  1. I'm having problems with the backgroubd sound when I author a Photo Album with WinOnCD 5, the album comes out GREAT but the sound is all f..ked up even though I use a 44.1 mp3 sound file. Starangly enought when I put in a video file it runs nicely with the sound.
    The same problem with music album. The sound it again f..ked up
    PLEASE PLEASE help ... Thanks in advance
  2. I had the same problem, even posted the same question. No-one was able to solve the music problem. Suggest you try Uleads dvd picture show.You can download a trial version on their homepage. It worked great for me....even went & bought it....good luck
    Jul 2001
    los angeles
    I've used this application to make photo albums with sound. So far it has produced good vcd's that play flawlessly in my apex ad-660, but the sound gets all mucked up when i play it in my apex ad-800. Go figure, i think it has something to do with the way these players handle the vcd. My suggestion, try it in your computer and if your vcd plays fine, then it's your player, if it doesnt, then it's obviously your software, but ive had nothing but good results when playing these things in my computer with the included vcd player software the 3.8 power edition lets you inclue in your compilation.
