Hello, dear all.
Can you point me some tools (freewares and paywares) wich can cut & join FLV files, just You Tube files or similar ones?
Thank you.
Best regards.
I could find some other tools:
---> http://www.onflex.org/ted/2008/07/richflv-finally-flv-editor.php (RichFLV)
---> http://split-flv-video.qarchive.org/
---> http://search.cpan.org/~cdolan/FLV-Info-0.22/
PS: for flv with h264 video, do you can point me other tools wich can deal with them? -
for h.264/aac in .flv, i would use flvextract (the new version supports this type of flv) to extract the raw streams, then use yamb to put them in .mp4 container. Then you can use yamb to cut / join or even avidemux
Hello !!
How can I do that?to put them in .mp4 container
Thanks for the tip !! :P
Best regards.
devil (johner) -
Originally Posted by devilcoelhodog
Please re-read my post. It outlines exactly what to do. Flvextract. Yamb.
Make sure you enter the fps on the raw video properties tab (check with mediainfo on the original flv to get the value)
Cheers
joining tools (preferably with flv/mov support + others)
By lordrt in forum EditingReplies: 3Last Post: 20th Aug 2010, 11:53 -
Cutting/Merging MKV file - Mkvtoolnix
By FMFIA in forum EditingReplies: 1Last Post: 15th Aug 2010, 01:47 -
What are the best professional tools from Source to FLV ?
By mrslurpee in forum Newbie / General discussionsReplies: 1Last Post: 10th Nov 2009, 01:54 -
cutting FLV files
By shaema in forum EditingReplies: 2Last Post: 24th Sep 2009, 12:01 -
Alternative AC3 cutting and joining tools
By 557953 in forum AudioReplies: 2Last Post: 21st Aug 2007, 12:11
