB
FFmpeg Parameters: -i "C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Bicycles.mpg" -vcodec copy "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_04_Bicycles.m2v"
<11-02-2009 21:40:06>
Created File: C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_04_Bicycles.m2v (42.2 MB)
ReJig Parameters: -size 33 -o "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_04_Bicycles.ReJig.m2v" -i "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_04_Bicycles.m2v" -auto -close -quiet
<11-02-2009 21:40:10>
Transcoding excuted on File: C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_04_Bicycles.m2v (33.1 MB)
OUTPUT VIDEO INFO:
Filename: DVD_3_Title_04_Bicycles
Filesize: 34668510 Byte
Format: MPEG Video
Time: 10:14 minutes
AvgBitRate: 452
Resolution: 720x576
Aspect Ratio: 1.778
FPS: 25.000
Interlacement: PPF
Frames: 15361
FFmpeg (WAV) Parameters: -i "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_3_Title_04 _Bicycles.avs" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_3_Title_04 _Bicycles.wav"
Aften (AC3) Parameters: -b 192 "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_3_Title_04 _Bicycles.wav" "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_04_Bicycles.ac3"
<11-02-2009 21:40:27>
Created File: C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_04_Bicycles.ac3 (6.8 MB)
TITLE 5 SOURCE FILES
Video: C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Cold Winter Day.mpg
Info: MPEG-2 Video - 601 kbps - 720x576 - DAR 1.778 - 25 fps - PPF - 9:36 minutes - 14401 frames
Audio: C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Cold Winter Day.mpg
Info: MPEG-1 Audio layer 2 - 192 kbps - CBR - 48000Hz - 2ch - 9:35 minutes
Subs:
AVISYNTH SCRIPT
Video = A2DVideoSource("C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Cold Winter Day.mpg", CacheFolder = "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp")
Audio = A2DAudioSource("C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Cold Winter Day.mpg", CacheFolder = "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp")
Target Video FileSize: 41.3 MB
FFmpeg Parameters: -i "C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Cold Winter Day.mpg" -vcodec copy "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_05_Cold Winter Day.m2v"
<11-02-2009 21:40:32>
Created File: C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_05_Cold Winter Day.m2v (48.9 MB)
ReJig Parameters: -size 41 -o "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_05_Cold Winter Day.ReJig.m2v" -i "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_05_Cold Winter Day.m2v" -auto -close -quiet
<11-02-2009 21:40:36>
Transcoding excuted on File: C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_05_Cold Winter Day.m2v (41 MB)
OUTPUT VIDEO INFO:
Filename: DVD_3_Title_05_Cold Winter Day
Filesize: 42996941 Byte
Format: MPEG Video
Time: 9:36 minutes
AvgBitRate: 601
Resolution: 720x576
Aspect Ratio: 1.778
FPS: 25.000
Interlacement: PPF
Frames: 14401
FFmpeg (WAV) Parameters: -i "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_3_Title_05 _Cold Winter Day.avs" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_3_Title_05 _Cold Winter Day.wav"
Aften (AC3) Parameters: -b 192 "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_3_Title_05 _Cold Winter Day.wav" "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_05_Cold Winter Day.ac3"
<11-02-2009 21:40:52>
Created File: C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_05_Cold Winter Day.ac3 (6.8 MB)
TITLE 6 SOURCE FILES
Video: C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Daddy Pig's Birthday.mpg
Info: MPEG-2 Video - 1005 kbps - 720x576 - DAR 1.778 - 25 fps - PPF - 6:01 minutes - 9025 frames
Audio: C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Daddy Pig's Birthday.mpg
Info: MPEG-1 Audio layer 2 - 192 kbps - CBR - 48000Hz - 2ch - 6:00 minutes
Subs:
AVISYNTH SCRIPT
Video = A2DVideoSource("C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Daddy Pig's Birthday.mpg", CacheFolder = "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp")
Audio = A2DAudioSource("C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Daddy Pig's Birthday.mpg", CacheFolder = "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp")
Target Video FileSize: 43.2 MB
