Hi,
I wasn't sure what category to put this under but I have a GeForce FX 5200 graphics card with 64 MB VRAM. It has a DVI port which is hooked up to my Cinema display and there is a second port that looks similar to the DVI but it has more pin. It seems to have 30 pins instead of the 24 pins of the DVI and the port is a bit longer. What kind of port is this? I was hoping to hook up a second monitor but I'm not really sure what cable I want to get. I own an LCD screen with HDMI? Is there a cable has whatever this mystery port is with HDMI on the other end? I assume this thing is a digital port. Does anyone recognize this port by my description? A bit longer than normal DVI and 30 pin?
http://www.directron.com/cbdvm1dm24dsmx.html
Maybe? M1 (also called EVC, or P&D)
Vga to dvi-d issues
By clevelandrager in forum Newbie / General discussionsReplies: 1Last Post: 6th Apr 2011, 17:16 -
Plug DVI/HDMI adapter to DVI video card?
By Stealth3si in forum Media Center PC / MediaCentersReplies: 25Last Post: 23rd Dec 2010, 19:32 -
PC to TV DVI to HDMI signal issues
By GokuuSon in forum Media Center PC / MediaCentersReplies: 12Last Post: 12th Jan 2010, 11:34 -
Computer DVI output to TV DVI input
By superdud1400 in forum DVB / IPTVReplies: 12Last Post: 13th Jul 2008, 09:44 -
DVI-D cable in DVI-I slot-possible? Quality loss?
By bigshotceo in forum DVB / IPTVReplies: 1Last Post: 21st Dec 2007, 06:49
