    Oct 2005
    I’m converting animated avi clips to mpeg2 using TMPGEnc so I can author them onto a dvd. I have 60 mpegs, each one min long. I don’t know if I should use CBR or VBR, or one pass or 2 pass. I want a good quality file like the original AVI but don’t want a huge file size. What mpeg2 output settings should I use? I’d like to have a good quality because I think I loose some when I edit/render the mpegs in my video editor. Thanks
    Apr 2004
    Miskatonic U
    60 videos at 1 minute each = 60 minutes, which will fit happily at the highest allowable bitrate for DVD. I would encode CBR at around 8700 - 9000 kbps.
    That said, you should have done your editing before you converted to mpeg2, unless you are using a dedicated mpeg-2 editor.
    Read my blog here.
    Oct 2005
    thanks, do you have any suggestions for an editor? i'm using sony screenblast. it's old but i know how to use it and when i load an avi into it, the audit is not there, so the only thing that worked was to convert it to mpeg....edit and then render it all to another mpeg.
  4. Member MysticE's Avatar
    Nov 2003
    If you AVI editing needs are simple, a trim here and there, Avidemux (free) may suit you.