FFmpeg Parameters: -i "C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Daddy Pig's Birthday.mpg" -vcodec copy "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_06_Daddy Pig's Birthday.m2v"
<11-02-2009 21:40:56>
Created File: C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_06_Daddy Pig's Birthday.m2v (45.9 MB)
ReJig Parameters: -size 43 -o "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_06_Daddy Pig's Birthday.ReJig.m2v" -i "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_06_Daddy Pig's Birthday.m2v" -auto -close -quiet
<11-02-2009 21:40:58>
Transcoding excuted on File: C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_06_Daddy Pig's Birthday.m2v (42.8 MB)
OUTPUT VIDEO INFO:
Filename: DVD_3_Title_06_Daddy Pig's Birthday
Filesize: 44826793 Byte
Format: MPEG Video
Time: 6:01 minutes
AvgBitRate: 1004
Resolution: 720x576
Aspect Ratio: 1.778
FPS: 25.000
Interlacement: PPF
Frames: 9025
FFmpeg (WAV) Parameters: -i "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_3_Title_06 _Daddy Pig's Birthday.avs" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_3_Title_06 _Daddy Pig's Birthday.wav"
Aften (AC3) Parameters: -b 192 "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_3_Title_06 _Daddy Pig's Birthday.wav" "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_06_Daddy Pig's Birthday.ac3"
<11-02-2009 21:41:15>
Created File: C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_06_Daddy Pig's Birthday.ac3 (6.8 MB)
TITLE 7 SOURCE FILES
Video: C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Dressing Up.mpg
Info: MPEG-2 Video - 382 kbps - 720x576 - DAR 1.778 - 25 fps - PPF - 12:03 minutes - 18085 frames
Audio: C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Dressing Up.mpg
Info: MPEG-1 Audio layer 2 - 192 kbps - CBR - 48000Hz - 2ch - 12:03 minutes
Subs:
AVISYNTH SCRIPT
Video = A2DVideoSource("C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Dressing Up.mpg", CacheFolder = "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp")
Audio = A2DAudioSource("C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Dressing Up.mpg", CacheFolder = "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp")
Target Video FileSize: 32.9 MB
FFmpeg Parameters: -i "C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Dressing Up.mpg" -vcodec copy "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_07_Dressing Up.m2v"
<11-02-2009 21:41:20>
Created File: C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_07_Dressing Up.m2v (44.2 MB)
ReJig Parameters: -size 32 -o "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_07_Dressing Up.ReJig.m2v" -i "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_07_Dressing Up.m2v" -auto -close -quiet
<11-02-2009 21:41:24>
Transcoding excuted on File: C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_07_Dressing Up.m2v (32.1 MB)
OUTPUT VIDEO INFO:
Filename: DVD_3_Title_07_Dressing Up
Filesize: 33709720 Byte
Format: MPEG Video
Time: 12:03 minutes
AvgBitRate: 372
Resolution: 720x576
Aspect Ratio: 1.778
FPS: 25.000
Interlacement: PPF
Frames: 18085
FFmpeg (WAV) Parameters: -i "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_3_Title_07 _Dressing Up.avs" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_3_Title_07 _Dressing Up.wav"
Aften (AC3) Parameters: -b 192 "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_3_Title_07 _Dressing Up.wav" "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_07_Dressing Up.ac3"
<11-02-2009 21:41:40>
Created File: C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_07_Dressing Up.ac3 (6.8 MB)
TITLE 8 SOURCE FILES
Video: C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Flying a Kite.mpg
Info: MPEG-2 Video - 457 kbps - 720x576 - DAR 1.778 - 25 fps - PPF - 10:27 minutes - 15685 frames
Audio: C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Flying a Kite.mpg
Info: MPEG-1 Audio layer 2 - 192 kbps - CBR - 48000Hz - 2ch - 10:26 minutes
Subs:
AVISYNTH SCRIPT
Video = A2DVideoSource("C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Flying a Kite.mpg", CacheFolder = "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp")
Audio = A2DAudioSource("C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Flying a Kite.mpg", CacheFolder = "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp")
