Hi all,
I bought a Magnavox TB100MW9 converter box a while back. Hooked it up a month ago to an old TV & scanned it to make sure it worked [worked fine]. I then turned it off and let it be just a pass-through until 2/17 arrives. Just recently, my analog signal became nearly non-existent. I pulled both coax cables off the box and hooked them together. Voila, analog signal is fine & strong. Turning the box on, off or to standby doesn't help. My question: Is the pass-through feature a constant or can the box being shut off too long stop it? OR did the box just go defective while sitting there all by itself?![]()
Thanks.
T'care,
Mike
I have the same box, but mine never had passthrough. I can't find my user guide at the moment, so I can't confirm whether it was supposed to support it or not.
Buy My Books -
The Magnavox TB100MW9 is an ealy version that does not support analog passthrough. The successor model TB100MW9A has that feature. Maybe the "A" was inadvertantly left off when you typed in the model number?
Not being used should not in and of itself make the a feature stop working. Theoretically a component could have gone bad just sitting there. I don't know what the Magnavox boxes do, but some CECBs periodically "wake up" for short periods if plugged into an outlet, even after they have been turned off. -
Thanks for your rapid reply. I checked the box and it's definitely a 9 only [no A]. It was passing the signal through for a month though. Oh well, only 6 more days and I'll know if the box still works. Either way, I probably still wouldn't need the pass-through feature anymore. Thanks much though for the helpful information. Fingers are crossed!
Always
Mike
Feature Film Lost footage on DVD
By colossus34 in forum Video ConversionReplies: 20Last Post: 4th May 2011, 13:53 -
Do I need the Converter Box?
By capman21 in forum DVB / IPTVReplies: 5Last Post: 12th Oct 2010, 22:17 -
Digital set top box, lost programme guide
By SILVER ANGEL'S WINGS in forum Newbie / General discussionsReplies: 0Last Post: 3rd Jun 2010, 01:13 -
On getting a DTV converter box...
By ahhaa in forum ComputerReplies: 0Last Post: 12th Apr 2008, 12:27 -
Digital TV Converter Box $9.95
By sushix in forum DVB / IPTVReplies: 1Last Post: 12th Mar 2008, 20:07
