Hi,
I have a .avi movie file and the subtitles to go with it in .srt how do i play them together in VLC??
thanks in advance
It should play automatically (at least it does in windows). They have to be the same name and in the same folder
file.avi
file.srt
If not, go into the options and you can set the subtitle options
Cheers -
ok they were in the same file but had different names, that worked though thanks
calderhead
You need to learn some patience or you are gonna run into trouble here.
Reposting for a reply 5 minutes then another 10 minutes after your original post
If you need to add something to your OP just use the EDIT button.
People don't surf here 24/7 that know the answer to every specific question posted.
How to watch an mp4 with subtitles in a .srt file
By Robor in forum Newbie / General discussionsReplies: 0Last Post: 9th Jul 2011, 06:47 -
How to merge .srt subtitles to a .vob video file
By GoNGaXiNHuO in forum SubtitleReplies: 5Last Post: 29th Dec 2010, 07:04 -
convert avi+srt files to avi with embedded subtitles
By flannob in forum Newbie / General discussionsReplies: 0Last Post: 30th Sep 2010, 06:35 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 19:45 -
Subtitles to .srt file ripper?
By vidmarc in forum MacReplies: 1Last Post: 8th Aug 2007, 13:33