Target Video FileSize: 34.2 MB
FFmpeg Parameters: -i "C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Flying a Kite.mpg" -vcodec copy "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_08_Flying a Kite.m2v"
<11-02-2009 21:41:45>
Created File: C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_08_Flying a Kite.m2v (43.1 MB)
ReJig Parameters: -size 34 -o "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_08_Flying a Kite.ReJig.m2v" -i "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_08_Flying a Kite.m2v" -auto -close -quiet
<11-02-2009 21:41:48>
Transcoding excuted on File: C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_08_Flying a Kite.m2v (34.1 MB)
OUTPUT VIDEO INFO:
Filename: DVD_3_Title_08_Flying a Kite
Filesize: 35725442 Byte
Format: MPEG Video
Time: 10:27 minutes
AvgBitRate: 456
Resolution: 720x576
Aspect Ratio: 1.778
FPS: 25.000
Interlacement: PPF
Frames: 15685
FFmpeg (WAV) Parameters: -i "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_3_Title_08 _Flying a Kite.avs" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_3_Title_08 _Flying a Kite.wav"
Aften (AC3) Parameters: -b 192 "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_3_Title_08 _Flying a Kite.wav" "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_08_Flying a Kite.ac3"
<11-02-2009 21:42:05>
Created File: C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_08_Flying a Kite.ac3 (6.8 MB)
TITLE 9 SOURCE FILES
Video: C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Frogs and Worms and Butterflies.mpg
Info: MPEG-2 Video - 307 kbps - 720x576 - DAR 1.778 - 25 fps - PPF - 12:08 minutes - 18205 frames
Audio: C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Frogs and Worms and Butterflies.mpg
Info: MPEG-1 Audio layer 2 - 192 kbps - CBR - 48000Hz - 2ch - 12:07 minutes
Subs:
AVISYNTH SCRIPT
Video = A2DVideoSource("C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Frogs and Worms and Butterflies.mpg", CacheFolder = "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp")
Audio = A2DAudioSource("C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Frogs and Worms and Butterflies.mpg", CacheFolder = "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp")
Target Video FileSize: 26.6 MB
FFmpeg Parameters: -i "C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Frogs and Worms and Butterflies.mpg" -vcodec copy "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_09_Frogs and Worms and Butterflies.m2v"
<11-02-2009 21:42:08>
Created File: C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_09_Frogs and Worms and Butterflies.m2v (38 MB)
ReJig Parameters: -size 26 -o "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_09_Frogs and Worms and Butterflies.ReJig.m2v" -i "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_09_Frogs and Worms and Butterflies.m2v" -auto -close -quiet
<11-02-2009 21:42:12>
Transcoding excuted on File: C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_09_Frogs and Worms and Butterflies.m2v (26.2 MB)
OUTPUT VIDEO INFO:
Filename: DVD_3_Title_09_Frogs and Worms and Butterflies
Filesize: 27514574 Byte
Format: MPEG Video
Time: 12:08 minutes
AvgBitRate: 300
Resolution: 720x576
Aspect Ratio: 1.778
FPS: 25.000
Interlacement: PPF
Frames: 18205
FFmpeg (WAV) Parameters: -i "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_3_Title_09 _Frogs and Worms and Butterflies.avs" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_3_Title_09 _Frogs and Worms and Butterflies.wav"
Aften (AC3) Parameters: -b 192 "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_3_Title_09 _Frogs and Worms and Butterflies.wav" "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_09_Frogs and Worms and Butterflies.ac3"
<11-02-2009 21:42:28>
Created File: C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_09_Frogs and Worms and Butterflies.ac3 (6.8 MB)
<11-02-2009 21:42:38>
START DVD AUTHORING OPERATIONS
BatchMux Parameters: -arglist "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_3_BatchMux .ini"
BatchMux ini file:
-d "C:\Documents and Settings\Administrator\My Documents\DVD_3\VIDEO_TS"
-mxp "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_3_MuxMan.m xp"
-l "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_3_MuxMan.l og"
