I've opened Adobe Premiere, File, Capture. Says it is offline. Went to Edit, Preferences, Device Control, Options. Made appropriate choices and still Offline. The computer recognizes that there is a new device with the sound, but it does not show up anywhere. I've gone to Computer Management, Disk Management. (Not quite sure how to add). I'm using Adobe Premiere Pro CS3, Windows XP on a Dell computer. The computer is not connected to a LAN and no wireless connectivity available where I'm at. I'm using a Panasonic AG-HVX2000 or a Sony GV-D1000.
Can someone help?
Thank you,
Ineedatalent
Have you tried other capture software to see if the camcorders are visible to Windows?
See this document to help troubleshooting:
http://www.enosoft.net/dl.php?filename=dv_connectivity.pdfJohn Miller
Can you import from Adobe After Affects to Adobe Premiere Pro?
By Devilsadvocate in forum EditingReplies: 9Last Post: 29th Feb 2012, 21:43 -
Best device to read PDF books?
By alegator in forum ComputerReplies: 2Last Post: 16th Nov 2010, 02:42 -
Adobe Premiere Pro Not Recognizing Capture Card
By ercdill in forum Newbie / General discussionsReplies: 1Last Post: 5th Dec 2008, 14:59 -
Adobe Premiere 1.5: Adobe Media Encoder: Frame size and scaling?
By vid83 in forum EditingReplies: 2Last Post: 30th Nov 2008, 03:17 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 04:31
