I can't explain exactly the problem but I've uploaded the video. This lightning happens somethimes but I don't see any logic in that. Do you know what it is? This was recorded with Samsung HR773 dvd recorder.
http://uploading.com/files/W87XWU7D/lighting.mpg.html
	I dropped the clip into VirtualDub and stepped through it frame by frame. I see some minor brightness changes in about the middle of that clip, but that could be from the camera metering or external reflections or even a photographers flash bulb off camera. No extreme brightness changes or any flashes that I could see in that clip.
 Can you supply more information, or at least a better descripton of your 'lightning'?
	Frames 17, 18 and 19 are slightly dimmer than the others. The change in brightness is causing what you see - it's kind of a reverse "lightning". Why is another question. I don't know.
	Given that it looks like a commercial source, I'd guess some kind of anti-copying signal such as Macrovision. John Miller
	It was recorded with a dvd recorder from a satellite reciever thru a scart cabel. I don't think that it's an anti-copying signal because sometimes it happens only once in an hour, but sometimes 10 times in a hour. Don't see any logic in that. Here is an other example, maybe its better. It would be really nice if someone would know what it is.
 http://uploading.com/files/EK0U9ZDQ/flashing.mpg.html
  Is there any video card that can encode/convert video at lightning speed?By johnharlin in forum Video ConversionReplies: 11Last Post: 17th Mar 2012, 16:27
  Trouble Copying a DVD. Lightning or Something Else?By solarblast in forum Authoring (DVD)Replies: 4Last Post: 10th Jun 2009, 22:24
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