-muxman "C:\Program Files\AVStoDVD\MuxMan"
-prio LOW
-v "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_01_Hiccups.m2v"
-vidmode LB
-a1 "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_01_Hiccups.ac3"
-a1lang en
-SEG2v "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_02_Babysitting.m2v"
-SEG2vidmode LB
-SEG2a1 "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_02_Babysitting.ac3"
-SEG2a1lang en
-SEG3v "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_03_Best Friend.m2v"
-SEG3vidmode LB
-SEG3a1 "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_03_Best Friend.ac3"
-SEG3a1lang en
-SEG4v "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_04_Bicycles.m2v"
-SEG4vidmode LB
-SEG4a1 "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_04_Bicycles.ac3"
-SEG4a1lang en
-SEG5v "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_05_Cold Winter Day.m2v"
-SEG5vidmode LB
-SEG5a1 "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_05_Cold Winter Day.ac3"
-SEG5a1lang en
-SEG6v "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_06_Daddy Pig's Birthday.m2v"
-SEG6vidmode LB
-SEG6a1 "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_06_Daddy Pig's Birthday.ac3"
-SEG6a1lang en
-SEG7v "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_07_Dressing Up.m2v"
-SEG7vidmode LB
-SEG7a1 "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_07_Dressing Up.ac3"
-SEG7a1lang en
-SEG8v "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_08_Flying a Kite.m2v"
-SEG8vidmode LB
-SEG8a1 "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_08_Flying a Kite.ac3"
-SEG8a1lang en
-SEG9v "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_09_Frogs and Worms and Butterflies.m2v"
-SEG9vidmode LB
-SEG9a1 "C:\Documents and Settings\Administrator\My Documents\DVD_3_Title_09_Frogs and Worms and Butterflies.ac3"
-SEG9a1lang en
-SEG10v "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_3_Menu.bmp "
-SEG10vidmode LB
-SEG10s1 "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_3_Menu.sst "
-SEG10s1dmode WIDE_LB
-SEG10hlmnu "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_3_Buttons. mnu"
-SEG10hlcsm "C:\Program Files\AVStoDVD\Menu\Highlight_Scheme.csm"
-hcn "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_3_BatchMux .hcn"
<11-02-2009 21:43:29>
END DVD AUTHORING OPERATIONS
Created Folder: C:\Documents and Settings\Administrator\My Documents\DVD_3 (393.9 MB)
START DVD BURNING OPERATIONS
ImgBurn (DVD) Parameters: /mode isobuild /buildmode device /src "C:\Documents and Settings\Administrator\My Documents\DVD_3\VIDEO_TS" /dest D: /volumelabel "DVD" /speed 2x /erase /testmode no /verify no /noimagedetails /start /waitformedia /close
<11-02-2009 21:48:20>
END DVD BURNING OPERATIONS
Created DVD: <DVD> in drive D: TSSTcorp DVD+-RW TS-L632H D300
Log file created by AVStoDVD Release 2.1.3 Alpha build 090102
A) AVStoDVD preview does not need Quicktime. If you can play your file with Windows Media Player, than AVStoDVD preview will work too. If not, there are some codec issues. Have you installed a good codec suite, like ffdshow?Originally Posted by alhenderson
B) Do use the new release (2.1.4) because it fixes several things. You have just encountered one of them (mpeg2 files not correctly read by MediaInfo). Looking at log files, your mpeg2 are surely strange: their res is extremely low (300/500 kbps)
They should look orrible!
C) Since your mpeg2 files contains MP2 audio (DVD compliant) I suggest you to keep them. Go to 'Settings'/'AudioVideo' and select "MP2" as 'Audio Format'.
Let me know -
Sorry - I was thinking MPEG Stream Clip for Quicktime - didn't realise AVsToDVD has a preview. I just tried and I get an alert saying "Error 445 - object doesn't support this action". I don't see an 'ffdshow' folder under program files - does this mean I haven't got it? I certainly don't remember explicitly installing it, unless it was installed as part of something else.
Is there any way round having to enter the play time manually? If not, do I have to be exact? I know these are all roughly 4-5 mins, so could I enter 5 mins for each?
As for looking horrible - when I played back the DVD, the video looked the same as it does when its live on the telly, so no problems there. Maybe its the way its broadcast?
