I am running Vista 64 bit and Divx Author craps out everytime I run it. I have tried many of the suggested options from Divx forums but nothing works. I need a program to edit video clips (unwanted commercials and etc.) and then convert them to Divx. Any suggestions?
Thanks!
Jason
Well, you don't have to do these tasks with Divx Author. You could instead do:
1) Assuming MPEG-1/2 source, edit with VideoReDo or MPEGVCR (both are try before you buy, but neither is freeware). Assuming AVI source you have some free options for editing, like Virtual Dub.
2) Use the free Dr. Divx to convert the edited file to Divx.
Unless you need Divx 6 subtitles or chapters, you don't have to use Divx Author for this.
Replacement for TMPEGnc DVD Author for the Mac?
By The Monkees in forum MacReplies: 1Last Post: 24th Feb 2009, 14:36 -
Pioneer DVR-433H Burner drive replacement - HDD Replacement 750GB succesful
By linkox in forum DVD & Blu-ray RecordersReplies: 1Last Post: 17th Dec 2008, 12:57 -
Does Tmpg Divx Author encode or it only author ?
By BlackShadow90 in forum Authoring (DVD)Replies: 3Last Post: 29th Jul 2008, 04:56 -
DVD author replacement for mac
By MarauderFox79 in forum MacReplies: 3Last Post: 16th Nov 2007, 07:01 -
Dr. Divx replacement?
By helloguys in forum Video ConversionReplies: 3Last Post: 30th Sep 2007, 20:33
