I have a bunch of DVDs that I need to make some product samples from. Is there a tool out there that will simply let me mark in and mark out the section I want, and then let me save it to a 640x480 MP4? If not, what would be the easiest (least amount of steps) way to get this project done? The DVDs audio is AC3.
	I don't want to rip the whole DVD. I just need to get 1 or 2 minute samples. I'm looking in the DVD to MP4 tools list now for something...
	If it's not copy protected, you can use mpg2cut2 to cut sections out of vob's. Then feed these .mpg segments into any encoder (e.g. ripbot264, xvid4psp, megui). You could even open a vob segment directly in avidemux, resize, encode (1 tool instead of 2)
 If it's copy protected, chances are you have to rip the whole dvd first, or the segment might come out looking funny /distorted
	No they're not copy protected DVDs. They're our learning products that we sell and I just want to make some sample videos for the product pages on the website. If I use mpg2cut2 to cut a section out, is the cut out section audio saved as WAV or is it still in AC-3 format? If it's not AC3, then I can just take the section and drop it onto a Vegas timeline, correct?
	mpg2cut2 is limited to cutting at the gop level on keyframes (not frame accurate), but that's what you get for free.
 videoredo can cut on exact frames.
 Both do not re-encode (original audio & video preserved), except the few frames around the cutsite for videoredo if not on an exact keyframe
 Vegas sometimes has issues with AC3 depending on your setup
  easiest free mp4 editorBy angryassdrummer in forum Video ConversionReplies: 2Last Post: 5th Apr 2011, 04:38
  The easiest way to convert dvd to mp4By karib in forum Video ConversionReplies: 2Last Post: 8th Feb 2011, 17:01
  VirtualDub....save as .mp4By Ogilvy in forum Video ConversionReplies: 2Last Post: 20th Mar 2010, 00:29
  MP4 (h264): Easiest Conversion?By m93 in forum Video ConversionReplies: 9Last Post: 15th Dec 2008, 23:13
  Easiest way to join several MP4 files?By slateef in forum EditingReplies: 1Last Post: 20th Sep 2008, 23:44
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