Al. -
I'm at work at the moment so can't try it - are you suggesting that I change the audio format to MP2 and try again?Originally Posted by _MrC_
Thanks,
Al. -
Just tried with 2.1.4 and audio format set to MP2. Burned two titles, and each had the correct sound track, which was good. Synch of audio was way out, though...Originally Posted by _MrC_
Log below:
<12-02-2009 21:07:07>
START PROCESS
DVD SETTINGS
DVD Titles number: 2
DVD Chapters Interval: 5 min
DVD Label: DVD
DVD Size: 627/4435 MB (14%)
Save Log file: Yes
Info: MPEG-2 Video - 15900 kbps - 720x576 - DAR 1.778 - 25 fps - PPF - 5:00 minutes - 0 frames
Info: MPEG-1 Audio layer 2 - 192 kbps - CBR - 48000Hz - 2ch - 5:00 minutes
Subs:
[MediaInfoLib - v0.7.10]
AVISYNTH SCRIPT
Return Video
START VIDEO ENCODING OPERATIONS
Encoding Profile: QuEnc CBR 1-pass
Target Video FileSize: 304 MB
QuEnc Parameters: -i "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_5_Title_01 _Babysitting.avs" -o "C:\Documents and Settings\Administrator\My Documents\DVD_5_Title_01_Babysitting.m2v" -b 8500 -1 -hq -novbr -scene -trell -aspectratio 16:9 -nointerlaced -mpeg2mux noaudio -dc 10 -priority 5 -auto -close
<12-02-2009 21:09:03>
Created File: C:\Documents and Settings\Administrator\My Documents\DVD_5_Title_01_Babysitting.m2v (598.7 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 8645 kbps - 720x576 - DAR 1.778 - 25 fps - PPF - 9:50 minutes - 14772 frames
ReJig Parameters: -size 303 -o "C:\Documents and Settings\Administrator\My Documents\DVD_5_Title_01_Babysitting.ReJig.m2v" -i "C:\Documents and Settings\Administrator\My Documents\DVD_5_Title_01_Babysitting.m2v" -auto -close -quiet
<12-02-2009 21:09:09>
Transcoding excuted on File: C:\Documents and Settings\Administrator\My Documents\DVD_5_Title_01_Babysitting.m2v (91.2 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 1310 kbps - 720x576 - DAR 1.778 - 25 fps - PPF - 9:50 minutes - 14772 frames
<12-02-2009 21:09:10>
START AUDIO DEMUXING OPERATIONS
FFmpeg Parameters: -i "C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Babysitting.mpg" -acodec copy "C:\Documents and Settings\Administrator\My Documents\DVD_5_Title_01_Babysitting.ToFix.mp2"
<12-02-2009 21:09:12>
Created File: C:\Documents and Settings\Administrator\My Documents\DVD_5_Title_01_Babysitting.mp2 (6.7 MB)
OUTPUT AUDIO INFO: MPEG-1 Audio layer 2 - 192 kbps - CBR - 48000Hz - 2ch - 4:54 minutes
Info: MPEG-2 Video - 15900 kbps - 720x576 - DAR 1.778 - 25 fps - - 5:00 minutes - 0 frames
Subs:
AVISYNTH SCRIPT
Return Video
QuEnc Parameters: -i "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_5_Title_02 _Best Friend.avs" -o "C:\Documents and Settings\Administrator\My Documents\DVD_5_Title_02_Best Friend.m2v" -b 8500 -1 -hq -novbr -scene -trell -aspectratio 16:9 -nointerlaced -mpeg2mux noaudio -dc 10 -priority 5 -auto -close
<12-02-2009 21:11:00>
Created File: C:\Documents and Settings\Administrator\My Documents\DVD_5_Title_02_Best Friend.m2v (559.8 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 8645 kbps - 720x576 - DAR 1.778 - 25 fps - PPF - 9:12 minutes - 13812 frames
ReJig Parameters: -size 303 -o "C:\Documents and Settings\Administrator\My Documents\DVD_5_Title_02_Best Friend.ReJig.m2v" -i "C:\Documents and Settings\Administrator\My Documents\DVD_5_Title_02_Best Friend.m2v" -auto -close -quiet
<12-02-2009 21:11:05>
Transcoding excuted on File: C:\Documents and Settings\Administrator\My Documents\DVD_5_Title_02_Best Friend.m2v (95.9 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 1475 kbps - 720x576 - DAR 1.778 - 25 fps - PPF - 9:12 minutes - 13812 frames
<12-02-2009 21:11:06>
FFmpeg Parameters: -i "C:\Documents and Settings\Administrator\My Documents\My Videos\Peppa Pig\to burn\Best Friend.mpg" -acodec copy "C:\Documents and Settings\Administrator\My Documents\DVD_5_Title_02_Best Friend.ToFix.mp2"
<12-02-2009 21:11:08>
Created File: C:\Documents and Settings\Administrator\My Documents\DVD_5_Title_02_Best Friend.mp2 (6.9 MB)
OUTPUT AUDIO INFO: MPEG-1 Audio layer 2 - 192 kbps - CBR - 48000Hz - 2ch - 4:59 minutes
<12-02-2009 21:11:09>
BatchMux Parameters: -arglist "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_5_BatchMux .ini"
BatchMux ini file:
-d "C:\Documents and Settings\Administrator\My Documents\DVD_5\VIDEO_TS"
-mxp "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_5_MuxMan.m xp"
-l "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_5_MuxMan.l og"
-prio LOW
-v "C:\Documents and Settings\Administrator\My Documents\DVD_5_Title_01_Babysitting.m2v"
-vidmode LB
-a1 "C:\Documents and Settings\Administrator\My Documents\DVD_5_Title_01_Babysitting.mp2"
-a1lang en
-SEG2v "C:\Documents and Settings\Administrator\My Documents\DVD_5_Title_02_Best Friend.m2v"
-SEG2vidmode LB
-SEG2a1 "C:\Documents and Settings\Administrator\My Documents\DVD_5_Title_02_Best Friend.mp2"
-SEG2a1lang en
-SEG3v "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_5_Menu.bmp "
-SEG3vidmode LB
-SEG3s1 "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_5_Menu.sst "
-SEG3s1dmode WIDE_LB
-SEG3hlmnu "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_5_Buttons. mnu"
-SEG3hlcsm "C:\Program Files\AVStoDVD\Menu\Highlight_Scheme.csm"
-hcn "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\DVD_5_BatchMux .hcn"
<12-02-2009 21:11:34>
Created Folder: C:\Documents and Settings\Administrator\My Documents\DVD_5 (210.3 MB)
ImgBurn (DVD) Parameters: /mode isobuild /buildmode device /src "C:\Documents and Settings\Administrator\My Documents\DVD_5\VIDEO_TS" /dest D: /volumelabel "DVD" /speed 2x /erase /testmode no /verify no /noimagedetails /start /waitformedia /close
<12-02-2009 21:16:25>
Log file created by AVStoDVD Release 2.1.4
No joy, I'm afraid. Audio synch is still out. Only burning two titles now. The MPGs are fine when I play them with VideoLAN. Tried burning just one title and it had the same problem. When I play the MPG in VideoLAN, the time bar at the bottom says that the total length is 9 - 10 mins (depending on the title), but it actually only lasts 4:50 or so (the time bar jumps 5 minutes in the last seconds). Clearly there's something wrong with the timeframe information in the MPG. Could that be having an effect?Originally Posted by _MrC_
Still no go on previewing in AVsToDVD - get the error I mentioned in a previous post.
Al. -
Yes, it could be. BTW you can adjust audio delay with AVStoDVD. Go to 'Title Edit'/'AviSynth', toggle off 'Auto AviSynth Script' and toggle on 'Delay Audio'. Then add the delay/advance of your file audio vs video.Originally Posted by alhenderson
If internal preview does not work, you can try using an external previewer. Go to 'Settings'/'Path', toggle on 'Use external player' and select your favourite media player (VideoLAN, MPC, WMP, etc.)Originally Posted by alhenderson
Bye -
Think I *may* have sussed this. I went back to basics and re-converted my original ts files that came off the PVR. I used MPEG Stream Clip to trim the files to the absolute minimum, got it to only convert one of the two audio tracks and then converted to MPG. Have burnt two of these MPGs with AVsToDVD and all is well, perfectly in synch and both have the correct soundtrack.
So, it looks like it was a problem with the MPGs I was trying to burn, specifically something wrong with the timeline information, may be down to how the PVR trimmed them, who knows.
Anyway, thanks all, especially MrC - and sorry to have started out blaming AvsToDVD when it was nothing to do with it at all!!
Al.
AVStoDVD limit the number of chapters/titles in Menu
By Nirvana_417 in forum Authoring (DVD)Replies: 3Last Post: 4th Feb 2012, 11:40 -
Combining multiple titles into one
By augerpro in forum Video ConversionReplies: 2Last Post: 22nd Sep 2011, 16:50 -
MKV with multiple titles\chapters..
By dregatar in forum Video ConversionReplies: 0Last Post: 12th Jun 2010, 02:01 -
What is the best way to combine multiple titles into one title?
By sldvd in forum Newbie / General discussionsReplies: 2Last Post: 14th May 2010, 09:39 -
Help trying to combine multiple titles into one
By Muskogeee in forum Authoring (DVD)Replies: 1Last Post: 28th Feb 2009, 00:35
